Song Player Repository?
You can find the driver(songplay.h) and music data(song.h) for Druid Chip in the Medieval Mayhem source.
The driver has been slightly modified from the original so the music will play at the correct speed for both NTSC and PAL frame rates. Search for COMPILE_VERSION to find the IF/ELSE/ENDIF block the playback speed.
Thanks for the link, Darrell.
Interesting modification for PAL/NTSC speed. I have wondered about the same problem lately and modified Paul's driver to use fractional math here. Which also allows very fine tuning of the music speed, but makes it a bit more complicated to have other stuff in sync with music.
There are a few other changes, mainly for space efficiency and a minor bug fix. When it is done, I will post it here.
