ydcl #1 Posted October 15, 2014 Hi all, I got someone with experience with woodwork that is going to help me build a machine, I currently own a SF II Champion Edition machine and would like to build a similar one. Any sites that offer accurate measurements and tells you what you need? I want to build the frame but use one of those already build arcade controllers, I figure it would be easier. Thanks, Yan Quote Share this post Link to post Share on other sites
retroillucid #2 Posted October 15, 2014 Hi all, I got someone with experience with woodwork that is going to help me build a machine, I currently own a SF II Champion Edition machine and would like to build a similar one. Any sites that offer accurate measurements and tells you what you need? I want to build the frame but use one of those already build arcade controllers, I figure it would be easier. Thanks, Yan Man, if you want a similar cab, here's my advice Lay down your actual Street Fighter cabinet on its side .... on a 4x8 sheet Trace the contour of your cabinet . then use a jigsaw to make the cut Then, take your (cutted) Side of your new cabinet, then lay it down on a new sheet of 4x8 Then simply route it Hope it help you 1 Quote Share this post Link to post Share on other sites
ydcl #3 Posted October 15, 2014 Man, if you want a similar cab, here's my advice Lay down your actual Street Fighter cabinet on its side .... on a 4x8 sheet Trace the contour of your cabinet . then use a jigsaw to make the cut Then, take your (cutted) Side of your new cabinet, then lay it down on a new sheet of 4x8 Then simply route it Hope it help you I got a site and downloaded some measuremnets as PDF's, I'm still deciding if I'm gonna do exactly as Street Fighter cabinet I have, or do a slighty different one. But I'm gonna use a PC with a front loader and buy one of those X controllers. Quote Share this post Link to post Share on other sites
retroillucid #4 Posted October 15, 2014 I got a site and downloaded some measuremnets as PDF's, I'm still deciding if I'm gonna do exactly as Street Fighter cabinet I have, or do a slighty different one. But I'm gonna use a PC with a front loader and buy one of those X controllers. May I suggest you to use a modded Xbox with CoinOP installed Works super well with Xarcade as well using a controller adapter (sold by Xgaming) 1 Quote Share this post Link to post Share on other sites
ydcl #5 Posted October 15, 2014 May I suggest you to use a modded Xbox with CoinOP installed Works super well with Xarcade as well using a controller adapter (sold by Xgaming) I'm currently waiting for my stuff to arrive from amazon and ebay so I can start attempting my 1st softmodding of my original xbox. Maybe if I'm successful I would do that, let's see if I can pull it off! Quote Share this post Link to post Share on other sites
retroillucid #6 Posted October 15, 2014 I'm currently waiting for my stuff to arrive from amazon and ebay so I can start attempting my 1st softmodding of my original xbox. Maybe if I'm successful I would do that, let's see if I can pull it off! Excellent , wish you good luck with it! Otherwise, there is a member here who's doing excellent job on installing CoinOp on Xbox Dwolf or something like that, can't exactly remember his name :/ Quote Share this post Link to post Share on other sites
Hyperboy #7 Posted October 15, 2014 Try johnnyblaze he mods the newer consoles, Great guy to deal with. 1 Quote Share this post Link to post Share on other sites
