wyerd
UDS-10 Arrived. Connection issues.
Firstly, The UDS-10 is on the LAN and can be seen and connected to via Telnet.
I've followed Omega's manual and loaded Telco to try at least to connect to the Heatwave BBS before trying Stuarts Browser, but I'm having issues.
Telco loads fine from the HxC once I stripped it from the original disk image to the format that could be read. I then configured the UDS-10 as explained in Omega's manual and connected the CorComp card in the PEB to the UDS-10 using a rewired null modem cable as shown again in Omega's Manual.
When I select the Terminal option from the main menu, I get a flashing cursor, but nothing happens when I try to enter the dial string commands. Also, the CorComp RS232 lights don't come on, but they do when I use the Diagnostics option 3 from the EX Basic 2.7 Cart.
Obviously I doing something wrong, or something's not working as it should. I'd be grateful for any help and pointers.
Thanks,
David.
Hi Wyerd,
I'm just about to leave the house so I don't have a lot of time to get detailed, but ensure the following settings on the UDS-10 from your telnet connection from the PC.
ON THE UDS-10
Baud Rate 2400
IFMODE 4C
Flow 02
Connect D6
You might want to set your port setting to 23 instead of 10001 (I'll explain why later after you get all setup and running)
IN TELCO
Under terminal setup make sure the "Q" option for baudrate is set to 2400.
Under the "R" option make sure it's set to 8N1
If you do not have your BAUD RATE set to match in TELCO, the UDS-10 will not 'hear' the TI to communicate, although you *MAY* get some junk characters on the screen. If the baud rate and ever thing is set properly, as a test, you can try to telnet over your local network to the PC is the communication dead both ways or does the data flow to the PC but not to the TI?
GOOD LUCK!
Thanks for info. I configured the UDS-10 to your settings and then performed the following:-
Telnet running on PC to IP address of UDS-10
Press a key in the terminal session on TI, nothing is shown on TI terminal screen, but get square character in the Terminal window on PC.
Press a key in the terminal session on PCI, character shown on PC Terminal session, but nothing on the TI.
At least something's happening!
On TI I changed duplex from (F)ull to (H)alf and the characters are being shown on the screen, but not on the terminal session on the PC, just the same squares.
Do you have a TI branded RS232 card you could use instead of the Corcomp card?
No, just the CorComp.
I would double check the pins are correct, usually when you cannot input any characters from the terminal, usually Pins 2 and 3 are reversed.
On the TI pins 2 and 3 are reversed than what the standard modem pinouts are.
You should be able to get it to work simply with :
TI UDS
2 <----------------------------- 3
3 ------------------------------> 2
5 -------------------------------> 4
7 -------------------------------- 7
20 <------------------------------- 5
I seem to remember that there are a few subtle differences between the CorComp RS-232 and the TI or Myarc cards. That may be causing the issues here as well--but I don't remember what the issues were right now, just that they existed.
Hey Chris, that should work alright, I'm just hoping it's not his RS-232. If I remember right this is the one that took down his P-Box when the TI clam shell bit into it.
Hmmm, I just learned something new. I was unaware of any functional differences.
Yes, I have also registered that differences between TI- and Corcomp-Card when trying to connect the HDX
at least, when I (while desperatly testing essential RS232-connect withTelCo), I got an echo on the PC from the TI writing,
but I did not with the CorComp (in the same cable- and mood-constellation).
First, I thought that my (never tested) Corcomp passed away, but I can remeber, days later,
with one of my 100 cables, the CorComp ones echoes....
So this was also my conclusion, in fact, that there must be a "difference".
(The only other option in this situation was to get mad and jump out of the windows, (incl. CorComp :)
If you have FB, here are some toxic Desperado-fotos:
https://www.facebook.com/media/set/?set=a.327976140727679.1073741832.326551627536797&type=3
TI UDS
I have the cable wired up as follows
TI
1-Black
2-Red
3-Brown
5-White
7-Blue
20-Green
UDS-10
1-Black
2-Brown
3-Red
4-White
5-Green
7-Blue
TI-UDS
 2-3
 3-2
 5-4
 7-7
 2-5
So it looks right.
Just my luck! :mad:
Did you get a copy of << THIS >> with your card Wyerd?
Look at the bottom of the document... could the jumper be missing or set incorrectly?
the pinouts are in the CorComp manual on the FTP site..but here it is below..
RS232/1
1 - Ground
2 - RXD
3 - TXD
6 - DSR
7- Ground
20 - DTR
RS232/2
1 - Ground
6 - DSR
7 - Ground
14 - RXD
17 - TXD
19 - DTR
Edited by Cschneider
When you bought the UDS10 and if it came with all the box candy then you should have a 25 pin to 9 pin modem cable.
If you have a PC with a communication port you can always hook it up there just to make sure you issue the AT commands and that it is functioning to help rule out your RS232 card.
Pin 6 is not used on the UDS-10. I was surprised at the time to see that it did not hook up like a modem.
Yes it did, but none of my highly modern PCs with USB3, Sata3 have errrrrr serial ports, not even headers. I might have an old motherboard somewhere though with the header port and a cable in my box of "might be useful someday" old junk.
I've studied both the PHP1220 and the CorComp RS232 pin outs and they're exactly the same.
I think the issues around the CorComp is just with DSR. I personally never had an issue with the CorComp cards. I switched over to TI when the HDX came out and the author of S&T BBS code said the TI was the most stable of all the RS232 cards.
yes, and if you have ie a PL-2303 USB-toRS232 for 5$ from china, then you may have some other issues (!) (really)
Edited by schmitzi
