blacka013 #1 Posted March 17, 2015 Hi All, hope someone can help. I have a 1050 drive fitted with a Happy board. After about 10 - 15 minutes the drive will start to spin for a few seconds and then stop. This continues until the drive is powered down. The drive needs to be left for about 30 minutes before it can be used again. I suspect this is a heat related fault, so does anyone have any ideas what is causing the fault? Thanks in anticipation. Andy 1 Quote Share this post Link to post Share on other sites
+bob1200xl #2 Posted March 18, 2015 Check the power diodes on the board. If they are hot (careful - they can be very hot), try replacing the big filter capacitors. If the diodes are not too hot (wet your finger and touch one - got sizzle?), try replacing the big filter capacitors. Get some 'circuit cooler' and spray it on the ICs while it is failing - not too much and not all over the place. If the bad part cools down, the drive works again, right? Bob Quote Share this post Link to post Share on other sites
Kyle22 #3 Posted March 18, 2015 Capacitor tops should be flat, not rounded or heaved up. A capacitor that is heaved or swelled up in any way is bad and should be replaced. Just a little info before you burn your fingers on the diodes Quote Share this post Link to post Share on other sites
thorfdbg #4 Posted March 18, 2015 If the diodes run hot, also replace them by stronger models. I had a problem with them on my 1050 quite some years ago, and the diodes of the voltage-doubler circuit are really under-dimensioned. The board underneath was already changing its color to brown when the drive stopped working. After replacing them, the drive worked fine again. Quote Share this post Link to post Share on other sites
blacka013 #5 Posted March 18, 2015 Ok all, will have a look at the areas mentioned tonight. Just a question thorfdbg, which are the doubler diodes? Many thanks Andy Quote Share this post Link to post Share on other sites
blacka013 #6 Posted March 21, 2015 Okay, I have checked all the areas advised on and I can't find a problem. All diodes are slightly warm after about half an hour. Checked everything against another drive I have which is working, and that is warmer than the faulty drive. Any thing else I should be checking? Many thanks Andy Quote Share this post Link to post Share on other sites
