Sign in to follow this
Christos
How to put an image on the screen.
Well, I have some problem understanding on how to put an image on the screen. Though I've edited the rapinit file to put my image there, it wouldn't work. Can anyone explain how raptor lists work? (I've done the necessary RTFM).
OK,
so, here's the BASIC:
100 REM IMAGE
120 CLS
200 RSETLIST(0)
210 RUPDALL(0)
300 GOTO 300
We also need to edit the _RAPINIT.S file to add the object (image) to display:
; Image
dc.l 4 ; (REPEAT COUNTER) ; Create this many objects of this type (or 1 for a single object)
dc.l is_active ; sprite_active ; sprite active flag
dc.w 20,0 ; sprite_x ; 16.16 x value to position at
dc.w 20,0 ; sprite_y ; 16.16 y value to position at
dc.w 0,0 ; sprite_xadd ; 16.16 x addition for sprite movement
dc.w 0,0 ; sprite_yadd ; 16.16 y addition for sprite movement
dc.l 320 ; sprite_width ; width of sprite (in pixels)
dc.l 200 ; sprite_height ; height of sprite (in pixels)
dc.l is_normal ; sprite_flip ; flag for mirroring data left<>right
dc.l 0 ; sprite_coffx ; x offset from center for collision box center
dc.l 0 ; sprite_coffy ; y offset from center for collision box center
dc.l 16/2 ; sprite_hbox ; width of collision box
dc.l 24/2 ; sprite_vbox ; height of collision box
dc.l BMP_IMAGE ; sprite_gfxbase ; start of bitmap data
dc.l 16 ; (BIT DEPTH) ; bitmap depth (1/2/4/8/16/24)
dc.l is_RGB ; (CRY/RGB) ; bitmap GFX type
dc.l is_trans ; (TRANSPARENCY) ; bitmap TRANS flag
dc.l 320*200*2 ; sprite_framesz ; size per frame in bytes of sprite data
dc.l 320*200 ; sprite_bytewid ; width in bytes of one line of sprite data
dc.l 0 ; sprite_animspd ; frame delay between animation changes
dc.l 0 ; sprite_maxframe ; number of frames in animation chain
dc.l ani_rept ; sprite_animloop ; repeat or play once
dc.l edge_wrap ; sprite_wrap ; wrap on screen exit, or remove
dc.l spr_inf ; sprite_timer ; frames sprite is active for (or spr_inf)
dc.l spr_linear ; sprite_track ; use 16.16 xadd/yadd or point to 16.16 x/y table
dc.l 0 ; sprite_tracktop ; pointer to loop point in track table (if used)
dc.l spr_unscale ; sprite_scaled ; flag for scaleable object
dc.l %00100000 ; sprite_scale_x ; x scale factor (if scaled)
dc.l %00100000 ; sprite_scale_y ; y scale factor (if scaled)
dc.l -1 ; sprite_was_hit ; initially flagged as not hit
dc.l -1 ; sprite_CLUT ; no_CLUT (8/16/24 bit) or CLUT (1/2/4 bit)
dc.l can_hit ; sprite_colchk ; if sprite can collide with another
dc.l cd_keep ; sprite_remhit ; flag to remove (or keep) on collision
dc.l single ; sprite_bboxlink ; single for normal bounding box, else pointer to table
dc.l 1 ; sprite_hitpoint ; Hitpoints before death
dc.l 2 ; sprite_damage ; Hitpoints deducted from target
dc.l 320*2 ; sprite_gwidth ; GFX width (of data)
and the _RAPAPP.S file to include the actual asset (the image)
BMP_IMAGE: incbin "ASSETS/GFX/LOGO.TGA"
and finally, add the asset to the auto-convert list:
;; Convert List
RAPTOR_autoconvert_list: dc.l BMP_IMAGE,-1
dc.l -1,-1
