Christos #1 Posted December 6, 2014 (edited) Don't expect anything too interesting.. EDIT: Also, download the other file... this one is.. terrible DLA.ABS Edited December 16, 2014 by Christos 1 Quote Share this post Link to post Share on other sites
ggn #2 Posted December 6, 2014 (edited) (although I think that in the future it'll suffice for people to upload the source code instead of a binary!) Edited December 6, 2014 by ggn 2 Quote Share this post Link to post Share on other sites
+CyranoJ #3 Posted December 7, 2014 (although I think that in the future it'll suffice for people to upload the source code instead of a binary!) Actually, I'm a bit fan of both (because I'm super-lazy) 1 Quote Share this post Link to post Share on other sites
Christos #4 Posted December 10, 2014 So if you have the time and you want to test your system or virtualjag for long term stability here's version 2.0 Many thanks to Reboot for adding PLOT and COLOUR and helping with the random number generator. Also note that though some optimizations for speed have been made, this is a simulation and so it takes a long time on the Jaguar. Also note that for something interesting to appear, at least 300 particles need to appear. I've left the debug prints commented out, so if you want to see what's going on, all you need to do is remove ther REM commands. Also two subroutines have been commented as well. If you want check them out as well. Anyway, it's not supposed to be too interesting to a non-Mathematician/non-Physicist. If you know ways to improve the speed, well... Patches Welcome 1 NUM=360*RND(0) 2 PRINT "MADE WITH RAPTOR AND RBASIC." 3 PRINT "SIMULATION OF" 4 PRINT "DIFFUSION LIMITED AGGREGATION" 5 FOR I=1 TO 10000 6 NEXT I 7 CLS 8 CLEAR 10 COLOUR(20):PLOT(160,100) 15 COUNTER=0 20 DIM SCREEN(320,200) 25 SCREEN(160,100)=1 30 REM GOSUB 500 31 REM GOSUB 400 35 XI=0:YI=0 40 GOSUB 100 50 GOSUB 205 60 GOTO 60 90 REM PROCEDURE FEED 100 SETCUR(0,0):PRINT "PARTICLES: ";COUNTER 110 FI=360*NUM 112 COLOUR(10) 115 IF COUNTER<=20 THEN R=5 116 IF COUNTER>20 AND COUNTER<=100 THEN R=15 117 IF COUNTER>100 AND COUNTER<=300 THEN R=30 118 IF COUNTER>300 AND COUNTER<=1000 THEN R=35 119 IF COUNTER>1000 THEN R=55 120 XI=160+INT(R*COS(360*FI)):YI=100+INT(R*SIN(360*FI)) 130 IF SCREEN(XI,YI)=1 THEN NUM=RND(0):GOTO 100:REM SETCUR(0,2):PRINT "LOOP" 140 IF SCREEN(XI-1,YI-1)=1 OR SCREEN(XI-1,YI)=1 OR SCREEN(XI-1,YI+1)=1 OR SCREEN(XI,YI-1)=1 OR SCREEN(XI,YI+1)=1 OR SCREEN(XI+1,YI-1)=1 OR SCREEN(XI+1,YI)=1 OR SCREEN(XI+1,YI+1)=1 THEN NUM=RND(0):GOTO 100:REM SETCUR(0,2):PRINT "LOOP" 150 RETURN 200 REM PROCEDURE FRACTAL 205 HZ=0 210 DO 220 NUM=RND(0) 221 IF NUM<=0.17 THEN N=-1 222 IF NUM>0.17 AND NUM<=0.33 THEN N=0 223 IF NUM>0.33 AND NUM<=0.5 THEN N=1 224 IF NUM>0.5 AND NUM<=0.67 THEN M=-1 225 IF NUM>0.67 AND NUM<=0.84 THEN M=0 226 IF NUM>0.84 AND NUM<=1 THEN M=1 230 IF ABS(XI-160)>2*R OR ABS(XI-160)>75 THEN N=5*N 240 XI=XI+N:REM PLOT(XI,YI) 245 IF XI<5 THEN GOSUB 100:REM SETCUR(0,2):PRINT "LEFTX";HZ 260 IF XI>315 THEN GOSUB 100:REM SETCUR(0,2):PRINT "LEFTX";HZ 270 REM IF SCREEN(XI,YI)=1 THEN GOSUB 100:REM SETCUR(0,2):PRINT "LEFTM" 280 IF SCREEN(XI-1,YI-1)=1 OR SCREEN(XI-1,YI)=1 OR SCREEN(XI-1,YI+1)=1 OR SCREEN(XI,YI-1)=1 OR SCREEN(XI,YI+1)=1 OR SCREEN(XI+1,YI-1)=1 OR SCREEN(XI+1,YI)=1 OR SCREEN(XI+1,YI+1)=1 THEN SCREEN(XI,YI)=1:COLOUR(R):PLOT(XI,YI):INC COUNTER:GOSUB 100 290 300 IF ABS(YI-100)>2*R OR ABS(YI-100)>75 THEN M=5*M 320 YI=YI+M:REM PLOT(XI,YI) 330 IF YI<5 THEN GOSUB 100:REM SETCUR(0,2):PRINT "LEFTY";HZ 340 IF YI>195 THEN GOSUB 100:REM SETCUR(0,2):PRINT "LEFTY";HZ 350 IF SCREEN(XI-1,YI-1)=1 OR