Opry99er #26 Posted June 29, 2015 Good high quality pic. That will help alot. Quote Share this post Link to post Share on other sites
Shift838 #27 Posted June 29, 2015 They are not encased fortunately which makes it easier. If I recall correctly you have to have a resistor pack on the last drive in the chain. So if you are setting this up as DSK3 then it should remain. It's been a while since I setup the 5.25 drives so maybe someone else can chime in to verify if my memory is working right. Quote Share this post Link to post Share on other sites
TI-GAMER #28 Posted June 29, 2015 (edited) These will be setup internally as Disk 1 and Disk 2 and apparently I need to remove the Resistor Pack from DSK 1 according to the documentation. Edited June 29, 2015 by TI-GAMER Quote Share this post Link to post Share on other sites
Shift838 #29 Posted June 29, 2015 (edited) These will be setup internally as Disk 1 and Disk 2 and apparently I need to remove the Resistor Pack from DSK 1 according to the documentation. yes, that should be correct. Will you only be having 2 drives? Edited June 29, 2015 by Cschneider Quote Share this post Link to post Share on other sites
TI-GAMER #30 Posted June 29, 2015 (edited) Yes, just the 2 drives installed in the PEB. I just dont know where the pack is located on the physical drive to remove. (I think thats all I need to do is to remove the pack on DSK 1) Doesnt it work just like a Terminator on a SCSI drive? Edited June 29, 2015 by TI-GAMER Quote Share this post Link to post Share on other sites
sparkdrummer #31 Posted June 29, 2015 The resistor pack needs to be in the last drive at the end of the cable. Does not necessarily need to be drive 2. Ralph. Quote Share this post Link to post Share on other sites
sparkdrummer #32 Posted June 29, 2015 The resistor pack in the image is by the card edge connector - marked 150 ohms. Quote Share this post Link to post Share on other sites
sparkdrummer #34 Posted June 29, 2015 Yes. You can pull it from that drive if its not going to be the last one in the cable. If it will be the last drive leave it. Ralph. Quote Share this post Link to post Share on other sites
Shift838 #35 Posted June 29, 2015 Ralph beat me to it. That's it.. Quote Share this post Link to post Share on other sites
TI-GAMER #36 Posted June 29, 2015 Ralph beat me to it. That's it.. LOL The final objective was met so you get some credit also. Quote Share this post Link to post Share on other sites
