+Larry #251 Posted October 22, 2019 OK, I've checked my stock of upgrades. I have two of the Ram 320XE. Both say Rev 3. One says batch 2 and the other batch 1. The pcb's are a bit different. Neither have an ECI pass-through. It appears that the screws holding the shells together are under the labels, so no pictures of the pcbs are possible. I'll sell either or both of these. PM an offer if interested. I also have two of the earlier Ram 320XL. This is interesting because you can map the base 16K or 64K in or out. Check the original thread(s). The negative thing about these is that they covered up the PBI, but if one uses an SDrive, etc. no big deal. Same deal, PM an offer if interested. (PayPal, of course.) -Larry 2 Quote Share this post Link to post Share on other sites
atari65xenajm #252 Posted October 22, 2019 (edited) 1 hour ago, Larry said: OK, I've checked my stock of upgrades. I have two of the Ram 320XE. Both say Rev 3. One says batch 2 and the other batch 1. The pcb's are a bit different. Neither have an ECI pass-through. It appears that the screws holding the shells together are under the labels, so no pictures of the pcbs are possible. I'll sell either or both of these. PM an offer if interested. I also have two of the earlier Ram 320XL. This is interesting because you can map the base 16K or 64K in or out. Check the original thread(s). The negative thing about these is that they covered up the PBI, but if one uses an SDrive, etc. no big deal. Same deal, PM an offer if interested. (PayPal, of course.) -Larry PM sent (for batch 1) Edited October 22, 2019 by atari65xenajm added a clarification. Quote Share this post Link to post Share on other sites
+Larry #253 Posted October 22, 2019 I am attempting to test the Ram XE units. I can't remember how to read the dip switch diagrams. Does the little white spot on the diagram indicate the position of the dip switch, or the black at the other end? I also can't find an explanation about the "requires modification" note on the batch 2 unit for the 576 kb. Is there another thread I missed? Quote Share this post Link to post Share on other sites
xrbrevin #254 Posted October 22, 2019 hmm.. i seem to recall that the diagram read in reverse on this device... mine is packed away atm so unable to test it but try the reverse, it might apply to yours too! Quote Share this post Link to post Share on other sites
+Larry #255 Posted October 23, 2019 Here's what I've found (and at this point 5 years later, I can't say that I understand all that is shown in the docs): Switches 1....2....3 (reading from the label) 1. Down Down Down shows 64K on XRam (64 base + 64) 2. Up Down Down shows 256K on Xram (64 + 256) 3. Down Up Down shows 64K on XRam (64 + 64) 4. Up Up Down shows 512K on XRam (64 + 512) Note that in the above that the remap is set to OFF. Both of the Ram 320XE units show the same results, so I have to believe that they both work exactly as when I got them several years ago. I have not been able to verify some of the remap=ON as mentioned in Ctirad's docs. I have a totally stock 130XE that performs perfectly normally when remap is OFF or when the Ram 320XE is not connected. The issue is the remap=ON setting. If I set the remap to ON, the machine will either display a black screen or stop in the middle of the boot. I have a gut feel this is an NTSC issue. But I have no PAL machines to test. Could someone else in NTSC-land test this. Also, could someone with a PAL machine test it. Here is the easiest-to-understand map of the settings: 1 Quote Share this post Link to post Share on other sites
Lastic #256 Posted November 7, 2019 @Larry mine arrived today, and it works like a charm. Thanks once again and also a big thank you for packaging it so good ! 1 Quote Share this post Link to post Share on other sites
+Larry #257 Posted November 8, 2019 Great! Hope you enjoy it for a long, long time! -Larry 1 Quote Share this post Link to post Share on other sites
orgi666 #258 Posted December 7, 2019 Hey guys, i would really need this one, is there anyone willing to sell? I have 800XE and two left hads, any homemade mod is too difficult. Quote Share this post Link to post Share on other sites
