Crashtest33 Posted June 13, 2018 Share Posted June 13, 2018 TPR (4th pad along) doesnt go on this tiny track pad pictured?? Quote Link to comment Share on other sites More sharing options...
McWill Posted June 13, 2018 Share Posted June 13, 2018 This solderpoint is OK, but I can't see the pad under the hot glue I still don't know if the LYNX has sound when cartridge is inserted.Please send to my address and I will check it, if you want. PM sent. Quote Link to comment Share on other sites More sharing options...
+orpheuswaking Posted June 18, 2018 Share Posted June 18, 2018 I'm in a position to have this upgrade done now. Does anyone in the US install these and have the parts on hand? Quote Link to comment Share on other sites More sharing options...
Crashtest33 Posted June 18, 2018 Share Posted June 18, 2018 Bought another PAG-0201, did the mod and works perfectly. Installed it in my mint PAG-0200 chassis (reducing the joypad lugs) and now have a working McWill Screen!! Its awesome. One question: It produces white noise for a millisecond when you turn it on. Is this normal? Regards Nick Quote Link to comment Share on other sites More sharing options...
McWill Posted June 18, 2018 Share Posted June 18, 2018 If you mean the short crack noise when turning on it's normal. Quote Link to comment Share on other sites More sharing options...
Crashtest33 Posted June 18, 2018 Share Posted June 18, 2018 Na, not the normal crack. Its coloured white noise as before but stays on for a millisecond. Quote Link to comment Share on other sites More sharing options...
McWill Posted June 19, 2018 Share Posted June 19, 2018 Na, not the normal crack. Its coloured white noise as before but stays on for a millisecond. Yes, it's normal if it is just for a millisecond like this: http://atariage.com/forums/topic/233632-lynx-lcd-replacementvga-out-by-mcwill/?p=4047247 1 Quote Link to comment Share on other sites More sharing options...
nyandeyanen Posted June 20, 2018 Share Posted June 20, 2018 (edited) The replacement screen came in and I put it on the mod and reinstalled. It looks good for the most part, but I wonder if I killed the display decoder on the mod board in the process. The display shows a static screen of random-ish garbage the entire time the system is on, probably the same screen that showed up for a split second previously when turned on, although I can hear sound from games and I can see the scanline emulation toggle if I hit the backlight button. The system and mod are working at a basic level at least. I checked all the lines and there are no wires crossed; no attempt was made to install the VGA output. I ensured the flexi cable on the LCD was protected with some non-conductive tape, and was careful not to squish it against the battery holder. There are no holes on the flexi cable when I look, that shouldn't be the issue this time. Has anyone else had this problem? Perhaps I'm cursed? Edited June 20, 2018 by nyandeyanen Quote Link to comment Share on other sites More sharing options...
McWill Posted June 20, 2018 Share Posted June 20, 2018 If you have some colored static on the screen and the sound is working, both (the LYNX and LCD mod) are working fine.Is the screen flickering, please check CL2 again. If not check RES/TPR wire again.Please send some closer pictures of your wiring. 1 Quote Link to comment Share on other sites More sharing options...
nyandeyanen Posted June 20, 2018 Share Posted June 20, 2018 I found the problem, and there was a terribly important reason it wasn't working: I am an idiot. I'd soldered the entire second row to the Lynx II board offset by one pin. I re-soldered the lines to the right place and now it's working fine. Perhaps 4am is not the ideal time to start a precision soldering project. No amount of poking around with the multimeter could determine what a night's sleep could. If you have some colored static on the screen and the sound is working, both (the LYNX and LCD mod) are working fine.Is the screen flickering, please check CL2 again. If not check RES/TPR wire again.Please send some closer pictures of your wiring. 1 Quote Link to comment Share on other sites More sharing options...
80s_Atari_Guy Posted June 26, 2018 Share Posted June 26, 2018 A couple of questions. Are the screens still available ? What price would it be to the UK ? And could a moron (Me) install it ? Or is this for more experienced people ? Awesome screen, by the way. Quote Link to comment Share on other sites More sharing options...
nyandeyanen Posted June 27, 2018 Share Posted June 27, 2018 I imagine it depends on your soldering experience. Are you comfortable soldering several thin wires to a set of pins close to each other and near heat-sensitive components? I probably had no business doing the mod to be honest, but I think I leveled up installing mine and am much more comfortable with the process. It's very much worth the effort. 1 Quote Link to comment Share on other sites More sharing options...
80s_Atari_Guy Posted June 27, 2018 Share Posted June 27, 2018 I think my main problem would be my eyes, I'm long sighted. I would be too afraid of soldering across adjacent solder points that are too close together, so I end up soldering pins together. I have decent equipment, a good solder station with adjustable heat settings, and lots of different tips. I just don't want to ruin a lovely condition Lynx Mk1, many don't come in the condition mine is in. Quote Link to comment Share on other sites More sharing options...
nyandeyanen Posted June 27, 2018 Share Posted June 27, 2018 One of those "third hand" magnifiers with alligator clips for holding components should help if vision is the only problem, you can refocus by moving the glass. The pins that you solder to are kind of close on the Lynx II, although I haven't seen a Lynx I. I attached a picture of the part that worried me the most; after doing it once I think I could do a better job if I tried again. I think my main problem would be my eyes, I'm long sighted. I would be too afraid of soldering across adjacent solder points that are too close together, so I end up soldering pins together. I have decent equipment, a good solder station with adjustable heat settings, and lots of different tips. I just don't want to ruin a lovely condition Lynx Mk1, many don't come in the condition mine is in. 1 Quote Link to comment Share on other sites More sharing options...
