Savetz Posted November 6, 2016 Share Posted November 6, 2016 Here's another attempt at Tiny Tots. The disk was a lot quieter this time, I think this might be a better read. Can someone try it out? (I can't— waiting on a Mac version of phaeton's conversion utility.) —Kevin TOT try 2.zip Quote Link to comment Share on other sites More sharing options...
Farb Posted November 6, 2016 Author Share Posted November 6, 2016 Can someone try it out? (I can't— waiting on a Mac version of phaeton's conversion utility.) This looks much better and now successfully boots. There's still some bad reads but it seems like a8rawconv may be compensating. I'll let Ijor chime in if he sees something wrong. FYI, I provided a Mac binary for a8rawconv (phaeron's conversion utility) a couple of posts up. Quote Link to comment Share on other sites More sharing options...
Savetz Posted November 6, 2016 Share Posted November 6, 2016 Microsoft BASIC 1.0 — Atari internal disk, labeled serial number 140. Copy protected. Don't know if it's the same as the released version. MicrosoftBASIC1.0_AtariInternal_1981-09-04_serialnumber140.zip Spell Me (Castle Software).zip From my own (purchased back in the day!) Birth of the Phoenix disk. Birth of the Phoenix.zip 3 Quote Link to comment Share on other sites More sharing options...
voy Posted November 6, 2016 Share Posted November 6, 2016 I can not convert "Birth of the Phoenix"... MicrosoftBASIC1.0_AtariInternal_1981-09-04_serialnumber140.rar Spell Me (Castle Software).atr Quote Link to comment Share on other sites More sharing options...
Farb Posted November 6, 2016 Author Share Posted November 6, 2016 (edited) Yes, Birth of the Phoenix appears to be problematic. It might be worth another dump attempt. Oh, and is Spell Me an original disk? If so, any chance of a photo? Edited November 6, 2016 by Farb Quote Link to comment Share on other sites More sharing options...
Savetz Posted November 6, 2016 Share Posted November 6, 2016 Yes, Birth of the Phoenix appears to be problematic. It might be worth another dump attempt. Oh, and is Spell Me an original disk? If so, any chance of a photo? All of the disks I contribute to this project will be originals unless I say otherwise. PhoenixTry2.zip Advanced Protection Techniques (Alpha).zip -Kevin 3 Quote Link to comment Share on other sites More sharing options...
ijor Posted November 6, 2016 Share Posted November 6, 2016 What about the many titles that were released only in ED? ... Also I found a protected DD disk in my collection ... It would be great if the new specification of the ATX format would provide support for ED and DD densities... Here is log from the AUFIT v1.3 by Jean Louis-Guérin (DrCoolZic): Yes, we are exchanging ideas with Phaeron. One way or the other it will get MFM support. Note that Aufit is designed for ST disks. As you can see it gets a little confused with 8-bit disks. For sure that most of those protections messages are just a consequence of the different bit rate between the disk of both platforms (300 RPM vs 288 RPM). Will take at the look at the raw dump later. Many thanks. 1 Quote Link to comment Share on other sites More sharing options...
ijor Posted November 6, 2016 Share Posted November 6, 2016 This looks much better and now successfully boots. There's still some bad reads but it seems like a8rawconv may be compensating. I'll let Ijor chime in if he sees something wrong. Yes, it is ok. There are errors, but every track is ok in at least one revolution. It has no copy protection that I can see. Quote Link to comment Share on other sites More sharing options...
voy Posted November 6, 2016 Share Posted November 6, 2016 (edited) Successfully converted Advanced Protection Techniques (Alpha Systems) in the ATX format. EDIT: Corrected name of the publisher. Advanced Protection Techniques (Alpha).rar Edited November 6, 2016 by voy 3 Quote Link to comment Share on other sites More sharing options...
Savetz Posted November 6, 2016 Share Posted November 6, 2016 Successfully converted Advanced Protection Techniques (Alpha) in the ATX format. To clarify: That's published by Alpha Systems; not an alpha version of the software. 1 Quote Link to comment Share on other sites More sharing options...
Farb Posted November 7, 2016 Author Share Posted November 7, 2016 All of the disks I contribute to this project will be originals unless I say otherwise. Thanks for the clarification and the photo of Spell Me. Unfortunately, the second Phoenix attempt was only slightly better than the first. The Advanced Protection Techniques dump has quite a bit of stuff going on that I would generally consider suspect but, then again, it is a disk demonstrating PROTECTION TECHNIQUES The ATX does boot. I may have that disk hiding somewhere - I'll see if I can find it and compare. Quote Link to comment Share on other sites More sharing options...
