+retroclouds #1 Posted December 28, 2014 (edited) So it has been a few years since I've done TMS9900 assembly language programming. Here's a recycled demo where I've now attached a speech sample. Tried it with classic99. Anyone willing to try if this also works on the real deal? It's an 8K image, scratchpad memory only. You'll need a supercart and a speech synthesizer to run this. CART.bin ********@*****@*********************@************************** AORG >6000 *-------------------------------------------------------------- * Cartridge header *-------------------------------------------------------------- GRMHDR BYTE >AA,1,1,0,0,0 DATA PROG BYTE 0,0,0,0,0,0,0,0 PROG DATA 0 DATA RUNLIB BYTE 10 TEXT 'SKULL DEMO' *-------------------------------------------------------------- * Include required files *-------------------------------------------------------------- COPY "D:\retro\Projekte\spectra2\tms9900\runlib.a99" *-------------------------------------------------------------- * Equates for the demo *-------------------------------------------------------------- TOGGLE EQU >8342 ; 2 - Toggle for SATs RAMSAT EQU >8344 ; 68 - Copy of SAT in RAM TIMERS EQU >8388 ; 12 - Space for 3 timers TMPBUF EQU >8394 *-------------------------------------------------------------- * SPECTRA2 startup options *-------------------------------------------------------------- SPVMOD EQU GRAPH1 ; Video mode. See VIDTAB for details. SPFONT EQU NOFONT ; Font to load. See LDFONT for details. SPFCLR EQU >01 ; Foreground/Background color for font. SPFBCK EQU >0B ; Screen background color. *************************************************************** * Main ********@*****@*********************@************************** MAIN CLR @TOGGLE BL @PUTVR DATA >01E3 ; Sprite magnify 2x + 16x16 size BL @FILV DATA >0000,>00,16000 ; Clear VDP memory BL @FILV DATA >0380,>10,16 BL @CPYM2V DATA >1000,SKULPT,68*8 ; Load skull sprite patterns into VDP memory BL @CPYM2V DATA >0300,SPRITE,12*4 ; Load overlay sprites into VDP memory BL @CPYM2M DATA SPRITE+48,RAMSAT,17*4 ; Copy skull sprites from ROM to RAM BL @CPYM2V DATA >0808,LETTRS,13*8 ; Load character patterns into VDP memory LI TMP0,TIMERS ; Address of timer table MOV TMP0,@WTITAB ; Set timer table BL @MKSLOT DATA >0001,SKULL,EOL B @TMGR *************************************************************** * Controller - Scroll skull *************************************************************** SKULL BL @CPYM2V DATA >0330,RAMSAT,68 ; Dump RAMSAT to VDP *************************************************************** * Calculate sprite positions for next frame *************************************************************** LI TMP0,RAMSAT CLR TMP1 LI TMP2,16 SKULLA MOVB *TMP0,TMP1 AI TMP1,->0200 ; Y=Y-2 CI TMP1,>D000 ; Skip Y position >D0 JNE SKULLB AI TMP1,->0100 SKULLB CI TMP1,>1900 ; Y position >19 reached ? JEQ SKULLD ; Yes, remove overlay sprites CI TMP1,>0800 ; Y position >08 reached ? JLE SKULLE ; Yes, stop scrolling skull SKULLC MOVB TMP1,*TMP0 AI TMP0,4 DEC TMP2 JNE SKULLA B @SLOTOK ; Exit thread *************************************************************** * Remove overlay sprites *************************************************************** SKULLD MOV @TOGGLE,@TOGGLE ; Already removed overlay ? JNE SKULLC ; Yes, so skip MOV TMP0,@TMPBUF MOV TMP1,@TMPBUF+2 MOV TMP2,@TMPBUF+4 BL @FILV DATA >0300,>E0,12*4 ; Put overlay sprites off-screen MOV @TMPBUF,TMP0 MOV @TMPBUF+2,TMP1 MOV @TMPBUF+4,TMP2 SETO @TOGGLE JMP SKULLC *************************************************************** * Stop scrolling skull and prepare shadow image *************************************************************** SKULLE BL @CPYM2V DATA >0264,TEXT,24 ; Put text 'A RETROCLOUDS PRODUCTION' LI TMP0,RAMSAT LI TMP1,>0202 LI TMP2,16 SKULLF A TMP1,*TMP0 ; Prepare RAMSAT for flicker shadow image AI TMP0,4 DEC TMP2 JNE SKULLF BL @CPYM2V DATA >0400,RAMSAT,17*4 ; Dump RAMSAT again BL @MKSLOT DATA >0020,WKDELAY,EOL ; Replace slot B @SLOTOK ; Exit thread *************************************************************** * Controller - Small delay *************************************************************** WKDELAY BL @MKSLOT DATA >0001,WKTOG ; Toggle SAT pointers DATA >017F,FREEZE,EOL ; Freeze after 1 second BL @SPPREP DATA THUNDR,SPOPT1 ; Speech player on / Speak external MOVB @BD1,@BTIHI ; Set highest slot in use to 1 B @SLOTOK ; Exit thread *************************************************************** * Controller - Toggle SAT pointer for shadow image *************************************************************** WKTOG DEC @TOGGLE JEQ WKTOGB WKTOGA BL @PUTVR DATA >0506 ; SAT at >0300 ABS @TOGGLE B @SLOTOK ; Exit thread WKTOGB BL @PUTVR DATA >0508 ; SAT at >0400 B @SLOTOK ; Exit thread *************************************************************** * Controller - Random delay and restart of animation *************************************************************** FREEZE MOVB @BD0,@BTIHI ; Set highest slot in use to 0 BL @MKSLOT DATA >0060,FREEZ1,EOL BL @RND ; \ Generate random number between 0-7 DATA 7,WAUX1 ; / Seed is stored in WAUX1 upon startup AI TMP0,3 ; MOV TMP0,@WAUX2 ; Save as delay 3-10 seconds JMP FREEZ2 FREEZ1 DEC @WAUX2 MOV @WAUX2,TMP0 JNE FREEZ2 JMP WKDELAY ; Delay reached, restart animation FREEZ2 B @SLOTOK *************************************************************** * Skull sprite layout *************************************************************** * 159D * 26AE * 37BF * 48CG *************************************************************** * Skull sprites ********@*****@*********************@************************** SPRITE DATA >9040,>400B ; Overlay 1 DATA >9060,>400B ; Overlay 2 DATA >9080,>400B ; Overlay 3 DATA >90A0,>400B ; Overlay 4 DATA >B040,>400B ; Overlay 5 DATA >B060,>400B ; Overlay 6 DATA >B080,>400B ; Overlay 7 DATA >B0A0,>400B ; Overlay 8 DATA >FE40,>400B ; Overlay 9 DATA >FE60,>400B ; Overlay A DATA >FE80,>400B ; Overlay B DATA >FEA0,>400B ; Overlay C DATA >9140,>0001 ; Sprite 1 DATA >B140,>0401 ; Sprite 2 DATA >D140,>0801 ; Sprite 3 DATA >F140,>0C01 ; Sprite 4 DATA >9160,>1001 ; Sprite 5 DATA >B160,>1401 ; Sprite 6 DATA >D160,>1801 ; Sprite 7 DATA >F160,>1C01 ; Sprite 8 DATA >9180,>2001 ; Sprite 9 DATA >B180,>2401 ; Sprite A DATA >D180,>2801 ; Sprite B DATA >F180,>2C01 ; Sprite C DATA >91A0,>3001 ; Sprite D DATA >B1A0,>3401 ; Sprite E DATA >D1A0,>3801 ; Sprite F DATA >F1A0,>3C01 ; Sprite G DATA >D000 *************************************************************** * Skull sprite patterns ********@*****@*********************@************************** *-- Sprite 1 SKULPT DATA >FFFF,>FFFF,>FFFF,>FFFF DATA >FFFF,>FFFF,>FFFF,>FFFF DATA >FFFF,>FFFF,>FFFF,>FFFF DATA >FFFF,>FEFC,>F8F0,>E0E0 *-- Sprite 2 DATA >FFFF,>FFFF,>FFFF,>FFFF DATA >FFFF,>FFFF,>FEFE,>FEFE DATA >C0C0,>8080,>8080,>0000 DATA >0000,>0000,>0000,>0000 *-- Sprite 3 DATA >FEFC,>FCFC,>FCFC,>F8F8 DATA >F8F8,>F8F8,>F8F8,>FCFC DATA >0001,>0307,>0F0F,>1F1F DATA >3F3F,>0000,>0000,>0000 *-- Sprite 4 DATA >FEFF,>FFFF,>FFFF,>FFFF DATA >FFFF,>FFFF,>FFFF,>FFFF DATA >0387,>FFFF,>FFFF,>FFFF DATA >FFFF,>FFFF,>FFFF,>FFFF *-- Sprite 5 DATA >FFFF,>FFFE,>FCF8,>F0C0 DATA >8000,>0000,>0000,>0000 DATA >FFFF,>0000,>0000,>0000 DATA >0000,>0000,>0000,>0000 *-- Sprite 6 DATA >0000,>0000,>0000,>0000 DATA >0000,>0000,>0000,>0000 DATA >0001,>0303,>0303,>0303 DATA >0303,>0301,>0101,>0100 *-- Sprite 7 DATA >FCFE,>FFFF,>FFFF,>FEFC DATA >F8C0,>0000,>0000,>3CFF DATA >0000,>0000,>0103,>0707 DATA >0F0F,>1F1F,>1E08,>0000 *-- Sprite 8 DATA >FFFE,>FCF0,>E1F3,>FFFF DATA >FFFF,>FFFF,>FFFF,>FFFF DATA >0000,>0040,>8000,>0084 DATA >C4FC,>FCFC,>FEFF,>FFFF *-- Sprite 9 DATA >FFFF,>0000,>0000,>0000 DATA >0000,>0000,>000F,>3F7F DATA >FFFF,>FF3F,>0F03,>0000 DATA >0000,>0000,>00F0,>FCFF *-- Sprite A DATA >FFFF,>FFFF,>FFFF,>FFFF DATA >FFFF,>FFFF,>FFFF,>FFF8 DATA >FFFF,>FFFF,>FFFF,>FFFF DATA >FFFF,>FFFF,>FFFF,>FFFE *-- Sprite B DATA >0000,>0000,>80E0,>F0F8 DATA >FC7E,>3E02,>0000,>0000 DATA >7C00,>0000,>0000,>0000 DATA >0101,>0101,>0100,>0000 *-- Sprite C DATA >0000,>0000,>0000,>0000 DATA >0808,>0C0F,>1FFF,>FFFF DATA >0000,>0C07,>0301,>0123 DATA >131F,>3FFF,>FFFF,>FFFF *-- Sprite D DATA >FFFF,>FFFF,>FFFF,>FF7F DATA >1F0F,>0703,>0301,>0000 DATA >FFFF,>FFFF,>FFFF,>FFFF DATA >FFFF,>FFFF,>FFFF,>FF7F *-- Sprite E DATA >8080,>C0C0,>E0E0,>E0E0 DATA >C0C0,>C080,>8080,>0000 DATA >7F3F,>1F1F,>0F0F,>0707 DATA >0303,>0307,>070F,>0F1F *-- Sprite F DATA >0000,>000F,>1F3F,>7FFF DATA >FFFF,>FFFF,>FF7F,>1F1F DATA >3F3F,>FFFF,>FFFF,>FFFF DATA >FFFF,>FFFF,>FFFF,>FFFF *-- Sprite G DATA >1F3F,>3F7F,>FFFF,>FFFF DATA >FFFF,>FFFF,>FFFF,>FFFF DATA >FFFF,>FFFF,>FFFF,>FFFF DATA >FFFF,>FFFF,>FFFF,>FFFF *-- Sprite H DATA >FFFF,>FFFF,>FFFF,>FFFF DATA >FFFF,>FFFF,>FFFF,>FFFF DATA >FFFF,>FFFF,>FFFF,>FFFF DATA >FFFF,>FFFF,>FFFF,>FFFF *************************************************************** * Pattern definitions for text ********@*****@*********************@************************** LETTRS DATA >0008,>1C14,>223E,>4200 ; A (1) DATA >007E,>2226,>7C28,>2600 ; R (2) DATA >003C,>4078,>404C,>7000 ; E (3) DATA >007E,>1010,>1010,>1000 ; T (4) DATA >001E,>3262,>4266,>3C00 ; O (5) DATA >001E,>3260,>4066,>3C00 ; C (6) DATA >0010,>1030,>2020,>3C00 ; L (7) DATA >0012,>3222,>624E,>7A00 ; U ( DATA >007C,>2222,>263C,>7800 ; D (9) DATA >001E,>2240,>3C04,>3800 ; S (10) DATA >007E,>2224,>3820,>2000 ; P (11) DATA >0038,>0010,>1010,>1000 ; I (12) DATA >0002,>4262,>725E,>4600 ; N (13) *************************************************************** * Text 'A RETROCLOUDS PRODUCTION' ********@*****@*********************@************************** TEXT BYTE 1,0,2,3,4,2,5,6,7,5,8,9,10,0,11,2,5,9,8,6,4,12,5,13 *************************************************************** * Speech sample * http://atariage.com/forums/topic/203069-transylvania-a-new-version-using-tms5220-synthetizer/?p=2609444 ********@*****@*********************@************************** THUNDR BYTE TALKON BYTE >28,>68,>CA,>4C,>4D,>2D,>93,>60,>58,>0F,>73,>B3,>4D,>00,>EF,>BD BYTE >03,>E0,>93,>CE,>00,>A2,>F7,>18,>40,>F2,>9E,>03,>C8,>D6,>6A,>00 BYTE >D9,>58,>0F,>20,>1B,>CD,>01,>44,>AD,>31,>00,>6F,>2C,>17,>60,>8C BYTE >E7,>01,>BC,>89,>38,>40,>66,>6E,>07,>88,>32,>FC,>00,>5E,>87,>1F BYTE >20,>A8,>F0,>03,>44,>11,>76,>80,>68,>2D,>16,>10,>AC,>D9,>01,>92 BYTE >51,>5B,>80,>B7,>1E,>03,>E0,>C6,>6C,>00,>D6,>9B,>2E,>C0,>39,>B7 BYTE >05,>78,>A3,>BE,>80,>A8,>D4,>17,>E0,>5C,>C4,>00,>8C,>31,>6B,>80 BYTE >B3,>E6,>0D,>30,>4E,>63,>00,>CE,>5A,>34,>20,>38,>89,>01,>78,>EF BYTE >D1,>80,>10,>34,>1A,>10,>2C,>7B,>03,>92,>97,>28,>80,>0F,>9A,>09 BYTE >30,>5E,>BC,>01,>26,>58,>36,>C0,>04,>CB,>02,>C8,>A0,>59,>80,>E0 BYTE >25,>1A,>10,>BC,>46,>03,>9C,>D3,>28,>80,>B5,>12,>05,>08,>46,>63 BYTE >00,>C9,>69,>34,>C0,>44,>CB,>02,>28,>AF,>D1,>00,>E1,>34,>1B,>E0 BYTE >BD,>44,>03,>A2,>93,>2C,>80,>2C,>96,>0D,>D0,>D9,>B2,>00,>3E,>6A BYTE >14,>20,>06,>C9,>02,>78,>AF,>51,>00,>13,>35,>12,>E0,>1D,>47,>02 BYTE >AC,>D7,>28,>80,>F1,>E2,>09,>F0,>41,>22,>01,>21,>68,>14,>C0,>39 BYTE >A9,>04,>78,>27,>99,>00,>1F,>34,>0B,>E0,>A3,>65,>01,>4C,>F2,>6C BYTE >80,>F3,>9A,>05,>F0,>9E,>B3,>00,>26,>59,>36,>40,>47,>AD,>06,>44 BYTE >2F,>D9,>80,>EC,>25,>0A,>90,>9C,>44,>01,>A2,>93,>28,>40,>F0,>92 BYTE >05,>F0,>5E,>B3,>00,>D1,>4B,>14,>20,>7A,>C9,>04,>A4,>28,>99,>80 BYTE >14,>39,>13,>10,>03,>47,>02,>52,>90,>4A,>40,>0C,>12,>01,>08,>41 BYTE >22,>01,>C1,>4B,>04,>20,>06,>89,>00,>04,>CF,>19,>80,>E0,>24,>03 BYTE >E0,>83,>66,>02,>42,>90,>08,>40,>08,>92,>0E,>88,>89,>D3,>00,>3E BYTE >48,>1A,>C0,>26,>49,>05,>E8,>28,>61,>80,>90,>39,>0D,>10,>B3,>B8 BYTE >01,>42,>E3,>30,>40,>AC,>1C,>06,>D0,>91,>53,>01,>36,>71,>28,>C0 BYTE >67,>09,>05,>90,>28,>A1,>00,>15,>39,>14,>60,>93,>84,>03,>5C,>E1 BYTE >34,>80,>CD,>5C,>0A,>70,>89,>43,>01,>3A,>4A,>2A,>C0,>47,>4E,>03 BYTE >98,>C8,>A9,>00,>1B,>24,>15,>60,>93,>84,>02,>7C,>92,>10,>80,>F6 BYTE >12,>02,>10,>5E,>42,>01,>2A,>88,>09,>C0,>45,>09,>01,>F0,>A8,>29 BYTE >00,>95,>24,>05,>60,>A3,>86,>00,>B4,>37,>67,>80,>F7,>66,>0C,>70 BYTE >D6,>9C,>01,>C1,>A9,>31,>C0,>1B,>37,>06,>78,>6F,>C1,>00,>1B,>3C BYTE >18,>60,>83,>19,>03,>42,>30,>67,>40,>08,>16,>0C,>88,>DE,>9C,>01 BYTE >2E,>5A,>30,>20,>04,>75,>06,>38,>6F,>CE,>00,>17,>CC,>08,>E0,>A2 BYTE >3B,>01,>82,>77,>23,>00,>34,>66,>FF BYTE TALKOF END Edited December 28, 2014 by retroclouds 4 Quote Share this post Link to post Share on other sites
sometimes99er #2 Posted December 28, 2014 Beautiful. Quote Share this post Link to post Share on other sites
Asmusr #3 Posted December 28, 2014 A great way to use the speech synth . I tried it in MESS. Unfortunately I can't test it on the hardware since I don't have a Supercart. Quote Share this post Link to post Share on other sites
