Lode Runner Chuck Peavey Conversion
bbking67
I just listened to the Antic Podcast Chuck Peavey interview... it sounded to me like he converted Lode Runner in 1987 to the XE Cartridge from the original Apple II version.
Now that just seems odd to me, since there was already an Atari 800 version of the game... wouldn't it have been easier just to port that from being a disk game to ROM?
I never owned the XE cartridge... are there any substantial differences?
When I heard the podcats I was thinking maybe he has fuzzy memories and it was just converted from the Atari code... (which itself is likely a direct port from the original Apple II game).
Chuck Peavey definitely did the XEGS cartridge conversion (he's credited on the title screen), but I was always under the impression that it was a conversion of the Atari 800 disk version. The main difference is that, by default, the cartridge version gets the level data from the cartridge; you can switch to "disk mode" to load saved levels from disk. If he did in fact convert it from the Apple version, he did a great job of duplicating the audiovisuals from the Atari version, because as I remember it, it was exactly identical.
As I understand it, the differences in the colors of the bricks has more to do with the way the different Atari computers handle color artifacting. The original disk version also has different-colored bricks when played on the XL/XE machines.
Weren't there three separate versions of Lode Runner for the A8? Admittedly all very similar, but I seem to remember that one of those had three versions.
Anyone remember?
-Larry
Well, there was the original Lode Runner, then there was Championship Lode Runner (the same game but with brutally difficult new levels, minus the level editor), and then there was the cartridge conversion of the original Lode Runner that was published by Atari. All three seem to have been derived from the same code base, so perhaps those are the three versions you're thinking of.
There was also Lode Runner's Rescue from Synapse, which I've played only briefly, but that was a totally different product.
Yes, but that's not what I'm referring to. For one of those (IIRC), there was a disk version and two cartridge versions -- one non-Atari cartridge preceded the Atari XEGS cart version, then Atari made some changes itself for its "gray" cartridge.
-Larry
-Larry
Hmmmm,
I remember this from Choplifter, afaik there is a 24k/32k disk from Broderbund, a 16k cart. from Broderbund and a 32k or 64k gray XE/XEGS cart. from Atari. Not sure if that 24k/32k for the disk version was only the RAM requirements or the real length of the program, nor if the 16k Broderbund cart was shortened somehow. Afaik, Lode Runner was never available on cart. from Broderbund.
But there were quite some 24k and 32k A8 disk games that were shortened to fit on a standard (non-bankswitching) 16k cartridge...
-Larry
You might be right. For whatever it's worth, I found the following in an article on the Internet Archive:
Most versions of Lode Runner were on disk, but the Atari 8-bit and Commodore 64 also got a "lite" cartridge version with only 32 levels and no editor for users without disk drives.
If true, this must have preceded Atari's re-release of Lode Runner on cartridge for the XEGS, since I'm quite certain that Atari's version included all the levels and the editor.
That text on Internet Archive was copied from Wikipedia, and is simply incorrect (The Wikipedia article is now fixed.) The Broderbund's catalog from 1983 shows that only C-64 was getting the cartridge version.
The Chuck Peavey cartridge contains all 150 levels.
  • 1 year later...
Hi, Guys,
Chuck Peavey saw this thread but apparently doesn't have an AtariAge registration yet.
Here's his reply:
"So the code was Apple but I got the levels off of a disc (that was a nightmare) for the Atari. That's how I got all 150 levels. There were no sprites in the code, because the graphics were sort of character mapped so it was easy enough to convert.
I am fuzzy on a few points. I remember spending hours getting the AI for the bad guys to emulate properly so play would be the same as it was on my C-64 (my personal favorite version).
So in a nutshell, it was a hybrid. Atari maps, Apple code. Would Atari code have been easier? Of course! Did they give me Atari source code to work with... Of course NOT! ;)
This conversion took me 4 months, longer than any other and they paid me as if it was an easy conversion so that kinda sucked but... I got my name of Load Runner, can't ask for better than that "
The reply on Facebook is here:
https://www.facebook.com/SashaJoy13/posts/10157132611375315?comment_id=10157134106115315
  • Like 6
For some reason I prefer the original version that used artifacting for color. I have both versions, the original as an ATR and the newer one as an XEX. They both load from my IDEPlus just fine.
Chuck Peavey's version uses artifacting too. That one you're talking about is just a hack, where they've changed the mode lines from Antic F to Antic E. A lot of games have been hacked like that.
Edited by MrFish
Indeed, just for fun I did it to Drol etc...Looks great and technical but its just the display list edited as said by MrFish....Mind you, 99.9% of you lot in here know that and a million times more..I'm jealous :)
Wish I'd gone back to maths and bettered myself but school boy hacks, trainers and a few utils were good enough for me considering I was dumber that a box of spanners.. :)
Interesting, I never realized that was a hack. I guess you'd have basically the same effective horizontal resolution as you would using artifacting for everything in hi-rez mode. I learned something today.
I'm in the same boat, I've done some actual development in high-level languages on bigger machines but nothing real special. I'm a SysAdmin more than I am a programmer. I'm working on an Electronics Engineering Technology degree full-time and the math is absolutely BRUTAL, especially since I'm in my mid-30's now, have a GED and never stepped foot in college. I'm passing but it hurts.
That's the problem with hacks like that, though. The original Atari version didn't use artifacting for everything -- which is a reason for using hi-res in the first place. So there are parts that didn't come out so well in the translation. For instance, the protagonist was designed with no artifacting. If he were redesigned, the hack would look much better. There are also some spots where the enemies' colors aren't consistent -- and the blocks aren't colored right as well.
Edited by MrFish
