Altirra crushes
yossibnv
I am trying to run assemly code on altirra 2.5 emulator and it crushes
i use assembler edtitor rom for the assembler programs
following the stack dump :
CPU: Illegal instruction hit: 0056
(8158: 14, 30) A=10 X=00 Y=00 S=FF P=30 ( ) 0055: 02 COLCRS bad
i've tried differnt cpu & memory setting and it wont help
i use 32 bit won 7 os .
10X
In CPU options you'd want to allow illegal instructions and have stop on BRK disabled.
Prettywell any instruction with low nybble value 2 and some value C will hang a 6502.
Remember with the AsmEd cart, one of the most annoying features is that you have to use BRK to exit your program when running from the debugger. An RTS won't return to the debugger properly and can cause a crash sometimes.
Danwinslow,thanks for reply,sorry i am a new member here and i am probably on a learning curve period.
i'll move my next posts to the 8 bit programming forum, but since i've got a reply i feel like obligated for responding :
Raybags: i've tried to run a simple assembly code:
10 *=$1000
20 LDA #1000
30 END
then type BUG
and command : G 1000 at the debug prompt ,then appears the crush window as described above
i've also tried setting the cpu to the parameters you have suggested and it wont help, i still get this annoying crush win.
  • 4 weeks later...
