Sign in to follow this
plbyrd
Need help with disk images
I know there has to be utilities out there to transfer files from Windows into ADAMEm DSK images. Right? I've spent the better part of the last day trying to find such a utility and it is escaping me. The closest thing I can find is the block editor in VirtualAdam, but that's obviously not a solution. I'd even settle for solid documentation on the format of an EOS floppy so I can roll my own utility (I have a lot of experience with this stuff on the Commodore platform).
So, someone slap me with a clue hammer and point me at the obvious utility I keep overlooking.
Thanks!
Payton
What kind of files are you trying to transfer? There are several utilities that will transfer files, but I'm not clear on exactly what you are trying to do.
Thanks!
Payton
Thanks for the reply. I want to transfer programs that I write in Assembler over to ADAMEm. You know, cross compiling. I don't care if the tool is gui or command line (would prefer command line capable so I can script execution with MAKE).
I'll be replying to your PM with everything you need as well as a wealth of stuff that you can use for the Wiki page.
Ah, OK...I defer to NIAD...sounds like he's got you covered.