Omega-TI #4 Posted December 28, 2014 It'll need conversion before it can run on real hardware. I would think that Ti99Dir should do the trick... but the question remains what format, EA/5 or EA/3. It'll have to be someone else though... I'm out of time and am expected to be someplace.... Quote Share this post Link to post Share on other sites
+Ksarul #5 Posted December 28, 2014 I'll burn it to a ROM and try it out this evening. . .the boys may find it interesting. Quote Share this post Link to post Share on other sites
Tursi #6 Posted December 29, 2014 (edited) It'll need conversion before it can run on real hardware. I would think that Ti99Dir should do the trick... but the question remains what format, EA/5 or EA/3. It'll have to be someone else though... I'm out of time and am expected to be someplace.... Doesn't look like it needs any conversion - header looks clean - just burn it to an EPROM and fire it up. Cartridges don't come in EA#5 or EA#3 versions. Edited December 29, 2014 by Tursi Quote Share this post Link to post Share on other sites
Omega-TI #7 Posted December 29, 2014 Doesn't look like it needs any conversion - header looks clean - just burn it to an EPROM and fire it up. Cartridges don't come in EA#5 or EA#3 versions. I'm confused then, the message said it needs a Super Cart, but with a .bin extension (it reads like a PC program), I assumed it would need to be converted to either format to be loaded into it's 8K space. So how would I load this into the Super Carts RAM? Quote Share this post Link to post Share on other sites
+OLD CS1 #8 Posted December 29, 2014 It can be used as a regular cart in Classic99 (or MESS, though I have not tried) as it has a real cartridge header, but to use on real hardware you have to use a super-cart with RAM at >6000, or burn it to an EPROM in a Guidry-a-like cart. Quote Share this post Link to post Share on other sites
+OLD CS1 #9 Posted December 29, 2014 A great way to use the speech synth . I tried it in MESS. Unfortunately I can't test it on the hardware since I don't have a Supercart. How do you mount this in MESS? Made my own rpk with a layout.xml file. Quote Share this post Link to post Share on other sites
TheMole #10 Posted December 29, 2014 (edited) How do you mount this in MESS? Made my own rpk with a layout.xml file. Never looked into how one makes rpk files. Can you share your layout.xml? Edited December 29, 2014 by TheMole Quote Share this post Link to post Share on other sites
+OLD CS1 #11 Posted December 29, 2014 Never looked into how one makes rpk files. Can you share your layout.xml? I used this Ninerpedia article as a template to create the attached RPK. (The "C" is an artifact of using it with Classic99.) retroclouds_demo_cartC.rpk 2 Quote Share this post Link to post Share on other sites
TheMole #12 Posted December 30, 2014 Thank you sir. Cool demo, nice use of the speech synth for the sound effect. I also like the very nice skull logo/graphic. Quote Share this post Link to post Share on other sites
Willsy #13 Posted December 30, 2014 Can someone post a YouTube video of the demo, with sounds and speech? Ta! Quote Share this post Link to post Share on other sites
