ClausB Posted February 8, 2015 Share Posted February 8, 2015 When I could finally afford an Epson RX-80, around 1983, I wrote an Atari screen dump utility that could print most any graphics mode, even mixed, by emulating ANTIC and GTIA. It used OS shadow registers to trace the display list, read pixel data, interpret them according to the ANTIC mode, color them (luminance only) using the shadowed color registers, and fill the printer's graphics buffer with dots in various dither patterns. It worked pretty well, even in GTIA modes, though it did not do PM graphics (since those registers are not shadowed) nor DLIs. I wrote the proof of concept in BASIC A+, leaving out some features like GTIA modes and character extender mode. Once the overall logic worked, I recoded it in assembly, putting those features in. Later I modified it for Atari LOGO and included PM graphics support for the turtle, because LOGO provided those shadows. In 1985 I interviewed for a job as a C programmer, so I added comments to the assembly code, and wrote another simplified version in Action!, the closest thing I had to C. I printed out all three code versions, as well as some sample screen dumps. They helped me get the job, and my first task there was to write a CGA screen dumper in Intel assembly for a color Epson dot-matrix printer! I still have those printouts, but have not found the disk files. Maybe I'll scan and post some. I did find earlier disk versions, uncommented and maybe buggy. They are here: PRANTIC.zip Here's an early BASIC A+ version (also in above .ZIP): 200 OPEN #3,8,0,"P:" 210 BYTEMAP=2000:PIXEL=3000 220 CLOCKS=0:DIM COL(4) 230 DIM MASK(4):FOR I=1 TO 4:READ MASK(I):NEXT I 240 DATA 192,240,252,255 250 DIM DOT(7,5):FOR COL=0 TO 7:FOR LL=0 TO 5 260 READ J:DOT(COL,LL)=85*J 270 NEXT LL:NEXT COL 280 DATA 3,3,3,3,3,3,3,1,3,3,2,3,1,3,2,1,3,2,1,2,1,2,1,2 290 DATA 0,1,2,0,1,2,0,1,0,0,2,0,0,0,0,0,0,0,0,0,0,0,0,0 1000 WIDTH=PEEK(559)&3 1001 POKE 559,0 1010 IF WIDTH=1 THEN WIDTH=128 1020 IF WIDTH=2 THEN WIDTH=160 1030 IF WIDTH=3 THEN WIDTH=192 1040 DIM PFCOL(4):FOR I=0 TO 4:PFCOL(I)=PEEK(708+I)&14/2:NEXT I 1050 DIM CLOKS(7):FOR I=0 TO 7:READ CLOKS(I):NEXT I 1060 DATA 4,2,2,1,1,1,1,.5 1070 DIM DBYTS(7):FOR I=0 TO 7:READ J:DBYTS(I)=J/8:NEXT I 1080 DATA 2,1,2,1,1,2,2,1 1082 DIM SLINS(7):FOR I=0 TO 7:READ SLINS(I):NEXT I 1084 DATA 8,4,4,2,1,2,1,1 1090 DLLC=DPEEK(560):CHRSET=PEEK(756)*256:DONE=0 1100 WHILE NOT DONE 1110 INST=PEEK(DLLC)&127:DLLC=DLLC+1 1120 MODE=INST&15:INST=INT(INST/16) 1130 IF MODE=1:REM JUMP INSTRUCTION 1140 DLLC=DPEEK(DLLC) 1150 SLINS=1:CLOKS=WIDTH:COL=PFCOL(4):GOSUB PIXEL 1160 IF INST&4 THEN DONE=1 1170 ELSE 1190 IF MODE=0:REM BLANK LINES 1200 