walterg74 #26 Posted August 22, 2015 My SNES was only yellow in the rear on both shells. It cost me $3.00 and one day with disassembly, retrobright application, cleaning, drying, and reassembly. I purchased a 32 Oz bottle of 40 VOL peroxide creme from Sallys Supply. It worked the same as the official retrobright recipe. Hi, would you mind telling me if it was any particular brand or link to the product? Thanks! Quote Share this post Link to post Share on other sites
Oldschool80skid #27 Posted August 23, 2015 (edited) Hi, would you mind telling me if it was any particular brand or link to the product? Thanks! It was this in the 32 oz.:http://www.sallybeauty.com/creme-developer/SLNCAR63,default,pd.html#q=Peroxide+creme&start=13&sz=12&viewAllProducts=true Edited August 23, 2015 by Oldschool80skid Quote Share this post Link to post Share on other sites
walterg74 #28 Posted August 23, 2015 It was this in the 32 oz.:http://www.sallybeauty.com/creme-developer/SLNCAR63,default,pd.html#q=Peroxide+creme&start=13&sz=12&viewAllProducts=true Thanks! Did you use it "pure" or mix with/add anything? How exactly did you apply it. Quote Share this post Link to post Share on other sites
Oldschool80skid #29 Posted August 23, 2015 Thanks! Did you use it "pure" or mix with/add anything? How exactly did you apply it. I applied it pure with a tooth brush and then covered with plastic wrap to keep it from drying out. 1 Quote Share this post Link to post Share on other sites
tremoloman2006 #30 Posted August 23, 2015 I was too. I did read also that extreme heat can cause the yellowing process even if the item is stored in the dark. This is definitely true... I have loads of old monitors that have that "piss yellow" color from getting hot. Nasty color. Quote Share this post Link to post Share on other sites
Oldschool80skid #31 Posted August 23, 2015 I applied it pure with a tooth brush and then covered with plastic wrap to keep it from drying out. I forgot to add to be sure to wear latex gloves when applying. The peroxide can cause mild skin irritation, but nothing serious. Quote Share this post Link to post Share on other sites
walterg74 #32 Posted August 24, 2015 Thanks, will try it out and see what happens! Quote Share this post Link to post Share on other sites
Greg2600 #33 Posted August 24, 2015 I could see the NES plastic being restored, but I've just not seen results with SNES that are satisfactory to me. SFC I would see it as well, but the SNES nope. I think it's partly due to the shade of white/grey it was, very light, or the texture of the plastic, but nobody ever gets it properly. Using a vinyl die is great and all, but I can't see how you could get the original color without extensive mixing. Quote Share this post Link to post Share on other sites
Oldschool80skid #34 Posted August 24, 2015 (edited) I could see the NES plastic being restored, but I've just not seen results with SNES that are satisfactory to me. SFC I would see it as well, but the SNES nope. I think it's partly due to the shade of white/grey it was, very light, or the texture of the plastic, but nobody ever gets it properly. Using a vinyl die is great and all, but I can't see how you could get the original color without extensive mixing. I was lucky that my Snes was not yellowed that bad, so it took me only one attempt. Everything that I have read on the web indicates thank you need to treat multiple times to completely restore the original grey color. Edited August 24, 2015 by Oldschool80skid Quote Share this post Link to post Share on other sites
Greg2600 #35 Posted August 24, 2015 I was lucky that my Snes was not yellowed that bad, so it took me only one attempt. Everything that I have read on the web indicates thank you need to treat multiple times to completely restore the original grey color. Eh, even then the results seemed way too white if you ask me. Quote Share this post Link to post Share on other sites
