atari2600land
GoSub for INTV
Cool as well! I can use this in my game, right? Here's what it would look like. I worked on a level 14 and made it before I saw that. When I put that in there, I saw that I can switch back and forth from using mode 0 and mode 1. Not only that, it used only 1.5 k!
Yes you can use it, but not as is, make it better. Put back your text and name, add text to say Press a Button to continue, add a Play music statement...Also, notice what happens after Game Over returns to the title screen.
This happens because the Title uses 43 cards, numbered 0 thru 42. You then use DEFINE for your sprites but you are using 0,1 etc thus redefining parts of the cards used by the title. What I do is start DEFINEs for sprites from 63 And work backwards towards the 43 so you won't clobber the title. Currently when you return to the Title screen it appears you are not resetting or hiding the Sprites and thus they are picking up the Gram reDEFINEing. If you DEFINE sprites like
DEFINE 63,1,Octopus
then you can bring back your sprites to the title screen the way you used to have. You could then make the Title Eyes "follow" the Octopus sprite chasing the Submarine sprite. Have them randomly on different y coordinates everytime they wrap.
What is the cycle cost of those extra GOSUBs? Is it essentially insignificant?
By the way, what is a cycle exactly? Is it 1hz? The CPU that Inty uses is technically a good couple hundred thousand hertz slower than the 2600's 6507, yet Inty strikes me as having more processing power. Why is that, or am I just mistaken?
The VBLANK (vertical blanking) event of the NTSC TV signal interrupts the CPU every 1/60th of a second, or at 60Hz. The CPU itself is faster than in the Atari VCS (I think it runs at close to 1MHz, though it has been under-clocked in the NTSC Intellivision to about 900KHz).
Here are some useful estimates taken from the SDK-1600 documentation:
    NTSC Intellivision Timing Parameters
    Parameter                                   Measurement
    NTSC STIC Clock Rate                        3579545 Hz
    STIC Scanlines per Frame                    262 scanlines
    Active Scanlines per Frame                  192 scanlines
    Actual Effective Frame Rate                 59.92 Hz
    CP-1600 Clock Rate (NTSC/4)                 894886.25 Hz
    CPU Cycles per Frame:
     -- Display disabled                        14934 cycles
     -- Display enabled, vertical delay == 0   ~13518 cycles
     -- Display enabled, vertical delay > 0    ~13572 cycles
    CPU Cycles per Scanline                     57 cycles
    CPU Cycles available in Bus Copy mode       3780 - 3790 cycles
    PAL Intellivision Timing Parameters (ESTIMATES)
    PAL STIC Clock Rate                         4000000 Hz
    STIC Scanlines per Frame                 ?? 312 scanlines
    Actual Effective Frame Rate                ~50.00 Hz
    CP-1600 Clock Rate (PAL/4)                  1000000 Hz
     -- Display disabled                       ~20000 cycles
     -- Display enabled, vertical delay == 0 ??~18584 cycles
     -- Display enabled, vertical delay > 0  ??~18638 cycles
    CPU Cycles per Scanline                  ?? 57 cycles
    CPU Cycles available in Bus Copy mode    ?? 8840 - 8850 cycles
This is why every time you have a WAIT statement in your code, it makes the program wait until the next VBLANK interrupt request, essentially "losing" one frame (or the time in between).
I like the new title screen! Fantastic! Although I would like to still see the sub moving around it to give it a more dynamic feel. :)
I did find a bug: the MOBs or BACKTAB cards are not properly reset when going from the "Game Over" screen to the "Title" screen.
-dZ.
But the sprites won't display properly if I change the first number to 63.
Show the define statements for the sub and the matching sprite statements, I suspect what the problem is but I'm not near a real computer to check your last bas file
Adding music data screws up the title screen.
Yep, I've forgot to add that to IntyBASIC manual. Once you activate music, the number of GRAM definable per frame are reduced from 18 to 16.
I would think that the Defines and Screen command would be done before starting music, or are you saying that once we add a reference to Play that the included code affects ALL define statements in the project?
Looking at the latest epilogue code I'd just move the music player to after the GRAM cards are reprogrammed on the fly. There are also a few places where cycles can be clawed back in your ISR.
Right. Once you use PLAY, all DEFINE statements are affected.
