Sign in to follow this
SoundGammon
New type LEAF switches!
Found these on E-Bay. Can't wait to get some! Anyone else try them before?
Hate those click switches!
Here's the link:
http://www.ebay.com/itm/221620433367?_trksid=p2060778.m1438.l2649&ssPageName=STRK%3AMEBIDX%3AIT
Gold-plated contacts. No tarnishing nor degradation results in no deterioration in response. The contact leaves and the external connections are fully gold plated.
  • Low inertia The moving part of the button is ultra-light and only 10mm deep, unlike other types where the plunger extends the full depth of the button.
  • No Click Leaf switch means no clicking micro-switch.
  • No Plunger Spring The body of the button contains no large spring. This results in a uniquely low actuation force of 45 grams for the entire button.
  • No Hysteresis. This is the difference in button depression for the contact close and open points. On these buttons the position is the same, resulting in maximum repeated actuation performance. On micro-switch buttons this "dead" distance can be up to 1.5 mm.
  • Concave top. Most serious gamers prefer the classic concave tops over the convex which are commonly used on Japanese low-inertia buttons.
  • Robust. The limit stop of the button is supported by the button body not the switch so no chance of switch damage owing to over-enthusiastic play!
  • Compact integral design. No fiddly assembly after fitting through the panel. Totally enclosed leaf-switch contacts.
  • Economic Despite their performance these are similar in price to standard arcade buttons and the price is all-inclusive, nothing extra to pay for add-on switch options.
  • Nut & Thread Fixing. We have retained the traditional threaded fixing rather than the push-in design of certain other low-inertia buttons as we believe this gives the most effective permanent mounting in all types of panel up to 19mm (3/4 in).
Edited by SoundGammon
Except for the delay...frustrating playing Donkey Kong because of it!
JUMP! No, too late...fall...
There's also a way to modify joysticks and other switches to use leaf switches...here's a pic:
