Zuckerton #1 Posted June 18, 2015 So I recently added the Arcadia 2001 to my collection. The issue I have is that the seller sent me a 3v DC Adapter and the Arcadia runs on 12v. The 3v adapter powers on the LED, but nothing else. So I purchased a 12v 500mA with a + Center and a - Barrel. However, when I connect THIS DC adapter, I get nothing. The LED doesn't light up at all.Has anyone worked with the 2001? I know it's a bit of an obscure console. Quote Share this post Link to post Share on other sites
CatPix #2 Posted June 18, 2015 Maybe it need the reverse polarity. Or your 12V psu is busted. I have an Arcadia clone but nothing says it should be the same tip. Try maybe a 9v psu from a Megadrive if you have one. 9v should be enough for it. Quote Share this post Link to post Share on other sites
Zuckerton #3 Posted June 19, 2015 The polarity is the same as the 3v that was sent to me (it wasn't listed on the adapter so I had to use a Multimeter to determine it's polarity). The 12v adapter that I got in today is a "switching adapter" that is made to be used to power cameras. I bought it because it matched the voltage, amps and polarity needed, so thought there was no reason why it shouldn't work. I don't know what "Switching Adapter" means or if it affects anything. The Megadrive (Well, the Genesis, as I live in the US) has a completely different tip. As do the adapters for my other 30 consoles, haha.Thanks for the reply though. Quote Share this post Link to post Share on other sites
Zuckerton #4 Posted June 22, 2015 So I took it over to my friend (who's dad is a retired electrician) and we hooked it up, turned right on. Turns out the plug had to be shoved in (not something that I thought of at the time, hindsight is 20/20). Though it was staticy as *expletive deleted*, but when I got back, I used a different switch box (same model, just physically different) and the signal was crystal clear.Now I have only ONE issue left: The controller pulls to the right. I opened the controller, cleaned it; still pulls to the right. I opened the console (as the controller ports are locaed INSIDE THE CONSOLE) unplugged the controller, blew in both the port and the connector, reconnected it; still pulls to the right. I THEN disconnected BOTH controllers, reset the console and it STILL pulls to the right. Without any controller plugged in, the controls still pull to the right.I don't know if there is something on the board, something in the port or what. I'm at a bit of a loss here. It's a shame this thing is so obscure that few people have seen it, fewer have worked on it and even fewer have had this problem to fix. Quote Share this post Link to post Share on other sites
7800fan #5 Posted June 22, 2015 (edited) wrong thread Edited June 22, 2015 by 7800fan Quote Share this post Link to post Share on other sites