SLINS=INST+1:CLOKS=WIDTH:COL=PFCOL(4):GOSUB PIXEL 1210 ELSE 1215 IF INST&4 THEN DDLC=DPEEK(DLLC):DLLC=DLLC+2 1220 IF MODE&8:REM BIT-MAPPED MODES 1230 BMODE=MODE&7 1235 CLOKS=CLOKS(BMODE):SLINS=SLINS(BMODE) 1240 FOR I=0 TO 4:COL(I)=PFCOL(I):NEXT I 1250 FOR I=0 TO WIDTH/CLOKS(BMODE)*DBYTS(BMODE)-1 1260 BYTE=PEEK(DDLC+I):GOSUB BYTEMAP 1270 NEXT I:DDLC=DDLC+I 1280 ELSE :REM CHARACTER MODES 1290 BMODE=10-MODE:IF BMODE=8 THEN BMODE=7 1295 CLOKS=CLOKS(BMODE):SLINS=SLINS(BMODE) 1300 FOR J=0 TO 7 1310 FOR I=0 TO WIDTH/CLOKS(BMODE)*DBYTS(BMODE)-1 1320 FOR K=0 TO 4:COL(K)=PFCOL(K):NEXT K 1330 NAME=PEEK(DDLC+I) 1340 IF MODE<6:REM 128 CHAR. SETS 1350 IF MODE<4:REM REVERSE VIDEO 1360 IF NAME&128 THEN COL(1)=PFCOL(2):COL(2)=PFCOL(1) 1370 ELSE 1380 IF NAME&128 THEN COL(2)=PFCOL(3) 1390 ENDIF 1400 ADDR=(NAME&127)*8+J+CHRSET&64512 1410 ELSE 1420 COL(0)=PFCOL(INT(NAME/64)) 1430 ADDR=(NAME&63)*8+J+CHRSET&65024 1440 ENDIF 1450 BYTE=PEEK(ADDR):GOSUB BYTEMAP 1460 NEXT I 1470 NEXT J 1480 DDLC=DDLC+I 1490 ENDIF 1500 ENDIF 1510 ENDIF 1520 ENDWHILE 1530 CLOSE #3 1535 POKE 559,34 1540 END 2000 MASK=256*(16*DBYTS(BMODE)-1) 2010 FOR K=1 TO 1/DBYTS(BMODE) 2020 BYTE=BYTE*16*DBYTS(BMODE)=BYTE&MASK/256 2030 IF BMODE=7 THEN P=( NOT P)+2 2040 IF P=0 THEN P=5 2050 COL=COL(P-1):GOSUB PIXEL 2060 NEXT K 2070 RETURN 3000 IF SLINS>4 THEN RETURN 3005 IF WIDTH<>160 THEN RETURN 3010 IF CLOCKS=0:REM START NEW LINE 3020 ? #3;"..A";CHR$(2*SLINS);".L@."; 3030 ENDIF 3040 CLOCKS=CLOCKS+CLOKS:IF CLOCKS=WIDTH THEN CLOCKS=0 3050 FOR L=0 TO 6*CLOKS-1:LL=L-6*INT(L/6) 3060 PUT #3,DOT(COL,LL)&MASK(SLINS) 3070 NEXT L 3080 RETURN 16 Quote Link to comment Share on other sites More sharing options...
ClausB Posted February 9, 2015 Author Share Posted February 9, 2015 Printout of title screen I did for PDI: 6 Quote Link to comment Share on other sites More sharing options...
ClausB Posted February 9, 2015 Author Share Posted February 9, 2015 GTIA mode rendering and the BASIC program for it: 7 Quote Link to comment Share on other sites More sharing options...
ClausB Posted February 9, 2015 Author Share Posted February 9, 2015 And, of course: 6 Quote Link to comment Share on other sites More sharing options...
flashjazzcat Posted February 9, 2015 Share Posted February 9, 2015 Very neat indeed. Wanted something like this in the 90s but couldn't figure out how to write it. Concise and clever. Quote Link to comment Share on other sites More sharing options...
+David_P Posted February 9, 2015 Share Posted February 9, 2015 Neat. Combine that with the G: driver from ANALOG #35 (and run in in an extended memory bank) and you'd have the ultimate printer dump combination. 2 Quote Link to comment Share on other sites More sharing options...
