walaber #1 Posted January 17, 2015 Has anyone tried using software floating-point routines on the 2600? For my motorcycle game I'm thinking about different ways to handle the physics. I can always do something simplified and custom using just integers / some 16-bit math, but if I could get some floating point routines working it would be possible to make the physics pretty realistic. I see there are some 6502 floating point routines here: http://codebase64.org/doku.php?id=base:floating_point_routines_for_the_6502 (along with some other interesting links at the parent page: http://codebase64.org/doku.php?id=base:6502_6510_maths ) Has anyone tried these routines on 2600? I assume they consume a lot of cycles... but if I'm only simulating a few point masses it might be acceptible. otherwise does anyone have any recommendations for doing either floating point or fixed point (signed) math on 6502 assembly? In order to do a "proper" physics simulation I'd need the ability to add, subtract, multiply, divide, and sqrt. Other than the link above I can't seem to find any ready-to-use code for this kind of math. Quote Share this post Link to post Share on other sites
+SpiceWare #2 Posted January 17, 2015 http://www.alienbill.com/2600/cookbook/subpixel.html Quote Share this post Link to post Share on other sites
walaber #3 Posted January 17, 2015 Thanks SpiceWare, I've already seen that, and I understand the basics of fixed-point math, but can't seem to find actual code for all the math I need. every example I can find shows the extremely simple examples and then says something like "of course remember with twos-complement you have to change this a bit..." etc. I'm really surprised there isn't a link anywhere with basic routines for signed fixed-point 8.8 math with subroutines for ADD, SUB, MUL, DIV, SQRT... Quote Share this post Link to post Share on other sites
+Omegamatrix #4 Posted January 17, 2015 6502.org has a lot of math routines in their repository. The Batari Basic also has some 8.8 fixed point math routines. I don't think Fred will mind me posting those here as long as it is known it is from the BB kernel. ; Fixed point math routines - created by AtariAge member djmips ; some changes by Fred Quimby ;assignment from 8.8 to 4.4 Assign88to44: ; A(4.4) = A,X(8. stx temp1 rol temp1 asl rol temp1 asl rol temp1 asl rol temp1 asl rts ;assignment from 4.4 to 8.8 ; Assign44to88: ; A,X(8. = A(4.4) sta temp1 lda #0 asl temp1 sbc #0 ; eor #$ff ; do sign extend rol asl temp1 rol asl temp1 rol asl temp1 rol ldx temp1 rts ifconst bankswitch Assign88to44bs: ; A(4.4) = A,X(8. stx temp1 rol temp1 asl rol temp1 asl rol temp1 asl rol temp1 asl RETURN ;assignment from 4.4 to 8.8 ; Assign44to88bs: ; A,X(8. = A(4.4) sta temp1 lda #0 asl temp1 sbc #0 ; eor #$ff ; do sign extend rol asl temp1 rol asl temp1 rol asl temp1 rol ldx temp1 RETURN endif ; ;Addition/subtraction asm procedures: ;add/sub 8.8 to/from 4.4 Add88to44: ; A(4.4) = A,X(8. + Y(4.4) jsr Assign88to44 sty temp1 clc adc temp1 rts Sub88from44: ; A(4.4) = A,X(8. - Y(4.4) jsr Assign88to44 sty temp1 sec sbc temp1 rts Add44to88: ; A,X(8. = A,X(8. + Y(4.4) sta temp2 stx temp3 tya jsr Assign44to88 clc sta temp1 txa adc temp3 tax lda temp1 adc temp2 rts Sub44from88: ; A,X(8. = A,X(8. - Y(4.4) sta temp2 stx temp3 tya jsr Assign44to88 sec sta temp1 lda temp3 stx temp3 sbc temp3 tax lda temp2 sbc temp1 rts Quote Share this post Link to post Share on other sites
Rybags #5 Posted January 17, 2015 You can accomplish plenty using variations of the fractional method as previously linked. A problem with FP on 6502 and especially 2600 when doing so using BCD - 6 bytes to represent 10 significant digits + mantissa. OK, you could reduce that to 4 bytes representing 6 digits which would be plenty. But when doing calculations you're dealing with usually 2 numbers coming in and 1 coming out (usually you'd overwrite one of the incoming operands). So, the amount of Ram required can ramp up. Also, with BCD you generally need a buffer area so that numbers can be expanded into long form that the exponent in the mantissa represents before calculations can take place. e.g. if doing an add on 0.00001 and 100,000 there you need to have leading zeroes and trailing zeros on the operands and depending on what exponent you limit your numbers to, it can add up to a fair amount of Ram. Quote Share this post Link to post Share on other sites
Thomas Jentzsch #6 Posted January 17, 2015 I suggest doing multiplications with square tables. That's much faster than the usual loops with shifts and adds. Division and SQRT will be dead slow, most likely too slow. So you should use precalculated tables here too. Quote Share this post Link to post Share on other sites
Tjoppen #7 Posted January 20, 2015 I used floating point numbers for score in Bell Hopper (if you get far enough that is ). IIRC they needed 6 bytes for mantissa (12 BCD characters) and one byte for the exponent. It only supported addition and doubling (adding the accumulator to itself). But what everyone else said: fixed point is most likely the way to go unless you need to do something *really* special. Quote Share this post Link to post Share on other sites
walaber #8 Posted January 21, 2015 Thanks for the notes everyone. I'm going to go with simplified math for the game, probably using basic scaled integer / 16-bit math where necessary. Quote Share this post Link to post Share on other sites
+Omegamatrix #9 Posted January 21, 2015 I don't know if this will be useful, but if you have need to do some unsigned integer division then I made some routines to do specific integers. You can find a copy here: http://forums.nesdev.com/viewtopic.php?f=2&t=11336 Also at the end of that thread is a 16 bit divide by 10. There is also some stuff in my blog. Quote Share this post Link to post Share on other sites
Thomas Jentzsch #10 Posted January 21, 2015 I suggest having a look at C=Hacking. Quote Share this post Link to post Share on other sites