ZuluGula #259 Posted December 7, 2019 I think Sys-Check can do the same and more. 2 Quote Share this post Link to post Share on other sites
mimo #260 Posted December 10, 2019 On 12/7/2019 at 2:06 PM, ZuluGula said: I think Sys-Check can do the same and more. Yep, just get a sys-check, no fancy case but it's pretty much your only option at the moment Quote Share this post Link to post Share on other sites
xrbrevin #261 Posted December 10, 2019 i dont think a case is realistically possible as the PCB sits right up to the case of the XL. maybe for an XE but then it wouldnt be useable in an XL Quote Share this post Link to post Share on other sites
xrbrevin #262 Posted December 10, 2019 the above post should be in the sys-check thread, apologies Quote Share this post Link to post Share on other sites
Drummerboycr #263 Posted January 15, 2020 Hello, This memory upgrade will work for Atari 800XL series without soldering? Thanks Quote Share this post Link to post Share on other sites
pseudografx #264 Posted January 15, 2020 (edited) The XE version can only be used with XE machines - 130XE's, 800XE's and some 65XE's (those with the full ECI connector at the rear side). The XL uses a different connector but there was a version of this expansion suitable for XL machines. And yes, these expansions can be used to expand your memory without any soldering. Edited January 15, 2020 by pseudografx Quote Share this post Link to post Share on other sites
xrbrevin #265 Posted January 15, 2020 4 hours ago, Drummerboycr said: Hello, This memory upgrade will work for Atari 800XL series without soldering? Thanks sys-check II is a solderless memory upgrade: Quote Share this post Link to post Share on other sites
Sinjinhawke #266 Posted February 28, 2020 Late to the party Did anyone else ever make a RAM cart? Any planned ones? Nervous about opening my only fully functional Atari to mess around in it with a soldering iron. Quote Share this post Link to post Share on other sites
manterola #267 Posted February 28, 2020 Only ready available, syscheck. But it does much more than just a RAM expansion. http://www.van-radecke.de/STUFF/tfhh_HW_info.pdf Quote Share this post Link to post Share on other sites
Sinjinhawke #268 Posted February 28, 2020 6 hours ago, manterola said: Only ready available, syscheck. But it does much more than just a RAM expansion. http://www.van-radecke.de/STUFF/tfhh_HW_info.pdf Thank you. This looks great. I think I think this looks like a great gift for me. Quote Share this post Link to post Share on other sites
ChaoticBiker #269 Posted May 18, 2020 Hi All, I'm new to this forum (but not new to Atari) and it would appear I am late to the party. Had a number of Atari's over the past 30 years, and recently decided to downsize my collection and focus on getting most use of what I have. So I am currently left with a 65XE and a 800XE, have the SIO2SD drive/tape emulator, and also some other peripherals (1050, 1010, XC12 etc). I also had a 130XE but sold it as it had a faulty video chip (display was b&w only). So looking for RAM extension, and was pretty much set at buying everything in order to solder the chips on the mainboard and expand to 320kb. Then i took one last plunge into the internets and here I am - an old thread with RAM cards ready made that are not that much more expensive than doing it myself. So my question is as follows - how do I get my hands on one? I understand the OP is no longer responding. Is anyone selling theirs? Is anyone making anything that would fit a 65xe/800xe (both of mine have ECI ports)? Or failing this, does anyone sell ready kits for onboard upgrades? If not, is there any place I could get all the chips, capacitors, resistors etc. instead of buying everything separately off ebay? Apologies for so many questions from the start, hoping someone is still out there willing to answer. Quote Share this post Link to post Share on other sites
