Sign in to follow this
snicklin
Using the Real Time Clock to Pause
All,
I'm trying to write some simple (I would have thought) code to pause for a little while using the real time clock.
Here it is:
.proc pause
LDA #0
STA 20 ;CLOCK_C
LDA #200
WAIT_A_BIT:
CMP 20 ;CLOCK_C
BCC WAIT_A_BIT
RTS
.endp
So I am setting the jiffy count to 0 and then waiting until 200 jiffies have passed. What I don't understand is that the code runs through immediately, but I would have thought that it would have required about 4 seconds on a PAL system.
What am I doing wrong? Probably something simple.
Is it my use of BCC?
Yes, you are correct! I did try using bcs before but it didn't work, but I think that I must have had something else in the code wrong at the time. Thank you!!
A carry check is more common after a math operation.
In this case you knew what the target was and so a BNE would have made more sense to someone reading this.
.proc pause
    LDA #0
    STA 20         ;CLOCK_C
    LDA #200
WAIT_A_BIT:
    CMP 20         ;CLOCK_C
    BNE WAIT_A_BIT
    RTS
.endp
So the alternative would have been:
.proc pause
    LDA #0
    STA 20         ;CLOCK_C
WAIT_A_BIT:
    LDA 20         ;CLOCK_C
    SEC
    SBC #200
    BCC WAIT_A_BIT
    RTS
.endp
Which is a lot more long-winded :)
And if you'd rather not write to the system clock at all:
	.proc pause
	lda 20
	clc
	adc #200
Wait_a_bit:
	cmp 20
	bne wait_a_bit
	rts
	.endp
Often a game or program will use a general "wait one frame" type subroutine.
You could do a recursive call, an with a little extra programming cater for Pal/Ntsc differences.
waitvb
  lda $14
waitvb1  cmp $14
  beq waitvb1
  rts
The PAL register in GTIA is 1 for PAL, 15 for NTSC. So, you could simply do and AND #10 (decimal). Which gives 0 for PAL, 10 dec for NTSC.
Then add to 50, giving you the proper delay for 1 second.
  lda pal
  and #$0A
  clc
  adc #50 ; get proper FPS
  tax
wait1sec
  jsr waitvb
  dex
  bne wait1sec
Thank you chaps. I've gone with FJC's option as it is good in that it doesn't write to the RTC (which may be useful later on) and because it is neat and simple.
RB's code looks good (as always!) but maybe a little overkill for what I am trying to do. It's very good to know though.
As for Wrathchild, your option looks good and the use of BNE was considered but decided against as I wasn't sure whether it could accidentally jump the number of jiffies that is looking for, forcing you to wait another 4.something seconds. Knowing a little more now, I don't think that it could.
