Sign in to follow this
walter_J64bit
PaCifiST in Windows 7
I'm trying to run PaCifiST in Windows 7, I'm having no luck. This is what's going on, I'll pull up command prompt and than I'll try to run PaCifiST and I get "This system doesn't support fullscreen mode." can anyone help without having to use DOSBox.
Edited by walter_J64bit
As far as I know it's one of few St emulators that lets you use the PC's Floppy drive, I want to try something out with *.stx files.
I've got running PaCifiST under Windows 7, it's was so easy to do. :-o I'd some reading, someone said try installing XP drivers for the video card so what i did was boot in to safe-mode that did the trick now I to need recall how setup PaCifiST.