+toddtmw #270 Posted May 18, 2020 I highly recommend @tf_hh's Syscheck 2.2. It does so much more than expand the memory. It plugs into the expansion port on an XL or XE (There are versions for each one, and one that works with both.) I have one and love how it works. It is pretty much plug and play. Just have to run a wire to the joystick port for power. All information on that, and on other cool upgrades for 8-bit Atari stuff can be found here: http://www.van-radecke.de/STUFF/tfhh_HW_info.pdf The thread on the syscheck is here: -Todd 2 Quote Share this post Link to post Share on other sites
MrFish #271 Posted May 18, 2020 (edited) Yeah, if there's ever a chance to produce these again, I'd love to get 1 or 2. Big difference between a cased product and a board hanging out the back of your machine. Edited May 18, 2020 by MrFish 2 Quote Share this post Link to post Share on other sites
Mathy #272 Posted May 18, 2020 (edited) Hello ChaoticBiker Open up your XE's to check if they use two or eight RAM chips. You'll probably find that the motherboard says "130XE" and that it looks like half the RAM chips are missing. Easiest way to upgrade than is to add the missing RAMs and the CO25953 (or the alternative) to get 128kB of RAM, fully 130XE compatible. Sincerely Mathy (who upgraded both his 65XE and his 800XE to 128kB years ago) Edited May 18, 2020 by Mathy Quote Share this post Link to post Share on other sites
tane #273 Posted May 18, 2020 12 minutes ago, Mathy said: Easiest way to upgrade than is to add the missing RAMs and the CO25953 (or the alternative) to get 128kB of RAM, fully 130XE compatible. Whereas it technically works, is not a Ready-To-Go solution. It would be helpful if someone can sell those replacements for the Emmu CO25953 (ex: @MacRorie ). Quote Share this post Link to post Share on other sites
manterola #274 Posted May 18, 2020 (edited) I got 3 EMMUs (CO25953) from an UK seller in Ebay, at good price. Probably still around. That was my first hardware modification ever to any of my Ataris. It is very straight forward and you get a 130XE with 65XE or 800XE badge. That simple upgrade allowed me to play Bosconian (with voice samples), Stunt car racer, use sector copiers (copy diskettes in 1 pass),etc. Now if you have a 65XE with ECI , getting SysCheck is also pretty nice, since you don't need to open the computer and solder anything. Edit: I found this link. I don't know why is not showing in other ebay sites... even when the seller is based in UK. https://www.ebay.pl/itm/NEW-Atari-computer-16-DIP-IC-130XE-65XE-65-130-XE-C25953-20-EMMU-memory-IC-chip-/152097265933 Edited May 18, 2020 by manterola found a link Quote Share this post Link to post Share on other sites
ChaoticBiker #275 Posted May 18, 2020 11 minutes ago, Mathy said: Hello ChaoticBiker Open up your XE's to check if they use two or eight RAM chips. You'll probably find that the motherboard says "130XE" and that it looks like half the RAM chips are missing. Easiest way to upgrade than is to add the missing RAMs and the CO25953 (or the alternative) to get 128kB of RAM, fully 130XE compatible. Sincerely Mathy (who upgraded both his 65XE and his 800XE to 128kB years ago) Hi Mathy, Thank you for the response. Thank all others for suggestions, the syscheck one is an interesting alternative (though still would prefer something with a case ) As mentioned previously, I did have a 130XE with a faulty graphics chip, I now regret selling it as should've just swapped the chip with one of my other ataris! I had 5 ataris back then (amongst a ton of other computers), now I'm down to two as over the last two years I have pretty much decimated my collection. Both my 65XE and 800XE have 8 chips RAM, and both have the space for extra chips and this indeed the way I'll do one of the Ataris (probably the 800XE). Problem is, original Atari MMU is near impossible to obtain nowadays and the GAL chip needs programmed which unforunately I no longer have the hardware to do that. Not sure if there's any place in UK or EU that ships pre-programmed GAL chips? I'm not shy to do a bit of soldering though looking at other options as well. Even if I order the syscheck for one atari I'll probably still have a go with soldering on the other. So the big question - is there anyplace I can get the GAL chip programmed up front? Quote Share this post Link to post Share on other sites
