Omega-TI
Microsoft Multiplan for the TI -- Cartridge Inquiry
On 5/29/2015 at 10:04 AM, pnr said:
The '673 document is the main specification, the '672 document is an addendum/errata to the former. It says that once upon a time Microsoft had a reference implementation in C for this spec, and also that the spec should be complete enough to write one from scratch. Has anyone ever attempted a disassembly & analysis of the Multiplan cartridge ROM?
This p-code looks quite well done, allowing substantial programs in little memory. It has a single 64K data space for global data and the stack, and an essentially unlimited segmented code space: the code is divided up into relocatable "segments" that are paged in and out as needed. Also, the p-code looks very tight, packing many C operations in a single byte.
If there is a reimplementation of this, and if someone has an old Microsoft C compiler (i.e. one of the DOS 16-bit compilers) that still supports generating this p-code, we would have another great tool for writing new software.
Just found the below book online. If you read through the foreword you learn that Microsoft Multiplan was compiled on a PDP-11 running unix and then the p-code was offloaded to the (home) computer where it gets executed by the P-interpreter.
http://cs.brown.edu/courses/cs190/2008/documents/restricted/Writing Solid Code.pdf
Sub-titled "Microsoft's Techniques for Developing Bug-Free C Programs."
From web literature we know that Microsoft Multiplan was written to use a very clever p-code compiler system created by Richard Brodie. This p-code system, which was also used later by Microsoft Word, allowed Microsoft to target Multiplan to a huge number of different 8-bit and 16-bit computer systems. (Charles Simonyi once estimated that Multiplan was available for 100 platforms.)
Any witness from MS or TI from that era?
I had a document documenting the C interpreter that was used in TI Microsoft Multiplan. But sadly I have lost it before getting a chance to scan. It was a copy of something printed with a matrix printer a long time ago. I’m sure it must be somewhere here in the house. I have looked for it a couple of times already in the last few years, but alas didn’t manage to find it so far.
Version 6 of Microsoft C was able to generate that compact interpreted code.  It did not last that long, I think version 8 could not.
Parts of Word 1.1 used it.
That is most interesting. Is there any documentation available on that particular aspect of Microsoft C ?
Yeah, actually Microsoft used P-Code way before VB1 - AFAIK their C compiler was able to emit it and several of their products were compiled as P-Code instead of machine code, which helped to save disk space (a premium at the time, especially considering it could make a difference on how many floppy disks they shipped) and quickly port their applications to other emerging platforms at the time (like the Macintosh).
Both Microsoft's P-Code and Java were really inspired by UCSD Pascal which only emitted P-Code to be executed by a runtime they implemented quickly in a lot of systems (including the original IBM PC).
Bumping this again.
I'm interested in the "Microsoft C Pcode spec used for Microsoft Multiplan"
I searched the Yahoo message list archive from whtech, but the attachments are not there.
I did some research. I heard back from a former Microsoft employee that worked there in the 90s, who said the P-code interpreter used in, for instance, Office 4.0, had evolved from the 1981 spec.  I guess that the MS C compilers 6.0 and 7.0 might have incompatibilities with the P-code interpreter used in 1981 for Multiplan.
On 5/29/2015 at 3:04 AM, pnr said:
I think the documents you refer to were posted in the yahoo group some 5 years ago:
https://groups.yahoo.com/neo/groups/ti99-4a/conversations/topics/72673
https://groups.yahoo.com/neo/groups/ti99-4a/conversations/topics/72672
Quote
Date: Sat, 06 Mar 2010 09:29:08 -0000
To: [email protected]
Subject: Microsoft C Pcode spec used for Microsoft Multiplan
Hi TI friends,
I just came across ebay item: 130372308372
This is what the description says:
"Microsoft C Pcode Specification - 1981"
This document describes the virtual machine that can execute the P-Code generated by Microsoft's  C compiler.  The document is original documentation used by TI developers to port Multiplan to 9900 based computers and more specifically the TI-99/4A. It is 22 pages with another 9 page update section.
Does anyone knows something about this:
1. Does Microsoft multiplan run in an interpreter ?
2. What language does the interpreter runs in; 9900 assembly or GPL ?
3. Has anyone ever seen this Microsoft C cross compiler. Would be interesting to know on what platform the compiler ran on.
4. Would be cool to see the source code for Multiplan ;-)
Cheers
Filip
Quote
Date: Mon, 26 Apr 2010 12:00:01 -0700 (PDT)
Subject: Microsoft C P-Code specification
I'm sorry if this is not protocol, but I recently won Microsoft C P-code specification and wanted to share this with the TI community.
There will be another document coming as well.
Quote
To: <[email protected]>
Date: Tue, 27 Apr 2010 08:55:31 +0200
Subject: Re: [TI-99/4A] Oops
I managed to download the unique pdf file, named 20100426122526859.pdf,
4.92 MB. It starts as follows:
"Microsoft C PCode Specifications - 1981
1. Introduction
This document describes the virtual machine that can execute the P_Code
generated by Microsoft's C Compiler.
The goals of this design are:  1. High static code density  2. Simple and
efficient implementation of the virtual machine on various
microprocessors.  3. Open ended design which will be able to accomodate
foreseen and unforeseen future extensions. Foreseen extensions include a
segmented swappable code section, coroutines, long integer aritmetic, and
passing of variable number of parameters ..."
