Dexter
A few random mods for the TI-99/4A to get rid of some annoyances
A few random mods for the TI-99/4A to get rid of some annoyances!
First thing that bugged me was that there’s no reset button.
I found the solution in the TIM9904A datasheet. On page four, there is actually drawn an optional reset button! :)
This hardware reset works ALWAYS. Now I’m using the reset button on a Navarone Cartridge Expander, but sometimes it doesn’t react on pressing the button.
DSAP0044620.pdf
Secondly I did the Alpha Lock key / Joystick mod, to not always have to release the Alpha Lock key for playing a game.
http://www.mainbyte.com/ti99/console/alpha_lock.html
Third, I did the “Powering the joystick port” mod. I wanted to have the TI’s 5V to power the nanoPEB. I believe it’s much healthier for the nanoPEB to use the perfectly stable 5V of the console, plus the nanoPEB will be powered up at the same time as the console.
http://www.nouspikel.com/ti99/titechpages.htm
Fourth, the Joystick adapter, this is a real relief!!!! Now I finally can use my favorite joystick and improve on Parsec and Q Bert. :)
http://www.mainbyte.com/ti99/hardware/cables/joystick.html
Edited by Dexter
  • Like 7
wow, respect Dexter !! well done. I would be glad to be able to do such work.
next project please: the fluxcard-compensator :) :)
Yes indeed, the 5V is available on the expansion port, but not passed through the speech synthesizer.
Dexter, I like that 5V nanopeb supply, good idea!
btw it looks that your RS232 interface is working, is this also a F18-v1 software running on it.
Both Ralf (schmitzi) and myself are unable to get the RS232 to PC-COM port to work.
It works out pretty well, NEVER have issues when powering up.
Yes, I have it working, it's the nanoPEB V1 with the F18 V1 firmware.
I'm using one of these cables:
http://www.reichelt.de/AK-143/3/index.html?&ACTION=3&LA=446&ARTICLE=3971&artnr=AK+143&SEARCH=AK+143
Next time I order from that store, I could order a cable for you.
I've attached the version of CFHDXS1 I'm using. (dsk)
Edit:
I hope this helps, otherwise I would guess the 9902 is not functioning correctly. Did you get any responce using terminal programs? BTW, I'm using a real COM port on the PC side.
Edited by Dexter
I use this one schmitzi:
ti99hdx73a
ti99hdx73a.zip
Did you get any progress with hdxs1 yet? I guess you're on it now. :)
Edit:
I am using the same version of Fred Kaal for this. I even made the cross-over cable exactly as yours with the pins.
No responses with PC-side Tera Term (or resetting with DosBox), but always use the USB-Serial (Profileric), I know the issues,
but it works with all routers, switches, and event TI PHP 1700 RS232 and PHP 1200 (PEB box) RS232 all okay, except NanoPEB.
so guess it is the 9902 chip (is it put the right way into the socket? (I see a little mark and it matches the mark on the chip itself, like a little cut)
Is there any software to test if it is working?
Ralf already did the DU2K (see Facebook and we see the PIO and RS232, strange that we see PIO on a serial device, but prob. forgot to take
it out from the firmware)
... I also used CommFront 232Analyser software (and see the differences with the other RS232s I have lights. like DTR, CTS, DCD,
but with nanoPEB not, only DSR if I remember) and once in a while a garbage message (I tried 2400 9600, 19200 baud,etc.).
Chipset 9902 issue or nanoPEB firmware issue? (rest works okay, diskdrives, 32K).
ti99hdx73a
attachicon.gifti99hdx73a.zip
I tried both 73a and 73c no luck
(but the 73c works with the normal RS232 and PEB box
See details: http://www.globeron.com/freedownload/TI-99-4A-PC-transfer-v1.12.pdf
(from Facebook, I do not know how to link it otherwise:)
On the PC I used Tera Term and for analysis: 232Analyser http://www.commfront.com/commfront-downloads.htm I tested with the RS232 (PHP 1200) in the box (DSR,CTS,DTR lights up) transfers all okay. I tested with RS232 PHP 1700 sidecar (DSR, CTS,DCD,DTR all light up) transfer all okay. Then I made the x-over cable (http://advancedtubular.com/wiki/index.php...) and also tried the x-over null modem db9 plug, both solutions only light up DTR.
ti99hdx73a
Nope. Also with my very new cable, no success, sorry. And this was trial#~100, cable #21 (in fact) , PC (with serial) #4, and hour #~40
All tests were with TI-HDX-Server 6.1a, 7.2a, 7.3a and 7.3c on the PC-side and CFHDXS1 v1.2 on the nanoPEB´s-side.
