sirlynxalot #1 Posted March 15, 2015 (edited) I recently got Jag Doom, a used cartridge. All the levels seem selectable from the main menu, probably bc the last owner beat them all... But is there any save feature like in wolfenstein? If I play the game in multiple sittings, do I always have to start a level with only the pistol (unless I use a cheat code)? If that is the case, is there anything done to compensate for this, like more advanced guns are more commonly available in later levels compared to the pc version? Edited March 15, 2015 by sirlynxalot Quote Share this post Link to post Share on other sites
Rick Dangerous #2 Posted March 15, 2015 There isn't a last save point like wolfenstein. Just select the level you want to play next. Either use the weapons given to you or use a code to stock up. 1 Quote Share this post Link to post Share on other sites
NeoGeoNinja #3 Posted March 15, 2015 There isn't a last save point like wolfenstein. Just select the level you want to play next. Either use the weapons given to you or use a code to stock up. Exactly this. It's pretty much treating it the same as if you die; you start with only the pistol. Like Travis said, pick the level you last played and do the weapons cheat to re-stock what you lost Quote Share this post Link to post Share on other sites
