Sign in to follow this
quylein
5200 Audio mod
What is the best way to mod the audio. I have seen the schematic from the Pokey and a few pictures from resistors on the side. I've yet to see any photos or how to on just the audio side. My main goal is to have the best sound with the least amount of moving parts so to speak. Judging by the pokey end of it I'll need to make a small circuit while the resistor connection can pretty much go to the RCA jack. Any help links or photos of both mods and opinions on which to do would be helpful.
Not that this is getting much response but I have a new quandary. By the expansion port is pin 2 audio out and 3 is ground. Has anyone soldered a 1uf cap to the positive there and used pin 3 for ground? It seems that it would be cleaner then running from the resistor or pin 37 to RCAs on the expansion port. However I am new to all of this and want to know if it's been done or issues with this idea.
Just modded a 4 port and went over the schematic. I found that the mod like this won't work unless it's a two port.