+Stephen Posted November 7, 2016 Share Posted November 7, 2016 Thanks for the clarification and the photo of Spell Me. Unfortunately, the second Phoenix attempt was only slightly better than the first. The Advanced Protection Techniques dump has quite a bit of stuff going on that I would generally consider suspect but, then again, it is a disk demonstrating PROTECTION TECHNIQUES The ATX does boot. I may have that disk hiding somewhere - I'll see if I can find it and compare. I do have that disk, but alas, no Kryoflux device. Quote Link to comment Share on other sites More sharing options...
+DjayBee Posted November 7, 2016 Share Posted November 7, 2016 (edited) Microsoft BASIC 1.0 — Atari internal disk, labeled serial number 140. Copy protected. Don't know if it's the same as the released version. These are identical except for these two differences: Released version: end of VTOC sector: "V1.0 100" protection: sectors 364, 380, 560, 592, 720 (missing) internal version: end of VTOC sector: "uSOFT V1.0 140" protection: sectors 364, 380, 560, 592, 720 (bad CRC) Altirra v2.81 shows a strange behavior with the internal version: For the bad sectors with "LFE DISK" it does not even show that these are accessed. Edited November 7, 2016 by DjayBee Quote Link to comment Share on other sites More sharing options...
Shannon Posted November 10, 2016 Share Posted November 10, 2016 I think a disk is missing from Sons of Liberty (1987)(SSI)(US) The boot disk seems to be there but the back side of the game disk is missing? Quote Link to comment Share on other sites More sharing options...
Farb Posted November 12, 2016 Author Share Posted November 12, 2016 I see two ATX files in the torrent labelled "Scenario" and "Game". Are you saying that you only see one file in the ZIP or that one of the ATXs is incorrect? Quote Link to comment Share on other sites More sharing options...
Shannon Posted November 12, 2016 Share Posted November 12, 2016 There should be three disks.. but I'm not sure how they are labelled.. On Atari mania they have three disks.. labelled Game Disk (back and front) and one just named "Sons of Liberty.atr". The one named "Sons of Liberty.atr" is bootable and runs the game. The one labelled Game Disk is what I insert when it asks for Side 1 (front) and Side 2 (back). However the media scans show a "Game Disk" and a "Scenario Disk". So I'm not sure how they are labelled. Compare this to what is in the torrent here and it looks like the back side of the Game Disk is missing. Because when the game asks for it none of the included disks works. The manual on Atarimania does not really give much insight on this either. But best I can tell the back side of the Game Disk is missing in your set. Quote Link to comment Share on other sites More sharing options...
+remowilliams Posted November 13, 2016 Share Posted November 13, 2016 Ah, it looks like the Sons of Liberty game disk is double sided. I'll get an image for side 2 Scenario disk is the boot disk and seems to be only single sided. 1 Quote Link to comment Share on other sites More sharing options...
Shannon Posted November 13, 2016 Share Posted November 13, 2016 Thanks remo. I read the documentation and it never specified which was the boot disk. I suspected the scenario disk was the boot disk but was not 100% sure. Quote Link to comment Share on other sites More sharing options...
+remowilliams Posted November 13, 2016 Share Posted November 13, 2016 Here you go: Sons of Liberty Game.Side Two.rar 1 Quote Link to comment Share on other sites More sharing options...
Shannon Posted November 19, 2016 Share Posted November 19, 2016 Did anyone have any luck getting the tape version of Star League Baseball (1983)(Gamestar)(US) to start? I get to the intro but then the music just keeps playing. Tried on Altirra and Atarixlbox. Quote Link to comment Share on other sites More sharing options...
Mclaneinc Posted November 19, 2016 Share Posted November 19, 2016 (edited) Did anyone have any luck getting the tape version of Star League Baseball (1983)(Gamestar)(US) to start? I get to the intro but then the music just keeps playing. Tried on Altirra and Atarixlbox. Just sat and tested it, it needs to be booted in XL and the screen set to NTSC Its weird, if I try and boot it as an OSB it errors and goes to Memo pad, were the cas routines upgraded in the XL bios? Edited November 19, 2016 by Mclaneinc Quote Link to comment Share on other sites More sharing options...
Shannon Posted November 19, 2016 Share Posted November 19, 2016 Yeah I did that. Were you able to get a game started? I can't get past the opening music. Quote Link to comment Share on other sites More sharing options...
FULS Posted November 19, 2016 Share Posted November 19, 2016 Yeah I did that. Were you able to get a game started? I can't get past the opening music. Same thing here. Just opening music and no chance to start a game. Quote Link to comment Share on other sites More sharing options...
FULS Posted November 19, 2016 Share Posted November 19, 2016 These seem to work. Star League Baseball .zip Quote Link to comment Share on other sites More sharing options...
Shannon Posted November 19, 2016 Share Posted November 19, 2016 Yeah thanks... but I got the disk version from this archive working. I was just trying to determine if the tape image is bad or if I overlooked some emulator setting or incompatibility. Quote Link to comment Share on other sites More sharing options...