Because the GRAM cards redefinition is kind of "lenghty" I made it that way so the music timing keeps the same while the IntyBASIC program is updating the GRAM.
It's a good trick to keep crystal clear timing for ear :)
I'm open to your suggestions for intybasic_epilogue.asm because I don't expect big changes in the future and I know the importance of cycles for doing more complex games.
Also I liked your idea for fixed-point arithmetic, the processing of number in lexical analysis, the addition and substraction are kind of things not so complicated that could be useful for users.
In my experience most people can't detect anything wrong with 50Hz PAL music played at 60Hz (by skipping a sound register update 1 in every 6 frames like you are doing already) so a little jitter in the music player should be acceptable.
OK. When I get some free time I'll PM you a breakdown.
:cool: It'll certainly make RAM go much further with IntyBASIC's more advanced users.
Time to add a new parameter to IntyColor, maybe -P, or make 16 the new default in the generated .bas. You can add it when you add that other feature we talked about...;-)
I looked at your last posted .bas
Rem You define the first 8 GRAM cards of 64
DEFINE 0,7,sprites
Rem You then refer to the Sprites using this notation:
SPRITE 4,X1+$300,Y1+$100,$1820
SPRITE 0,X1+$300,Y1+$100,$1800
The last parameter is sent to the STIC as is, but Nanochess showed me a trick to reference it in a way more understandable, and more importantly, in line with the 0-63 card definition format.
Instead, I'd do this
Rem define the first 8 sprites using upper GRAM cards instead of the first 7,
Rem if using an IntyColor generated screen, start somewhere above the number referenced in the generated file --> ' 43 bitmaps
DEFINE 50,7,sprites 'Define 7 sprites, store them at GRAM cards 50 thru 56
SPRITE 4,X1+$300,Y1+$100,((256+xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx)*8+1
SPRITE 0,X1+$300,Y1+$100,((256+xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx)*8+1
Where xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx is the card number above, starting at 50 to match the card you Defined. The +1 at the end is the color (in Hexidecimal)
I also use the Constants provided earlier to just refer to the color.
SPRITE 4,X1+$300,Y1+$100,((256+51)*8+X_GRN
SPRITE 0,X1+$300,Y1+$100,((256+50)*8+X_RED
REM colors for color stack, border, etc
CONST C_BLK = $0 ' Black
CONST C_BLU = $1 ' Blue
CONST C_RED = $2 ' Red
CONST C_TAN = $3 ' Tan
CONST C_DGR = $4 ' Dark Green
CONST C_GRN = $5 ' Green
CONST C_YEL = $6 ' Yellow
CONST C_WHT = $7 ' White
CONST C_GRY = $8 ' Grey
CONST C_CYN = $9 ' Cyan
CONST C_ORG = $A ' Orange
CONST C_BRN = $B ' Brown
CONST C_PNK = $C ' Pink
CONST C_LBL = $D ' Light Blue
CONST C_YGR = $E ' Yellow-Green
CONST C_PUR = $F ' Purple
rem colors for backtab or mob a
CONST X_BLK = $0 ' Black
CONST X_BLU = $1 ' Blue
CONST X_RED = $2 ' Red
CONST X_TAN = $3 ' Tan
CONST X_DGR = $4 ' Dark Green
CONST X_GRN = $5 ' Green
CONST X_YEL = $6 ' Yellow
CONST X_WHT = $7 ' White
CONST X_GRY = $1000 ' Grey
CONST X_CYN = $1001 ' Cyan
CONST X_ORG = $1002 ' Orange
CONST X_BRN = $1003 ' Brown
CONST X_PNK = $1004 ' Pink
CONST X_LBL = $1005 ' Light Blue
CONST X_YGR = $1006 ' Yellow-Green
CONST X_PUR = $1007 ' Purple
Edited by Tarzilla
OK, so music isn't possible with this setup apparently, so I tried to put some text in there and while lowercase just gets a bunch of symbols, uppercase works just fine, but it switches to a black background. How would I change it to blue?
The COLOR parameter for PRINT AT it's OR'ed with the letter code, put the STIC value you would write directly in screen memory
Sure music is possible, Nanochess said if Play is used anywhere in your code the DEFINE statement gets capped to 16 card definitions at a time instead of 18.
