Sign in to follow this
Steve Mynott
Disk based DOS?
What disk based DOSes are people using?
I guess the best is probably Spartados X but as far as I know that's cartridge only?
Earlier versions of Spartados or BW-DOS or even OSS/A++ or DOSXL?
As for disk based DOS i have used primarily SpartaDOS 3.2 and Atari DOS 2.5. Between the two you can do pretty much everything. Before I got into SpartaDOS I had also used SmartDOS (which is similar to Atari DOS) for double density support. I think the double density multi boot disks I used were created using SmartDOS for the most part.
If you have a device capable of running it go with SpartaDOS X.
