Sign in to follow this
Wally1
PANASONIC KXP 1150
HOW DO I CHANGE THE CPI (CHARACTERS PER INCH, OR ALSO KNOWN AS 'PITCH')?
THANKS A MILLION
WALLY
(GREAT IOLD PRINTERa)
If it is Epson compatible, try this:
Epson Escape Codes (ESC/P-83) Compatible with Epson LQ and FX series Dot Matrix printers. See the examples at the end of the table © Copyright 1995-1998 All rights reserved 07/13/1998 ASCII DEC HEX Description ASCII DEC HEX Description BEL 7 07 Beeper ESC > 62 3E Set MSB to 1 BS 8 08 Backspace ESC ? 63 3F Reassign graphics mode HT 9 09 Tab horizontally ESC @ 64 40 Initialize printer LF 10 0A Line feed ESC A 65 41 Set n/72-inch line spacing VT 11 0B Tab vertically ESC B 66 42 Set vertical tabs FF 12 0C Form feed ESC C 67 43 Set page length in lines CR 13 0D Carriage return ESC C0 67 67 Set page length in inches SO 14 0E Select double-wide (1 line) ESC D 68 44 Set horizontal tabs SI 15 0F Select condensed mode ESC E 69 45 Select emphasized mode DC1 17 11 Select printer ESC F 70 46 Cancel emphasized mode DC2 18 12 Cancel condensed mode ESC G 71 47 Select double-strike mode DC3 19 13 Deselect printer ESC H 72 48 Cancel double-strike mode DC4 20 14 Cancel double-wide (1 line) ESC J 74 4A Perform n/216-inch line feed CAN 24 18 Cancel line ESC K 75 4B Select single-density graphics DEL 127 7F Delete character ESC L 76 4C Select double-density graphics ESC SO 14 0E Select double-wide (1 line) ESC M 77 4D Select 12 cpi ESC SI 15 0F Select condensed mode ESC N 78 4E Set skip over perforation ESC EM 25 19 Cut sheet feeder on/off ESC O 79 4F Cancel skip over perforation ESC SP 32 20 Set inter character space ESC P 80 50 Select 10 cpi ESC ! 33 21 Master select ESC Q 81 51 Set right margin ESC # 35 23 Cancel MSB control ESC R 82 52 International character set ESC $ 36 24 Set absolute print position ESC S0 83 53 Select superscript mode ESC % 37 25 Select user-defined set ESC S1 83 53 Select subscript mode ESC & 38 26 Define user-defined characters ESC T 84 54 Cancel superscript/subscript ESC (- 40 28 Select Score ESC U 85 55 Turn unidirectional mode on/off ESC * 42 2A Select graphics mode ESC W 87 57 Turn double-wide on/off ESC + 43 2B Set n/360-inch Line Spacing ESC Y 89 59 High-speed dbl-density graphics ESC - 45 2D Turn underlining on/off ESC Z 90 5A Quadruple-density graphics ESC / 47 2F Select vertical tab channel ESC \ 92 5C Retrieve relative position ESC 0 48 30 Select 1/8-inch line spacing ESC a 97 61 Select justification ESC 2 50 32 Select 1/6-inch line spacing ESC b 98 62 Set vertical tabs in channels ESC 3 51 33 Select n/216-inch line spacing ESC g 103 67 Select 15 CPI ESC 4 52 34 Select italic mode ESC k 107 6B Select typestyle family ESC 5 53 35 Cancel italic mode ESC l 108 6C Set left margin ESC 6 54 36 Enable printable characters ESC p 112 70 Turn proportional mode on/off ESC 7 55 37 Enable upper control codes ESC q 113 71 Select character style ESC : 58 3A Copy ROM into RAM ESC t 116 74 Select character table ESC < 60 3C Unidirectional mode (1 line) ESC w 119 77 Turn double-high on/off ESC = 61 3D Set MSB to 0 ESC x 120 78 Select NLQ or draft NOTE!! The ESC character is DEC 027 or HEX 1B. Use the above table to determine which character code (Dec or Hex) that should be sent after the ESC character.
EXAMPLE. To set the "emphasized" mode in the printer, either of the following character strings may be sent.
ASCII…..ESC….E
Decimal…027…..069
Hex……..1B……45