Find this
MODE 1
WAIT
DEFINE 0,18,titlescreen_bitmaps_0
WAIT
DEFINE 18,18,titlescreen_bitmaps_1
WAIT
DEFINE 36,7,titlescreen_bitmaps_2
WAIT
Update the Defines to this:
DEFINE 0,16,titlescreen_bitmaps_0
WAIT
DEFINE 18,16,titlescreen_bitmaps_1
WAIT
DEFINE 36,11,titlescreen_bitmaps_2
WAIT
Then modifiy the bitmaps definition to be no more than 16 per chunk, pushing the last two of _0 into _1, then pushing the last 4 of _1 into _2
titlescreen_bitmaps_0:
DATA $FFFF,$FFFF,$FFFF,$80C0
DATA $FFFF,$FFFF,$FFFF,$0103
DATA $F3FD,$E7E7,$E3E7,$F0E0
DATA $FCFF,$E0F0,$80C0,$0F03
DATA $3FFF,$0307,$0101,$E0C0
DATA $0000,$0000,$0C3C,$3C0C
DATA $FCFF,$C0E0,$8080,$0703
DATA $3FFF,$070F,$0103,$F0C0
DATA $FFFF,$FCFE,$C1F1,$0F03
DATA $E0F8,$80C0,$0080,$0000
DATA $E080,$F0F0,$F8F0,$F8F8
DATA $FEFF,$F8FC,$F8F8,$F0F8
DATA $0000,$0101,$1F1F,$3E3E
DATA $8080,$0000,$FFE0,$0000
DATA $7E7F,$787C,$F878,$F0F8
DATA $0000,$0101,$1F1F,$3F3F
DATA $8080,$0000,$E0E0,$C0E0
DATA $7C7E,$7078,$7070,$F070
titlescreen_bitmaps_1:
DATA $0101,$0202,$3F3F,$0000
DATA $0000,$0000,$FFC0,$031F
DATA $F0F0,$E0F0,$E0E0,$C0E0
DATA $3F3F,$7F3F,$7F7F,$FFFF
DATA $C0C0,$81C0,$8181,$0381
DATA $F8F8,$F0F8,$F0F0,$E0F0
DATA $1010,$2020,$3F3F,$0000
DATA $0001,$0000,$81C1,$0703
DATA $F8F8,$F8F8,$F8F8,$F8F8
DATA $F0F0,$E0F0,$E0E0,$F0E0
DATA $3E3E,$3F3F,$0808,$1010
DATA $0000,$81C1,$0101,$0303
DATA $3F3F,$3F7F,$0808,$1010
DATA $C0C0,$81C1,$0301,$0F03
titlescreen_bitmaps_2:
DATA $FFF8,$C0FF,$C0C0,$E0C0
DATA $F000,$7FFF,$1010,$2020
DATA $0103,$0383,$0703,$1F07
DATA $C0C0,$80C1,$8080,$C080
DATA $FFFF,$FEFF,$1010,$2020
DATA $0303,$0707,$0F07,$3F0F
DATA $E0E0,$C0C0,$C0C0,$8181
DATA $0000,$FFFF,$8080,$0000
DATA $0103,$0381,$0703,$1F07
DATA $FFFF,$FFFF,$FFFF,$3F7F
DATA $F8F8,$F8F8,$F8F8,$E0F0
That's because the title screen is using Foreground/Background mode, the manual says you lose the lower case characters when using it.
I changed the bitmaps definition to what you said above and this is the result. Do I have to change the titlescreen_cards as well?
Never mind, I did it myself! Please note two things:
1. The music on the title screen is just temporary test music. I don't really know how to compose chiptunes, but I'll take a stab at composing a little song. You can help me, too, if you want.
2. Once you complete level 14, the game goes wacko only because I haven't programmed anything beyond level 14. Just hit F12 in jzintv to reset the game.
Edited by atari2600land
OK, I added some more to the song. Tell me what you think.
I like it, it's cute. It reminds me of old video games like Pooyan or Mr. Do. But then, that's just it. When I play a game with a submarine hunting treasures and being stalked by an octopus, I don't think of cute music like that. It needs something that says more "adventure" and less "fairy tale."
-dZ.
