snicklin
Coding Styles / Code Amnesty!
I was wondering if a few developers could release the code to some of their Assembly language projects so that I can get some coding style tips?
I think that I write relatively neat code, but there's still lots to be learnt and maybe I could make it easier to follow. Therefore I'd like to see some examples from others. Not just 1 file, but maybe several files from a project and how they all relate to one another.
If your code isn't finished, that is not important, as long as the style can be seen.
Here's an example of the style that I currently prefer. It's from the implementation of the NEW statement in Altirra BASIC.
; NEW
; Erases all program text and variables, clears the TRAP line, silences
; sound, closes IOCBs, and resets angular mode to radians.
; Not affected by new: COLOR
.proc stNew
        ldy     memlo+1
        ldx     memlo
        ;set up second argument stack pointer
        txa
        clc
        adc     #$6c
        sta     argstk2
        tya
        adc     #0
        sta     argstk2+1
        ;initialize LOMEM from MEMLO
        iny
        sty     lomem+1
        stx     lomem
        ;clear remaining tables
        ;copy LOMEM to VNTP/VNTD/VVTP/STMTAB/STMCUR/STARP/RUNSTK/MEMTOP2
        ldx     #<-16
        jsr     stClr.reset_loop
        dec     lomem+1
        ;insert byte at VNTD
        inx                     ;!! stClr leaves this at $FF
        stx     degflg          ;!! - set degflg to $00 (radians)
        stx     a2+1
        inx
        stx     a2
        ldx     #vntd
        jsr     MemAdjustTablePtrs
        ;insert three bytes at STARP
        lda     #3
        sta     a2
        ldx     #starp
        ;write sentinel into variable name table
        ldy     #3
        mva:rpl empty_program,y (vntp),y-
        ;all done
        jmp     immediateModeReset
empty_program:
        dta     $00,$00,$80,$03
.endp
You can look at my source codes of all my programs (links in signature) but I'm not sure you should inspire by them :) but it's up to you.
Thanks Phaeron and MaPa, both of your coding styles look quite neat. My impression is that only people with neat styles will submit something here, but I implore all people, no matter how tidy your code is to put something up here.
I personally can't put anything up as I want to enter my program into the ABBUC contest at some stage (some year that I manage to finish it!!). I think that releasing any code will invalidate my entry.
My style is probably most similar to Phaerons, though I use colons after the end of label names and my instructions are in uppercase (most of the time, but not consistent). Do you have one procedure per file or all of them together in one big file? I try to separate things out, though some similar procedures may get dumped together into one file.
As for yours MaPa, I took a look at your Atallax code and I tend to comment like you, after the line of code rather than before it.
One thing I do tend to do, is use the .ifdef functionality in MADs so that I can re-use code again later but with different defines. I also use a lot of 'icl' (includes) to bring in vast amounts of code from outside.
Thank you for your contributions.
As for comments I rarely use them. I'm just adding them before public release to make the source file a little more clear.
I have to use them as if I don't look at my code for a couple of days, I forget what and where everything is!
depends on timings... :D as more closer to deadlines as more "hacks" appear :D
I think the pro-coders here have better style than me... ;)
I tend to "hack" things in to see if they work and then I go back and fix them later - a pretty bad habit as it takes my time up.
However I am not working to a deadline, when it is finished, it is finished. Less pressure then.
I reckon I could have hacked a game together by now, but subsequent games wouldn't be able to re-use any code.
I learned that at least in my projects just few bits and pieces are reusable:
- Display list
- NMI handler when OS is off
- LZ4 depacking while loading in xBIOS
- RMT music
- fastmul routines
but that's it basicly... as each project is in the end too different.
That's what I used to think, but I have changed my mind now.
As long as you are working on the same kind of project (i.e. 2 games), then I think that a lot of the code can be the same.
For example, most games are similar in that they:
a) Have a title screen
b) Have a main game
c) A game over screen
d) High score entry
e) High score table display
Now it may well be that game 2 doesn't have high scores, in that case, you use the .ifdef functionality in MADS to not include those sections of code.
Then you'll probably say, "Yes, but Gauntlet is very different to Space Harrier, you need completely different dynamics in each".... , and yes, they are different.
However, if you take things up a level conceptually, you still have
a) Initialise variables
b) Set up screen
c) Process joystick / keyboard
d) Update hero characters
e) Update screen
f) Check for game / level completion, if so, jump out of main loop
g) Jump to c
Then (e) might be very different for updating the screen in Gauntlet to Space Harrier, but you use the .ifdef functionality to choose what functionality to use. You may well find that the general structure of the games underneath is very much the same.
Title screen
Load level
Set up game
Play game
Highscore (not needed for Gauntlet)
Display high score (not needed for Gauntlet)
Jump to title screen
Everything is coded from a library with lots of optional functionality.
That's just my opinion anyway, I've tried to apply what I've learnt in world of systems automation back to A8 programming, time will see if it is useful or not.
- Display list
- RMT music
- fastmul routines
And the great thing is, you can have all of those fastmul routines (and other routines) in a library, and if they don't get used in your main code, MADS doesn't compile it into the binary. How brilliant is that?
I may well be PMing you soon on something soon, I need some advice with some things you've been working on.
I did put the code of my last game here:
http://atariage.com/forums/topic/191864-pad-15-beta/page-3?do=findComment&comment=2897188
(but this was started like 20 years ago, so there are like two programming styles coexisting here x) )
Some old demos with code:
http://www.atariage.com/forums/topic/108283-more-software-sprites/
http://www.atariage.com/forums/topic/119962-why-are-my-shape-tables-flickering/page__view__findpost__p__1453933
http://www.atariage.com/forums/topic/52701-bubble-bobble/page__view__findpost__p__1260463
I would say similar to Phaeron.. with lots of comments, starting with memory maps, vars and constants definitions, then the inclusion of some standard equates and macros files, code initialization (for games something like InitSystem, InitGame, InitLevel), a short main loop with some jsr calls (read input, game logic, draw screen, screen sync..), ending with interruptions and data areas and tables (P/M's, fonts, DL's..).
Also when the programs grows, logic groups of methods or data end in their own files.
I think that every game is so different that there is almost none code for reusing. At least that's my experience in my few games. All of them was coded from scratch with no code reuse with the exception of Rolltris/Thetris. And if I would reuse some code I would do it by copying and modifying rather than trying to have some universal code.
Edited by MaPa
I hardly am in old style coding - so most of the times everything is in one large source file and I rarely use libraries or many structures. I have to change this behavior for sure.
