Sign in to follow this
madgitty
Testing GTIA
Hi Guys
Just bought a couple of 130xe and 65xe pal versions, reading up on faulty gtia chips,as there is no serial number sticker underneath how can I test it to see if they are faulty.
I have found a basic prog which I tried and found that I get black lines in the pic, is this write
10 GR. 9:D=1:FOR X=0 TO 79
20 COLOR C:C=C+D:IF C=15 OR C=0 THEN D=-D
30 PLOT X,0:DR. X,191
40 NEXT X
50 G. 50
many thanks
Black appearing at certain luma transitions is normal - it's because a resistor ladder is used to generate the signal. The problem there being that it takes time for voltage to ramp up when changes like 7 to 8 occur... in binary that's 0111 to 1000 - monentarily there's no voltage at all.
Bad GTIA will look like the GTIA modes don't even exist. In that program put an extra line in:
45 POKE 623,0
it makes the graphics revert to just normal mode 8 - I've got an 800XE which is a victim of the bad batch of GTIAs.
Edited by Rybags
sorry to be thick, how do I run the file as it is a .arc
thanks
It is a .atr. .arc is a compression format. .atr is a disk image. you can use an .atr in emulator, or to use it with a real atari, you
need APE or ASPEQT disk drive emulator on PC and a PC to Atari interface and PC to Atari cable, either USB or serial.
There is a file called SI2.EXE on the .atr. That is what you run.
Edited by russg