GlowingGhoul Posted February 10, 2015 Share Posted February 10, 2015 Impressive! Quote Link to comment Share on other sites More sharing options...
ClausB Posted February 10, 2015 Author Share Posted February 10, 2015 Thanks! Here's the original Franglais screen rendered by a modern emulator. Notice that PRANTIC failed with the yellow text, because it is really drawn in black, and a yellow PMG block behind it shows through. 1 Quote Link to comment Share on other sites More sharing options...
kenjennings Posted February 10, 2015 Share Posted February 10, 2015 Exceptional! The most I ever did was write something to make printer dumps of text/program listings in the Atari font. Remembering the fun.... Quote Link to comment Share on other sites More sharing options...
ClausB Posted February 11, 2015 Author Share Posted February 11, 2015 A few more, including maps I drew for a planetarium program I never finished: 7 Quote Link to comment Share on other sites More sharing options...
_The Doctor__ Posted June 5, 2015 Share Posted June 5, 2015 Did you ever get the time to type those print outs of the non buggy finished versions in? I really love those printouts Quote Link to comment Share on other sites More sharing options...
ClausB Posted June 7, 2015 Author Share Posted June 7, 2015 Thanks! No, I don't want to retype them. They must be on a floppy somewhere. I just have to look. I could try scanning them. Does OCR work on dot-matrix text? Quote Link to comment Share on other sites More sharing options...
_The Doctor__ Posted June 7, 2015 Share Posted June 7, 2015 If you get the image straight as possible dot matrix OCR's very nicely, maybe a scan, ocr, touch up and import into the Atari? Text files can be sent to entered into basic, yes? Quote Link to comment Share on other sites More sharing options...
Kyle22 Posted June 15, 2015 Share Posted June 15, 2015 Yes, E."D:BASICPGM.TXT". You should make sure it's ATASCII first. Tabs to spaces, $0D$0A (CR/LF) to $9B (EOL). Quote Link to comment Share on other sites More sharing options...
a8isa1 Posted April 1, 2018 Share Posted April 1, 2018 And, of course: IMG_20150209_174415.jpg ClausB, this is off topic but did you do the avatar for your ACE-80? Just curious. Quote Link to comment Share on other sites More sharing options...
ClausB Posted April 1, 2018 Author Share Posted April 1, 2018 An artist coworker drew it and I digitized it. Quote Link to comment Share on other sites More sharing options...
_The Doctor__ Posted September 30, 2019 Share Posted September 30, 2019 Wonder if the disks turned up... 1 Quote Link to comment Share on other sites More sharing options...
ClausB Posted October 5, 2019 Author Share Posted October 5, 2019 Hate to admit it, but I still haven't connected a drive in years. Quote Link to comment Share on other sites More sharing options...
_The Doctor__ Posted October 5, 2019 Share Posted October 5, 2019 our drives stand ready to extract the back log of disk data... Quote Link to comment Share on other sites More sharing options...
_The Doctor__ Posted April 4, 2020 Share Posted April 4, 2020 Now you've gone and done it, you alerted and pointed us to your fine work again... and now the time is here … time to connect a drive and find those later versions and revisions we were salivating for. Quote Link to comment Share on other sites More sharing options...
ClausB Posted April 7, 2020 Author Share Posted April 7, 2020 I'm comparing the printed, commented listing with the RPRANTIC.SRC.txt file above. The printed version used 480 printer dots per line, not ideal for Atari's 320 pixels. The SRC file uses 640 dots, and is likely the version which made the image printouts above. I'm in the process of typing the comments into the SRC file and verifying the code. I'll post it when finished. 3 Quote Link to comment Share on other sites More sharing options...
ClausB Posted April 7, 2020 Author Share Posted April 7, 2020 Here it is. Have no way to test it now, but I was careful not to change code, just comments. Labels starting with L correspond roughly to line numbers in the BASIC code above. PRANTIC.SRC.txt 1 2 Quote Link to comment Share on other sites More sharing options...
