blakespot #1 Posted September 1, 2014 I just received a Rev F HxC2001 floppy emulator and have mounted it in an SF354 external drive case. Grey-painted HxC2001 mounted in a dremel-modified Atari SF354 enclosure. #ST by blakespot, on Flickr I have an orig 520ST with no internal drive. It's all wired up and powered up but I get not drive activity when booting. I got the ST Manager archive and pulled the HXCSDFE.CFG and AUTOBOOT.HFE from there and put it on the SD card (4GB) with some games in a GAMES/ dir. I have set 8-switch DIP to all possible settings for HxC as drive A: or A: and B: both twisted cable and normal. I never see the track indicator move. When I first booted with no files on SD card, I got an error saying no HXCSDFE.CFG file, and I see the contents of that file have changed since I manually chose a game to load with the front buttons. Any ideas on how to get this working? Thanks. bp Quote Share this post Link to post Share on other sites
Jeff_HxC2001 #2 Posted September 2, 2014 The colored wire of the floppy ribbon should be connected to the right of the drive. Please put a picture of the HxC lcd with a selected HFE to confirm or not the issue. Quote Share this post Link to post Share on other sites
blakespot #3 Posted September 2, 2014 The colored wire of the floppy ribbon should be connected to the right of the drive. Please put a picture of the HxC lcd with a selected HFE to confirm or not the issue. Yes, the photo above is not how it's plugged in. I have flipped the Atari interface board, so the ribbon cable is in reverse orientation vs. the photo, there. So, not the problem, it seems. bp Quote Share this post Link to post Share on other sites
Jeff_HxC2001 #4 Posted September 3, 2014 (edited) Yes, the photo above is not how it's plugged in. I have flipped the Atari interface board, so the ribbon cable is in reverse orientation vs. the photo, there. So, not the problem, it seems. bp may help if you post a picture of the hxc lcd screen and of the actual connection. And you should contact me at the hxc forum for faster exchange. Edited September 3, 2014 by Jeff_HxC2001 Quote Share this post Link to post Share on other sites
blakespot #5 Posted September 12, 2014 Is anyone out there running an HxC2001 on an ST and using it for dual drive emulation? If so, can I get your pinouts? I am using mine in an external drive enclosure on a 520ST which has no internal drive. I am discussing my issues here: http://torlus.com/floppy/forum/viewtopic.php?f=6&t=1478 Can't get the B: drive emu working. Thanks. bp Quote Share this post Link to post Share on other sites
jvas #6 Posted September 21, 2014 Here is mine sharing the case with an UltraSatan: Quote Share this post Link to post Share on other sites