Paolo
Quote
Date: Mon, 26 Apr 2010 18:43:57 -0400
Subject: Re: [TI-99/4A] Microsoft C P-Code specification [1 Attachment]
came through fine here
9 page pdf, several pages have red notes added with marker
top of page 1 Jan 22 16:42 1982 inter82.doc
last 3 words on page 9 immediately after the directory
Quote
Date: Mon, 26 Apr 2010 19:48:19 -0500
I got the same pdf file as described.  It was 2.4 MB in size on my Mac
I also got the second one which was 22 pages long and 5.2 MB in size.
Joel
Note that on a second look, the email messages were only about 20KB and attachment were only URLs like to xa.yimg.com
On 4/13/2020 at 7:24 PM, arcadeshopper said:
i have backups of the group.. I'll see what I can do
As the yahoo groups are no longer alive, were you able to find something?
8 minutes ago, arcadeshopper said:
I uploaded everything I have to whtech
http://ftp.whtech.com/YAHOO%20group%20backups/TI99-4A/FILES/
Sent from my LM-V600 using Tapatalk
Thanks, took a quick look, but doesn't appear to be there. So the search continues, it will popup someday. As said I'm 100% sure I have it somewhere in the house. Question is where.
Did some more searching and found the following on one of my hard drives. May it be kept forever on the internet....
Specification pcode virtual machine for running Microsoft C compiler code.pdf
p-code interpreter updates of microsoft C compiler.pdf
  • Thanks 3
Specification pcode virtual machine for running Microsoft C compiler code.pdf 4.92 MB · 4 downloads
Awesome! Thank you!
1 hour ago, retroclouds said:
If anyone is willing to make a new "clean" version of the documents, that would be awesome.
I'm dictating them to Siri as I read out loud. Then I hit the code dictionary so I'm typing.
Sample...
The definitions of the instructions are written in C-like notation. Any other implementation with the same results is acceptable.
NOP		No Operation
LDFN		Load From Frame
LDFAN	Load Erase Address
LDGN		Load Global
LDGAN	Load Global Address
LDT		Load T
STT		Store Into T
LDIT		Load Indirect Through T (Word pointer)
STIT		Store Indirect Through T (Word pointer)
LDIBT	Load Indirect Byte Through T
STIBT	Store Indirect Byte Through T
LDIN		Load Indirect. Word on the stack is taken to be a word pointer. The increment N may be used to address a field in a data structure. *(S-1) = *(*(S-1)+N)
LDIBN	Load Indirect Byte. Word on the stack is byte pointer. The increment N may be used to address a byte field in a data structure. *(S-1) = *((CHAR *) *(S-1)+N)
I am amused by the Octal numbers everywhere in the spec in 1981. Rumor was, the first compiler implementation was on a PDP-11.
From my bookshelf, I see that by 1978, Hexadecimal ruled in 8080A and 8088 assembly language.
A lot of stuff back before 1980 showed up first on PDP-11 machines. The earliest text adventures were developed and used as a troubleshooting aide on them. I remember regularly putting the diagnostic pack into the hard drive of the one I used in Berlin and booting the game to give the system a thorough workout during preventive maintenance sessions.
I'm working on this a little each day. I'm up to page 8 of 22.  I'm making tiny revisions for syntax, and noting them with "original reads:".
There are a couple weird bits so far, in the opcode definitions, which are in C syntax. Octal, with some strange operators (PDP-11 no doubt.)
I'm not 100% sure of AND, OR and other opcodes. Starting with ADD, they are defined as:
ADD	Add
	W2 = *--S;
	W1 = *--S;
	*S++ = W1 + W2;
AND	Logical And, same with W1 & W2
OR	Logical Or, same with W1 % W2
NOT	Bitwise Logical Not:
	*(S-1) = ^*(S-1)
REP	Repeat Operand
	S++ = *(S-1)
(S is the stack pointer, W1 and W2 are temporaries)
I think they mean "Bitwise Or" where they call it Logical. Since they occur in the arithmetic operations, I think they should be bitwise like most ALUs.
For coding logical operations, I guess you have ZR and NZ, Jump if Zero/Not Zero. I don't see any other Boolean instructions.
Taking my changes one at a time:
AND.  & to & (no change)
OR.    % to |
NOT.   ^ to ~ (bitwise, one's complement)
REP.   *S++  Obviously an oversight. S++ is not assignable (lvalue)
Here are the bit field load/store opcodes. & is obviously bitwise here.
LDO F1	Load Field, F1 is an instruction byte.
	Loads field from word on the stack. Field is described by width of Field-1 stored in 4 bits and a right shift stored in the next 4 bits.
  DBITWIDTH = F1>>4;
  DBITSHIFT = F1 & 017;
  *(S-1) = (*(S-1)>>DBITSHIFT) & (2 POWER (DBITWIDTH+1) - 1);
STO F1	Store field. Pointer to word is on the stack above the datum. Field descriptor format as above.
	MASK = 2 POWER (F1>>4+1) - 1;
	PW = *--S;
	W = *--S;
	*PW = (*PW & !(MASK << DBITSHIFT)) \ ((W & MASK)<<DBITSHIFT);
Change \ to |
Change ! to ~
The MASK will be ok in  16-bit arithmetic.  DBITWIDTH+1 is from 1 to 16.
2^1 - 1 = 1, ok
2^15 -1 = 32768 - 1 = 32767 (7FFF), ok
2^16 - 1 = 65536 - 1 = 0 - 1 = 65535 (FFFF), ok
Equivalent to
2 << DBITWIDTH
2 << 0 -1 = 2 - 1 = 1
2 << 14 - 1 = 32768 - 1 = 32767 (7FFF)
2 << 15 - 1 = 65536 - 1 = 0 - 1 = 65535 (FFFF)
  • Thanks 2
