If you exported (in Multipaint) gfx to text format and you checked "comments" an "byte" you find those comments in your exported file, then you must only replace ".db" with ".byte" and C&P respective blocks of data to Mad Pascal code.
Quote
Hi, Thank You.
worked wonderfully.
a great thing what you do with the plus4 everything.
you have a lot of ideas.
I'm also interested in the hires mode.
do you have an idea for that too?
Thank you
As far as I know its all about different register ($ff06/$ff07) settings. I'm not tested this yet.
i have not yet understood the relationship between the colors in multicolor mode.
have you ever seen why one of my programs is not running on the yape?
how do you know that yape is better than winvice?
what test experience did you have?
Thank you.
Edited by funkheld
Another C+4 simple example (can be easy converted to A8) for beginners.
const
  ATTRIBUTE_ADDR = $0800; SCREEN_ADDR = $0c00; OFFSET = SCREEN_ADDR - ATTRIBUTE_ADDR;
  CHARSET = $d000; EMPTY = $20;
var
  BACKGROUND                         : byte absolute $ff15;
  BOREDER                            : byte absolute $ff19;
procedure printBigCharXY(x, y, ch, c: byte);
var
  curPoint, charRow     : word;
  tmp, i0b, i1b         : byte;
begin
  curPoint := SCREEN_ADDR + x + (y * 40);
  charRow := CHARSET + (8 * ch);
  for i0b := 0 to 7 do begin
    tmp := Peek(charRow + i0b);
    for i1b := 7 downto 0 do begin
      if (tmp and 1) = 1 then begin
        poke(curPoint + i1b, $a0);
        poke(curPoint - OFFSET + i1b, c);
      end;
      tmp := tmp shr 1;
    end;
    Inc(curPoint,40);
  end;
end;
procedure printBigXY(x, y, c: byte; s: string);
var
  i0b : byte;
begin
  for i0b := 1 to length(s) do printBigCharXY(x + (8 * (i0b - 1)), y, ord(s[i0b]), c);
end;
begin
  FillChar(pointer(SCREEN_ADDR), 24 * 40, EMPTY);
  FillChar(pointer(ATTRIBUTE_ADDR), 24 * 40, 0);
  printBigXY(3, 3, $11, 'tron'~);
  printBigXY(11, 12, $11, '+4'~);
  repeat until false;
end.
Edited by zbyti
add screen
Hi, Thank You.
this function is ok.
why is this "'....~" ?
why ist this function
when i take it out the screen is the same.
greeting
Edited by funkheld
From changelog
Quote
02/23/2021
- added PETSCII character conversion for strings ended with ''~
About fill ATTRIBUTE_ADDR area... Its a part of my screen init routine. C+4 have screen memory and colour map.
Stop asking so much questions, as always I recommend to read documentation for Mad Pascal and microcomputer are you now interested in.
Edited by zbyti
typo
13 minutes ago, funkheld said:
hello, can this "file" also be used for the Plus4 from Madpascal?
I don't understand, please write your question in german, I use Google Translate DE->EN.
I don't think so, support for Commodore family is in a very preliminary state, most Mad Pascal libraries are still A8 only.
Edited by zbyti
Hi good afternoon.
does it continue for the c64?
I would also be very happy with the madpascal.
 there aren't that many demos for the c64 yet.
the c64 is much more known than the plus4
Thank you.
Hello Mad Pascal Community,
in my project i'd like to - at some certain conditions, for initialization purposes - start another binary located on the disk; like a binary load.
Could this be done easily in Mad Pascal?
Currently i'm using the xBootDos by @XXL, which by description should support such a call - like XIO 40, #1,0,0,"D:FILE.EXE"
(btw, thx again for xBootDOS, gives me so much RAM i don't have to despair :) )
Best regards to everybody -   and thank you very much @TeBe for that great great compiler!
Posted (edited)
hello, good day you specialist.
I'll try the c64 and madpascal.
have a first problem with this asm:
can you please do the procedure with data transfer for me
madpascal?
I can then use them later as a procedure sample.
Thank you.
please transfer data to the asm procedure:
befehl:  !byte 10,0
puffer:  !byte 0
madpascal-procedure:
asm:
    lda #2
    ldx #2
    ldy #0
    jsr $ffba
    lda #2
    ldx #<(befehl)
    ldy #>(befehl)
    jsr $ffbd
    jsr $ffc0
    ldx #2
    jsr $ffc9
    ldy #0
    lda puffer,y
    jsr $ffd2
    jsr $ffcc
waitforchar:
    lda $029d
    cmp $029e
    bne waitforchar
    ldx #50
loop:
    jsr $eeb3
    dex
    bne loop
    lda #2
    jsr $ffc3
end-asm
Edited by funkheld
Posted (edited)
DIY
if you see:
    lda #2
    ldx #2
    ldy #0
    jsr $ffba
you can write:
procedure someCall(a ,x, y : byte); assembler;
asm {
  lda a
  ldx x
  ldy y
  jsr $ffba
end;
for lda/sta use poke, or poke and peek, or absolute variables.
for branch instructions use pascal loops with proper conditions or if/else statement.
and so on...
Edited by zbyti
typo
To answer my own question:
There actually is a XIO call procedure in MP, unit CIO !
procedure XIO(cmd, chn, ax1, ax2: byte; device: PByte); assembler;
Thanks @Tebe :)
thanks for the information.
buffer and befehl must be an address.
Thank you
befehl:  !byte 10,0
 puffer:  !byte 0
  ldx #<(befehl)
  ldy #>(befehl)
lda puffer,y
Mad Pascal provide you built-in  functions:
function Lo(x): byte;
function Hi(x): byte