SCREEN(XI-1,YI)=1 OR SCREEN(XI-1,YI+1)=1 OR SCREEN(XI,YI-1)=1 OR SCREEN(XI,YI+1)=1 OR SCREEN(XI+1,YI-1)=1 OR SCREEN(XI+1,YI)=1 OR SCREEN(XI+1,YI+1)=1 THEN SCREEN(XI,YI)=1:COLOUR(R):PLOT(XI,YI):INC COUNTER:GOSUB 100 360 INC HZ 370 LOOP UNTIL COUNTER=3600 380 RETURN 400 FOR i=0 TO 179 410 x1=160+COS(90+i)*10 420 y1=100+SIN(90+i)*10 430 x2=160-COS(90+i)*10 440 y2=y1 450 FOR j=x1 TO x2 460 SCREEN(j,y1)=1 465 COLOUR(10):PLOT(j,y1) 470 NEXT j 480 NEXT i 490 RETURN 500 FOR I=1 TO 15 510 FOR J=1 TO 15 520 X=INT(300*RND(0)) 530 Y=INT(190*RND(0)) 540 SCREEN(X,Y)=1:PLOT(X,Y) 550 NEXT J 560 NEXT I 570 RETURN DLA2.ABS 5 Quote Share this post Link to post Share on other sites
Christos #5 Posted December 10, 2014 (edited) And here's the Henon Strange Attractor. Strange attractors are very interesting both as physical phenomena and as demonstrations . I found this online, and it only took 1 minute to get it running with rbasic. Including the time to run the build script. 1000 PRINT "Quite BASIC Math Project" 1010 PRINT "The Henon Map" 1015 PRINT "PORTED TO RBASIC" 1016 PRINT "USING RAPTOR & U235SE" 1017 FOR J=1 TO 3000:NEXT J 1020 CLS 2000 REM Set the parameters A and B 2010 LET A = 1.4 2020 LET B = 0.3 2030 REM Set initial values for X and Y 2040 LET X = 0.5 2050 LET Y = 0.5 2060 REM Initialize the iteration counter I 2070 LET I = 0 3000 REM Main iteration loop. Start plotting after 25 iterations 3010 FOR I = 1 TO 10000 3020 LET Z = X 3030 LET X = Y + 1 - A * X * X 3040 LET Y = B * Z 3050 IF I>25 THEN COLOUR(20):PLOT(36*(X + 1.4),100*(Y + 0.5)) 3060 LET I = I + 1 3070 NEXT I HENON.ABS Edited December 10, 2014 by Christos 4 Quote Share this post Link to post Share on other sites
F.L #6 Posted December 11, 2014 i have tried it, and the rally game too good work ! do you think you will add later a function to draw tiles or something like this ? in 2012 i have done a remake in basic of barbarian (an atari st game of the 80's) and it would be great to port it on jaguar ! see ya Quote Share this post Link to post Share on other sites
+CyranoJ #7 Posted December 11, 2014 It can already access the Jaguar hardware to display objects of any size. I will later add the RAPTOR tile engine to BASIC. Check out the RAPTOR API (another subforum here in programming) for the details on the RAPTOR API. Quote Share this post Link to post Share on other sites
+CyranoJ #8 Posted December 11, 2014 Anyway, it's not supposed to be too interesting to a non-Mathematician/non-Physicist. If you know ways to improve the speed, well... Patches Welcome Nice work - as for the speed.... I've been working on that Expect a nice speed boost in 0.1.7 - EhBASIC was clearly built for portability (and rightly so!) but there are many places the inner loops can be optimized... which is what I've been working on. Quote Share this post Link to post Share on other sites
ovalbugmann #9 Posted January 26, 2015 Thanks for the binary forms of game/demo sources as I forgot how to compile after setting up a Jagdev environment, lol, I think I'll go grab Belboz's dev environment files now. Quote Share this post Link to post Share on other sites
Christos #10 Posted January 26, 2015 (edited) Thanks for the binary forms of game/demo sources as I forgot how to compile after setting up a Jagdev environment, lol, I think I'll go grab Belboz's dev environment files now. And that will undoubtedly be 0% help. With the recent versions of RBASIC all you need to do is put the .bas file in its own project folder and type build dla et voila! Edited January 26, 2015 by Christos 2 Quote Share this post Link to post Share on other sites