+OLD CS1 #14 Posted December 30, 2014 I have no YouTube, so how about an AVI in ZIP? retroclouds_skull_speech_synth_fx_demo.zip 3 Quote Share this post Link to post Share on other sites
+Ksarul #15 Posted December 30, 2014 I burned a cartridge image of this about an hour ago--it runs beautifully on real iron. I also turned on my Myarc MPES50, since it was attached to the console I use for module testing, and it doesn't affect the module at all, which is a good thing. The boys liked it, Retroclouds. 1 Quote Share this post Link to post Share on other sites
+retroclouds #16 Posted December 30, 2014 ok, here is an idea I'v been playing with for a long time, and that I'm gonna work on in 2015: a high-level language that compiles to 9900 assembly language, allowing you to create cartridge games that run on a bare console, that is without 32k memory expansion. Target will be the 99/4A and (perhaps) the Tomy Tutor. spectra will serve as the runtime library. The language will have a Pascal / ADA like syntax. Oh, it's gonna be a cross-compiler so work is done on a PC. We'll see how it goes, should be fun :-) 3 Quote Share this post Link to post Share on other sites
+OLD CS1 #17 Posted December 30, 2014 ok, here is an idea I'v been playing with for a long time, and that I'm gonna work on in 2015: a high-level language that compiles to 9900 assembly language, allowing you to create cartridge games that run on a bare console, that is without 32k memory expansion. Target will be the 99/4A and (perhaps) the Tomy Tutor. spectra will serve as the runtime library. The language will have a Pascal / ADA like syntax. Oh, it's gonna be a cross-compiler so work is done on a PC. We'll see how it goes, should be fun :-) Neat. So it will be its own contained game development environment and production system? Sounds fun! Quote Share this post Link to post Share on other sites
+Ksarul #18 Posted December 30, 2014 Now that is a wonderful idea! Would it support the larger, bank-switched cartridge modes, or would it be limited to single, 8K files? The latter is not a problem in my eyes--the question just lets me better understand the scope of possibilities using it. I will get a couple of Tutor cartridge boards made to allow real iron testing of anything you target to that system too. I already have the layouts done, so there isn't much additional work needed to support you in that very worthy endeavor. Quote Share this post Link to post Share on other sites
+retroclouds #19 Posted December 30, 2014 (edited) Sounds cool. It will support larger bankswitched cartridge models (at least for the ti-99/4a) As far as the tutor is concerned, the little demo I sent you last week looks very promising. There are some changes I would need to do for reducing TI-99/4A dependencies in the spectra library (memory locations, equates) but all in all very doable. I would like to write some small demo programs in the high-level language that then compile for both the 99/4a and the tutor. Edited December 30, 2014 by retroclouds Quote Share this post Link to post Share on other sites
