bogax #1 Posted September 12, 2014 (edited) I'm trying to write a minikernel but some how I've gotten the timing screwed up. Initialization of the TIA happens (mostly) during the first line. Among other things GRP1, GRP0, VDELP1 and VDELP0 get set to $00. RESP1 gets set at cycle 34 (there's 31 cycles before the sta RESP1) then some set up happens for 3 lines and on cycle 69 of the fourth line GRP1 gets set for display on the fifth line but it seems to be appearing on the fourth line. I can't figure out what I've done wrong. code here: http://basicplay.netau.net/ Edited September 12, 2014 by bogax Quote Share this post Link to post Share on other sites
treep78 #2 Posted September 13, 2014 I haven't been able to open that link you put, it just loads the page indefinitely, not sure if that's just me though. In general though, if your having trouble getting any code working there are two basic approaches that I like. 1. Guess and check by reverting the code to something functional (if it was ever at that stage) and adding things back in one at a time until it breaks. 2. Find code similar to what you're trying to accomplish that you know works (like another mini kernel) and change it bit by bit to match yours, sometimes you get something incredibly basic wrong and don't even notice until you go through this process. If I can ever open the page with your code I'll try to go through it and see if I can offer some more helpful suggestions. Quote Share this post Link to post Share on other sites
bogax #3 Posted September 13, 2014 (edited) I haven't been able to open that link you put, it just loads the page indefinitely, not sure if that's just me though. In general though, if your having trouble getting any code working there are two basic approaches that I like. 1. Guess and check by reverting the code to something functional (if it was ever at that stage) and adding things back in one at a time until it breaks. 2. Find code similar to what you're trying to accomplish that you know works (like another mini kernel) and change it bit by bit to match yours, sometimes you get something incredibly basic wrong and don't even notice until you go through this process. If I can ever open the page with your code I'll try to go through it and see if I can offer some more helpful suggestions. I fixed the thing its just a matter of shuffling things around a bit (and putting them where I probably should have in the first place) But I don't understand why it happens. I'm using stella so maybe it's an issue with stella. As to the page it's probably the splash ad (free hosting) here's direct links I don't know that they'll work any better. hex_minikernel_2.bas hex_minikernel_2.bin I used to have that problem with older browsers. I wonder if any one else has that problem (no one else has mentioned it) (probably because nobody bothers to look at it ) the working version (not well tested) hex_minikernel_3.bas hex_minikernel_3.bin hex_minikernel_3.bas hex_minikernel_3.bin Edited September 13, 2014 by bogax Quote Share this post Link to post Share on other sites
