TI 99 Disk Controller question...
eccofonic
After several years in storage, I put back together a PEB. The flex cable card and 32k RAM card work fine, but the TI disk controller card....
When the card is accessed, the LED on the card stays lit and the computer hangs. Regardless of whether a drive is connected or not. Doesn't matter which slot I put it in either (I know it's supposed to be the closest one to the drive bay). I noticed the 5v regulator chip gets warm, but no other chips do, including the 12v regulator.
What would be the behavior of a known-working TI disk card if no drives were connected? Would it hang the computer or just generate an error and continue?
Test all power supply outputs from the PEB itself, even if the RS232 and 32K works, it could be the power supply is having issues.
I got five PEB's myself, and out of them 4 of them are having major issues with 12volt load when I got more then 3 cards in the cage, after 30 years of usage they are starting to die, and very rarely got turned off.
Might be time to convert them over to PC power supplies, and then convert over all the cards to use direct and remove 5 and 12 regulators.
It hangs when I power on the console.
Have you got a MiniMem cartridge, then you can check the DSR? You'll need to power on the console first, then the PEB. Then with the MiniMem cartridge you need the following (IIRC):
(1) From the MiniMem menu, select EasyBug.
(2) C 1100 1 <Return> [Floppy LED should light]
(3) M 4000 <Return><Space><Space>... [To read out memory]
Compare the data you're getting against this: http://nouspikel.group.shef.ac.uk/ti99/dc1.txt. If you see errors, then a common point of failure is the 74LS245 on the floppy card, which runs rather hot and has a bit of a hard time.
I do have Minibug.
Unless my ROMs are completely different, I see these bits changed:
A4000-01 should be AA 02 but is AA 00
A4008-09 should be 40 4A but is 40 48
A4012-13 should be 5B 38 but is 58 38
A401A-1B should be 01 11 but is 01 10
A401C-1D should be 40 22 but is 45 22
A401E-1F should be 5B 52 but is 5A 50
A4020-21 should be 01 12 but is 01 10
A4022-23 should be 40 28 but is 40 29
A4024-25 should be 5B AC but is 5A AC
A4026-27 should be 01 13 but is 00 10
A402A-2B should be 5C 78 but is 58 78
A402C-2D should be 01 14 but is 00 14
A4034-35 should be 40 34 but is 40 38
many other random errors follow....
I do have Minibug.
If you take the floppy card apart, are the ROMs original? http://nouspikel.group.shef.ac.uk/ti99/fdcard.htm
Have you got other cards in the PEB that *do* work? That I think would rule out problems with the PEB power supply. Next I think I would replace the 5V regulator on the floppy card (because it's easy) then look at replacing the 74LS245.
Yes, the RAM card works... I type "SIZE" in extended basic and it gives me the extra RAM total.
The ROMs are labeled as follows:
1501392-33 C2E020 (and date code probably of 8303) this is the one closest to the FD1771 chip
1501392-34 C2E019 (8305)
Answering my own question here (for anyone who needs the info in the future)...
I got another card and it does not hang the system without a drive attached at boot up.
The card LED flickers quickly and then the TI logo screen comes up.
I used MiniMemory and looked at the DSR, and all bytes were the same as the listing in the "dc1.txt" file.
The card functions great with a Tandon TM100-2A I pulled out of an old IBM. I set it to DS0 with terminator IC installed, using a straight cable.
Formats single sided (90k) and double sided (180k) fine. I'm assuming no double density is available. I read the card doesn't support it.
Edited by eccofonic
LOL, more bad luck. Now that I can load programs from the internet (using TI99-PC)....
....any program loaded into my 32k RAM card is either corrupt when listed/run or crashes the computer.
Doesn't matter what slot it's put in. Contacts are clean on the card too.
Other programs/data that load off the disk into VDP RAM or cartridge RAM (i.e. Tunnels of Doom, Adventure, MiniMemory, etc) work fine.
Anyone out there have a spare 32k RAM card for sale or to give away? :grin: ;)
Edited by eccofonic
You could use Easy Bug in the Mini Mem cart to write data to the 32K and then read it back.
First, write a 0 to A000 then read it back. If not zero, a RAM IC is down.
Then try writing FFFF to A000 and read it back. If not FFFF a RAM IC is down.
Using the schematic, it would probably be possible to determine exactly which IC is broken then you could fix it up no problem.
Might also be worth changing the capacitors at the same time - can't remember if there's any liquid type (small canister) caps on the card, but if there are, they're 30 years old and *well* ripe for changing out by now!
