electrotrains
In development - SD card based Multicart
Hi All,
I thought I'd post to announce my new hardware project - I'm building an SD-card based Multicart.
https://youtu.be/PjkCTXqirv8
Although its far from being finished, it already shows the available ROMs/CARs on the SD card on an Atari menu, and will then reboot to the selected cartridge. At the moment it only supports 8k ROMS and 8-mbit Atarimax ROMs, with bankswitching etc, but I plan to support all cartridge types soon.
Adding a new ROM is simply a case of copying a new file to the SD card - no more flashing ATRs etc.
Not sure if there's any other available hardware that currently does this? I don't have an SIDE or MyIDE.
The hardware is a Altera Max 10 eval board, with my 3.3v cartridge breakout board attaching it to the atari. There's an external 1 megabyte SRAM which cartridges are copied to. Initially the atari boots to a small 8k boot ROM which is stored in dual port memory on the FPGA. The FPGA is also running a soft-cpu to copy files from SD card to SRAM.
I'm planning to make a PCB for this next, with the aim of fitting inside a standard cartridge case. Never done an FPGA board before, so that may take me some time. The boot ROM is also far from finished - I'm having to learn 6502 from scratch.
There are some other possibilities for this too - the same cartridge could be re-programmed e.g. as an atari co-processor/accelerator board. I'm planning to leave a JTAG/USB Blaster header on the board to make this easy.
Robin
Here is something I hope you find useful. Here is the bank switching info I have for programming.
; Express! Professional Terminal Program
; Copyright © 2001 Stephen J. Carden
; This module contains all of the global definitions.
; Compiler: MADMAC Cross Assembler
.atascii ;translate IBM chars to ATASCII chars
; system cart equates
screen equ $bc40 ;change to $9c40 when in ROM!
;screen equ $9c40 ;change to $bc40 when in RAM!
;phone_book: equ $a000 ; when in cartrage
phone_book: equ $4000 ; when in ram
my_crc_low equ $2d00 ;$a200
my_crc_high equ my_crc_low+256 ;$a300
;LFFE4
all_bank equ $d500 ; Steve Tucker Mega Cart
;all_bank equ $d570 ; Express cart latch
;all_bank equ $d5d0 ; Diamond GOS latch
;all_bank equ $d5f0
; ; express cart!
bank0_latch equ all_bank+7 ;$d577 ;highest bank in the cartridge
car_pass equ all_bank+8 ;$d578 ;enable cart pass-thru
passthru_latch equ all_bank+9 ;$d579 ;
cart_off equ all_bank+12 ;$d57c ; cart off
x_cart_tag equ $ffe4 ;d5e8
