Sign in to follow this
humeur
Catalog of multiple disk
Try Catlib, Jean Louis. That one will make a master catalog of as many disks as you feed it, and gives you the option of adding comments for each program.
Yes I have lost, I want to catalog my floppy images in DSK format in my PC. I never know Catilb however. Thank you.
Jean-Louis
You can also use my Java-based TIImageTool in its command shell mode to create a directory listing which you can save in a file. In case you are using Linux or run a shell with cygwin, you can do something like this:
for image in *.dsk
do
   java -jar tiimagetool.jar commandshell dir $image >> completedir.txt
done
What was it that did not work? Did you try TIImageTool? Note that the lines showed above actually invoke it with one image at a time and that the for-loop iterates through the file names.
English and me in writing this is not easy.
I have several disk image cataloging
With the command that you give is for an image at a time and must make a loop
We can not do the full image of a pass directory catalog
I work on Xp
thank Jean Louis
Edited by humeur
