cc65: passing to and from C code
Hi, is the http://www.cc65.org/doc/internal.txt document sufficient enough to learn how to pass data to and from assembler snippets to and from C?
Yes. Try to use the 'fastcall' convention to save some cycles (prototype for the function needed then). And if you have to supply multiple parameters, passing a pointer via fastcall to a struct is more effective than supplying them via stack.
If you encounter problems, inspect the C-library source code.
Edited by Irgendwer
You can use the parameter stack as cc65 itself does by calling the code that cc65 uses.
jsr popax
for instance will pop the top 2 bytes of the parameter stack into the a and x register. Note that parameters are on the stack with the rightmost first. If you use the fastcall convention you will arrive with the rightmost parameter already in a and x, as irgenwer mentioned. Return value is held in ax.
You can also just drop into embedded assembler with the asm() command within a c function.
Its often easier to access a global of some sort in assemb;er. Just remember that C will preprend a underscore for the link name, so that foo becomes _foo. You can jsr to a void parameterless c function just as you can to any assembler label.
Edited by danwinslow
