Cybearg Posted May 8, 2015 Share Posted May 8, 2015 For anyone interested, I've made a little command line tool called pngParse that reads a palette png image and a sprite png image and outputs sprite table data formatted for batariBasic or 6502 ASM. bBpP_1.0.0.zip Notes on use: pngParse doesn't approximate colors: it identifies colors between the sprite image and the palette image by comparing r/g/b values, so for your sprite image to accurately be parsed, its colors must exactly match the colors in the palette. pngParse can take custom palettes of 8x16 pixels. Palettes for NTSC and PAL are already included in the attached zip file. if you don't specify a custom palette file, pngParse will expect to find ntsc.png or pal.png (depending on the -P flag) in the same directory. Output will go to output.txt by default. Sprite images must have a width divisible by 8. Sprite images wider than 8 pixels will be parsed as a separate sprite, so you can input a 64x13 pixel sprite sheet and pngParse will output 8 8x13 pixel sprites. Flags: -s "spritesheet.png" Specifies the input spritesheet (required). -p "secam.png" Specifies the input palette image (ignores the -P flag) -o "spriteData.txt" Specifies the output file (output.txt by default) -P Uses the PAL palette (NTSC by default) -D Formats output for the DPC kernel (standard kernel formatting by default) -A Formats output for 6502 ASM (batariBasic formatting by default) Quote Link to comment Share on other sites More sharing options...
+Random Terrain Posted May 8, 2015 Share Posted May 8, 2015 Is that similar to the Graphics Converter that VbB has? Quote Link to comment Share on other sites More sharing options...
Cybearg Posted May 9, 2015 Author Share Posted May 9, 2015 Is that similar to the Graphics Converter that VbB has? ... God dammit! How did I never notice that existed?! Quote Link to comment Share on other sites More sharing options...
