ricortes #26 Posted December 27, 2014 Should ask someone from NJ to confirm. I may have history wrong, as I recall we were all going to fiber optics and digital for phone service, then cell phones hit. Information I have is six months after Katrina, the copper/fiber lines were still out in NJ. Speculation at the time was phone companies were all deliberately dragging their feet to force people into using cell phones: Better profit margins, lower up keep, lower labor costs. I know my land line phone service in the hills above Los Gatos is absolutely abysmal. It was better in the 80s then it is now. My Mom still has a dial type phone. It was funny to see my grand children Xmas trying to use it, talking into it like Scotty did the mouse in Star Trek "The Journey Home." Saying all this just to give a heads up of what is obvious to all. Telenet will be around for a while, land lines I'm not so sure. Fine to use dial up for now but may need another solution in the near future. Maybe BT to cell dialer for toll free calls or something and a VOIP digital tolerant connection. Quote Share this post Link to post Share on other sites
Dan Iacovelli #27 Posted December 28, 2014 land lines are staring to decline now that more people use thier cells as thier primary phones. I don't mind telneting to bbs. Quote Share this post Link to post Share on other sites
tschak909 #28 Posted December 28, 2014 This is what I get for putting my BBS project on hold... I guess i'd better get back on it.. -Thom Quote Share this post Link to post Share on other sites
kogden #29 Posted December 28, 2014 An AtariAge BBS would be cool! As far as connectivity..... I've had good luck with an 850 + Precidia iPocket232 setup. I have an SX212 as well but I haven't bothered getting a power supply for it since I don't have a phone line at the moment. Quote Share this post Link to post Share on other sites
+David_P #30 Posted December 28, 2014 Anyone with experience with any of the low-cost Chinese RS232-Ethernet adapters? At under $20 shipped, they would be a nice alternative to the pricier options out there. One example: eBay Auction -- Item Number: 291229605057 Manual at: http://www.lillyelectronics.com/download/USR-TCP232-T24_en.pdf And perhaps a better option (that could be powered by SIO) at: eBay Auction -- Item Number: 261695282580 Quote Share this post Link to post Share on other sites
Fletch #31 Posted December 28, 2014 (edited) An AtariAge BBS would be cool! As far as connectivity..... I've had good luck with an 850 + Precidia iPocket232 setup. I have an SX212 as well but I haven't bothered getting a power supply for it since I don't have a phone line at the moment. The power supply for the SX212 is the same one as the Atari VCS (2600). If you have a VCS you have the proper power adapter. Edited December 28, 2014 by Fletch Quote Share this post Link to post Share on other sites
kogden #32 Posted December 30, 2014 Anyone with experience with any of the low-cost Chinese RS232-Ethernet adapters? At under $20 shipped, they would be a nice alternative to the pricier options out there. I've looked at some of those. The ones that support the AT command set might be usable. If they support real RS232, an 850 could probably be used. If they are TTL serial, you might be able to build something easily but you'd have to put a little effort into it. Maybe build something like an RVerter but without the MAX232. I ended up going with the Precidia iPocket232 simply because I ended up with a couple for free and I already had an 850 I scored for $20 on eBay months prior itching for something to do. Quote Share this post Link to post Share on other sites
+David_P #33 Posted December 30, 2014 I just gave in to temptation and ordered a TTL model. There will be a need to make a slight control circuit to enter "Configuration Mode" - I'm thinking I can use the cassette control line for that - and a need for a bit of software to send the config string (twenty four bytes which includes the IP address and port for the device and the IP address and port for the destination). With that up and running it should be able to use an R:Verter handler and a term program (famous last words). (Manual for the model I bought is at http://www.tcp232.net/download/USR-TCP232-T-EN.pdf) ...step 2 will be to figure out "TCP Server mode"... Given work, work and school right now, I figure I should get around to it sometime in 2018 or so... Quote Share this post Link to post Share on other sites
Omega-TI #34 Posted December 30, 2014 << THIS HERE >> is one of the more popular devices in use. The link has information on the device, sources to obtain one, links to active BBS systems as well as other stuff. It's one alternative you might want to investigate. Quote Share this post Link to post Share on other sites
kogden #35 Posted December 30, 2014 The UDS10 is pretty common and can be had cheap nowadays. In actual field use these days I use a LOT of the iPocket232 and SysTech devices. We use them in our stores a lot for legacy POS gear, money order machines, light control boxes, etc. One caveat with an awful lot of these devices is that they don't support DNS but that's not really a showstopper. Quote Share this post Link to post Share on other sites
Marius #36 Posted December 30, 2014 The UDS10 is pretty common and can be had cheap nowadays. In actual field use these days I use a LOT of the iPocket232 and SysTech devices. We use them in our stores a lot for legacy POS gear, money order machines, light control boxes, etc. One caveat with an awful lot of these devices is that they don't support DNS but that's not really a showstopper. Another big disadvantage of the UDS10, which is imho unforgivable, is that it does not do a 100% compatible telnet handshake. This results in incompatible terminal telnet applications giving double echo on screen, without the ability of switching that off. The MSS100 needs a nullmodem cable to connect to your atari, in stead of a regular rs232 cable, but does not has this issue and it does support DNS as well. 1 Quote Share this post Link to post Share on other sites
kogden #37 Posted December 31, 2014 Yeah, to be fair, the UDS10 is really old by today's standards which is why they are so cheap now. They were insanely expensive when they were new. IIRC they were one of the first compact single-port device server/terminal server you could get. I've been tempted to try to write a few Atari-side apps that implement a few application layer protocols like FTP and DNS that kick the iPocket into raw socket mode. At that point it almost acts like a real network interface but you only have to implement application layer protocol and let the device do the heavy TCP/IP lifting. There's a lot of additional functionality besides modem emulation we could squeeze out of these devices but I don't know how consistent any of it is across manufacturers. Quote Share this post Link to post Share on other sites
+doctorclu #38 Posted January 3, 2015 Was checking Atari 8-bit BBS's tonight and was wondering if we have an Atariage to add to the list? Quote Share this post Link to post Share on other sites
rcamp48 #39 Posted June 24, 2019 I have actually got my US Robotics Sportster 28800 DIAL UP modem to work on a Rogers Voip Line, the thing I did not know is that digital lines still support pulse dialing and if you have a digital line first you have to type ATZ then ATP, then ATDP and the phone number, my BBS is going online right now! I will switch it to a pulse modulation and that will work with any caller in the world, the number to call is 1-226-647-0710 , I have an Ultra Satan with 8 GIGS online several door games but I have yet to get them to work, but I have Forum ST running with 12 message bases, and a NETUSBEE device hooked up. I will be running the MAX drives , that is 14 520 Meg drives from C to P, that's 520 Megs times 14 dedicated to my new BBS : Spy Visits Spy BBS. I will put up both the ST , 8 Bit and Portfolio Libraries for download. This will be a free system, you can download to your hearts content at 19200 baud, I don't know if the Mega ST4 can go faster but I will try. And I am going to turn on my AdSpeed 16 MHZ speed booster too, to make it lightning fast along with my super fast Micro SD card (Highest speed you can get). Russ 2 Quote Share this post Link to post Share on other sites
rcamp48 #40 Posted June 24, 2019 You guys want an AtariAge BBS, why not ???? Albert it is available for your use Russ Quote Share this post Link to post Share on other sites