80s_Atari_Guy Posted June 27, 2018 Share Posted June 27, 2018 Thanks for the pic. That doesn't look too difficult, to be honest. Quote Link to comment Share on other sites More sharing options...
nyandeyanen Posted June 27, 2018 Share Posted June 27, 2018 It wasn't really, since it was my first time trying a console mod I was a bit worried about it. Ironically the part that really hung me up was the ribbon cable of the new LCD getting pinched by the battery holder, hopefully there's more room in the Lynx I for that! I attached a piece of plastic with electric tape next to the offending area to prevent damage the second time around. Thanks for the pic. That doesn't look too difficult, to be honest. Quote Link to comment Share on other sites More sharing options...
+-^CrossBow^- Posted June 27, 2018 Share Posted June 27, 2018 For me, the most difficult part was replacing out the mosfet and zener since they are so small and in the case of the mosfet it is an SMD part. The rest was just time as I recapped it in the process of also doing the LCD mod. 1 Quote Link to comment Share on other sites More sharing options...
nyandeyanen Posted June 28, 2018 Share Posted June 28, 2018 I used a Chip Quik SMD removal kit for the mosfet, awesome stuff. For me, the most difficult part was replacing out the mosfet and zener since they are so small and in the case of the mosfet it is an SMD part. The rest was just time as I recapped it in the process of also doing the LCD mod. 1 Quote Link to comment Share on other sites More sharing options...
agradeneu Posted July 8, 2018 Share Posted July 8, 2018 (edited) The screen does not work well with Alpine Games "Hicolor mode" and transparencies., just lot of flickering. Was this already mentioned on this thread? Edited July 8, 2018 by agradeneu Quote Link to comment Share on other sites More sharing options...
Grumpmeister Posted July 9, 2018 Share Posted July 9, 2018 I'm really considering this mod as a project after I get back from vacation, but the technical talk is kind of scary... I have close to 0 experience in soldering (I've only done a CDi disc laser replacement just last week) and would have to purchase some soldering equipment for this, but it just seems awesome having a Lynx with this screen & VGA out. Luckily I do have 2 Lynxes laying around (as my brother also had one as a kid but has 0 interest in it any more), but I do feel a bit scared picking up this project. Aside from a soldering iron and tin, what equipment would be required for this? How big are the chances I'd permanently destroy something? And worst case if this doesn't seem like a feasable project for me, are there locations where I can have it done instead? Quote Link to comment Share on other sites More sharing options...
McWill Posted July 9, 2018 Share Posted July 9, 2018 The screen does not work well with Alpine Games "Hicolor mode" and transparencies., just lot of flickering. Was this already mentioned on this thread? Yes, interlaced mode isn't working well because of the variable frame rate of the LYNX. That was already mentioned here months ago. I'm really considering this mod as a project after I get back from vacation, but the technical talk is kind of scary... I have close to 0 experience in soldering (I've only done a CDi disc laser replacement just last week) and would have to purchase some soldering equipment for this, but it just seems awesome having a Lynx with this screen & VGA out. Luckily I do have 2 Lynxes laying around (as my brother also had one as a kid but has 0 interest in it any more), but I do feel a bit scared picking up this project. Aside from a soldering iron and tin, what equipment would be required for this? How big are the chances I'd permanently destroy something? And worst case if this doesn't seem like a feasable project for me, are there locations where I can have it done instead? The LYNX-II mod is more easy than LYNX-I or GAME GEAR. You just need a good soldering iron/station with fine tip. I also can do the installation for you, if you want. 2 Quote Link to comment Share on other sites More sharing options...
Grumpmeister Posted July 9, 2018 Share Posted July 9, 2018 The LYNX-II mod is more easy than LYNX-I or GAME GEAR. You just need a good soldering iron/station with fine tip. I also can do the installation for you, if you want. Really tempting! And since you're located in Germany that will be pretty manageable when it comes to mail and such (better than overseas for sure ). Expect a PM soon for some more info about it (mostly about time / cost estimates, as I'll be on a holiday soon). I'll have to do a quick test on my devices to see which is best to perform the mod on, though if I remember correctly both are in good working condition. Quote Link to comment Share on other sites More sharing options...
McWill Posted July 9, 2018 Share Posted July 9, 2018 PM sent Quote Link to comment Share on other sites More sharing options...
bjkock Posted July 15, 2018 Share Posted July 15, 2018 Finished the LCD/VGA upgrade on one of my Lynx II yesterday and the change is just Amazing!!Not at all as difficult as I thought, actually the hardest part was getting the hole for the VGA connector to look good . Added some pictures from the upgrade process. A big Thanks to McWill for this super great modification. New screen VGA Connector Only two more to go Lynx with original Screen Lynx with New screen New vs. Old VGA output 5 Quote Link to comment Share on other sites More sharing options...
greenmonkeyking Posted July 15, 2018 Share Posted July 15, 2018 Yes, interlaced mode isn't working well because of the variable frame rate of the LYNX. That was already mentioned here months ago. Q: Is there a list of any other games that use variable frame rate or interlaced mode? I plan to keep one of Lynx untis with a stock screen to play these games. But I'd liek to know which games need the stock screen. Thanks! Chuck Quote Link to comment Share on other sites More sharing options...
