wixomhead Posted December 8, 2014 Share Posted December 8, 2014 Return or try to fix?Makes no difference if game is inserted or not.I removed/re installed RCA cable onto the mother board twice.I am using $2 female RCA to Coax connector into antenna jack.Advice appreciated! Link to vid: http://youtu.be/wmpS2_PiNWw Quote Link to comment Share on other sites More sharing options...
phattyboombatty Posted December 9, 2014 Share Posted December 9, 2014 Return or try to fix? Makes no difference if game is inserted or not. Looks like a cart data/pins-connection issue. How many games have you tried? The "boop-beep" noises and vertical lines happen on every Atari when there's no game inserted. Clean the pins on your test cart if you've only been using one. If you've already done that, then clean the pins in the cart slot. I like to use electronics cleaner, sprayed onto a thin piece of cardboard and folded in half. Insert into slot. Repeat. See black stuff. Wait til dry. Speed dry with compressed air. Your RF signal is clearly transmitting there, so that's not the issue. Quote Link to comment Share on other sites More sharing options...
chas10e Posted December 9, 2014 Share Posted December 9, 2014 (edited) how many games do you have ? the video shows no game in slot & that would be normal most likely dirty cart (cartridge) http://atariage.com/howto/clean_cartridges.html EDIT: not mentioned in article ... the higher percentage rubbing alcohol is what you want !!! 90% or higher what game(s) do you have some take more vigorous cleaning than others & a slight possibility you just have a bad cart as well Edited December 9, 2014 by chas10e Quote Link to comment Share on other sites More sharing options...
Mef Posted December 10, 2014 Share Posted December 10, 2014 (edited) Might be dirty connector, sure, but... If it just happened suddenly one day and you didn't have trouble before (didn't need to wiggle/reposition the cart and the contacts look clean), then perhaps your cartridge connector is just not making physical contact on one or more address lines? Try looking into the connector if the pins aren't bent and are uniformly aligned. If everything looks fine, I'd try disassembling the console and running the soldering iron along the solder joints between connector and the motherboard (after applying a little bit of flux there). You might check for continuity between the pins and the motherboard first with a simple multi-meter, if you have one. Edited December 10, 2014 by Mef Quote Link to comment Share on other sites More sharing options...
wixomhead Posted December 11, 2014 Author Share Posted December 11, 2014 Everything is all set. Well mostly. I just purchased this 2600 on ebay and it came with one combat cartridge. I was not smart ...well, educated enough to understand that when the console is switched on with no cartridge, the screen can display a variety of different lines/beeps etc. or just stay black. Inserting the combat cart did nothing, hence my cncern with the console. But when my box of nine other games arrived.........they all worked perf! So I need to clean combat. And brush up on my Defender and Donkey Kong skills. And THANK you guys/this forum for your efforts to help me and your fast responses! 1 Quote Link to comment Share on other sites More sharing options...
chas10e Posted December 11, 2014 Share Posted December 11, 2014 congrats on your new toy Combat is great 2 player fun .... I've been in the habit of cleaning carts as they come in especially ones with the open PCB like Donkey Kong Quote Link to comment Share on other sites More sharing options...
gilsaluki Posted December 12, 2014 Share Posted December 12, 2014 No cart, no video, no play, NO FUN. Enjoy. The 2600 is the coolest thing EVER! Quote Link to comment Share on other sites More sharing options...