With and without the nanoPatched-version. All this in many different combinations.
The normal CFHDX-1.2er Version, with my big PEB, ran immediatley.
Then I checked all possible serial cards, all PCs, all nullmodem-adapters, and all cables.
I have tested EACH of them with 3 real-ironPEBs. EACH works.
So for me, I came to the conclusion that it is an issue on my nanoPEB.
And another indicator, as a matter of fact, I have 4 more nano´s which are complete defective.
I want, but I don´t need to get it running anymore, as I am using now the Lotharek´s HxC-drive since some months.
There is no prob, of course, as this is totally other way of doing. But I am sure now, it´s not a big, but a nano-prob.
Here (to get an impression how much testing-work for 0 it was) the link to my negative equipment-tests with the nano:
https://www.facebook.com/media/set/?set=a.327976140727679.1073741832.326551627536797&type=3&hc_location=ufi
And some positives tests, here with Real-Iron-PEB, but have pics only on tests wih UDS.
(I made no pics with the HDX, just tested it 2 times, works, and went away, not to destroy anything :x .
But for me, the HDX also makes no sense at this point, with mounted HxC´s.
https://www.facebook.com/media/set/?set=a.353892781469348.1073741856.326551627536797&type=3&hc_location=ufi
and
https://www.facebook.com/media/set/?set=a.353852204806739.1073741855.326551627536797&type=3&hc_location=ufi
/EDIT: Globeron: I also have done many tests on the nano with Telco, just tried to get an echo. -> Nope /
Edited by schmitzi
@globeron
What I would do next is look if there is any activity on pin 2 of the 9902. It’s 5V inactive, i.e. when it does nothing, it should measure 5V. You can check for activity with several devices:
· oscilloscope
· logic analyzer
· logic probe
· LED with a 1k resistor in series
I’d simply try that with the CFHDXS1 program, while trying to access the HDX1 device.
You wrote you have a TI RS232 Cart for the PEB, I’d guess there is the same chip inside. I’d take the chip out of the nanoPEB and try it in the RS232 Cart.
There is still plenty to test.
@schnitzi
That’s really a shame that it still doesn’t work. :( As you concluded, it’s most likely an issue with the nanoPEB. There is a good chance that the 9902 is defective, it’s an old chip, and could be defective before assembling the nanoPEB.
So I’d first try that 9902 chip.
A week ago, I received my F18A!
Replacing the VDP was quite easy, and yes, I didn’t drill holes in my 4A. :D This time I left out the metal shielding, and I put the flat cable between the two plastic halves of the casing.
The F18A demodisk is awesome. Especially with the provided sources!
Thank you very much Matthew and Rasmus!!!
  • Like 4
Thanks schmitzi, I have to say, it’s yet another homemade project! And a very rewarding one. First I searched for a joystick with a rather big casing on eBay. Then I did some shopping at http://www.arcadeshop.de/index.php?cPath=73_104&osCsid=uotfg513j6a375toss0vrd0704
Bought one joystick with a red ball, (you can choose from many colors) and two red buttons. You wouldn’t believe it, but it really improves gameplay a LOT!
Oh, "elite" - Kaufhof?
Could be quite possible, I got this one second hand from ebay.
I also did an Elite 2000, but a friend of mine did the metal work, as I don't have the equipment.
They are still regularly on ebay, but prices are exploding. :(
The bottom one is mine.
This (German only, sorry) video gave me the inspiration:
Here is another one for inspiration:
http://www.instructables.com/id/Xbox-360-PC-Arcade-Joystick/
Chris,
I am using the monitor cable which goes from the TI to 3 Composite RCA Jacks. Will the 2nd mod make any difference with that cable?
You will not need to make any modifications to the cable for this display modification.
If you are going to upgrade to an F18A video then you will not need to do the modification.
The F18A is one of the best upgrades for the 99/4a and is easy to to (no soldering required!).
@Schmitzi  / @arcadeshopper  all,
Guess what  (after how many years) I finally have the nanoPEB RS232 working as well with a PC connection.
(I still need to try the connection from a TI to a TI).
(as I just made the UberGrom RS232 interface for connection to the PC, I thought maybe test this nanoPEB
one more time again).
no clue what the issue was, +5V / 2A power - I do not think so, also not the cabling)
USB - DB9 (MALE), gender changer (FEMALE - FEMALE), cross-connect (MALE, FEMALE), to MALE plug of nanoPEB
settings upload at 38400, 8, E, 1
but I am using a different progra now which might be the case for the PC connection:
of @F.G. Kaal Fred.   NPDSK2PC   (NanoPEB DISK to PC)
NPDSK2PF
NPDSK2PE
NPDSK2PD
NPDSK2PC
