Omega-TI
(Hardware) Project of the 'calendar quarter'
Wirewrap wire usually goes by the name Kynar.
Interesting thing, the 30 gauge (Kynar) is twice as expensive as the 28 gauge wire. (Less for more?) :)
I'll probably go that route though as it'll probably be easier to attach to the IC's leads.
I did not know this, but when I read it, I went and looked at my spool, and sure enough, that was the only word on it. ;)
Speaking of the wire... has anyone located a cheaper source?
I plan to order in the next week, so when January comes around I'll have the stuff to start along with everyone else.
I figured for my use a single spool will last me nearly forever, so I wasn't too worried :)
Is silver or tin better? I already bought the Kynar
Silver is a much better conductor, which is better for such thin wire. It is, however, more reactive; but, the wire covering greatly retards tarnishing until uncovered for use.
...lee
ordered 4 sets of chips to do some consoles :)
One console is enough for me (at least right now).
Anyway I just put my order in so I'll be ready in January.
Would anyone be interested in clear stickers for their modified "Internal 32K " consoles?
This is just an idea, I'm not setup to print them, but as time allows I could make up a few different sizes and fonts to get a 'final product'... if someone else is willing to print them off for everyone who wants one.
  • Like 4
Just got notice that it's been shipped. I can't wait for January to roll around so I'll have time to do this project. I'll probably even make a video.
yes, nice idea. I have one 32k-internal supercomputer, maybe get (or make?) another one next year.
so for me, at least a +5 :) (I need spares. I cannot live without spares, anybody sells ANY spares here ?) pls hlp :)
I also need to make 1-2 internal 32K ones to use only with the 2048K Games I module ("game console")
PS. does someone know if the nanoPeb gets connected to an internal 32K if it will break things? (2x 32K ?)
(I cannot remember I used to have an internal 32K and later on a PEB box with 32K, but believe it cannot work together)
or does it makes sense to have something externally connected to the TI with more memory (I think I read somewhere 512K, etc.)
No clue how to use it or it will benefit. I wish I can make dedicated time to understand the internals of the TI (Craig Miller videos are
good, but quality of the video is a bit difficult to see, I also need to go through Tursi one, that explained it very well with the XB27 module
and (G)ROMS)
Edited by globeron
Some of the 32k mods call for a switch on the exterior of the console for on/off. Don't know about this particular one here.
You definitely don't want two 32K devices on the bus at the same time. If you plan to add an external 32K at some future time, you need to be able to switch the internal one off.
Good idea... which lines? Could we get by with a SPST or do we need something lager than a 4PST?
You'll either need SPDT or a pull-up resistor, since you can't simply "cut off" any of the lines, they need to be attached to something. With an SPDT you put the chip side in the middle, one side to the original signal, and the other side to +5V or Ground as appropriate for the signal.
With my mod, I guess you have lots of options, but I'd probably disable it with a switch on the RAM's Chip Enable line (pin 20). One side to the AND gate as per the docs and one to +5v (optionally through a small resistor, 1k or so). When the switch is placed in the 5v selection, the chip enable is permanently high and the RAM chip will never respond. Flicking the switch while the system is running may cause a crash (less likely if not using the 32k at the time, but it is always possible).
With a pull-up resistor you can use an SPST switch on the same line -- the pull up resistor goes from CE to any +5V source, and the switch is inline with the wire to the AND gate. I don't like it quite as much because the system has to override the resistor to activate the chip, and the console kind of has a lot of that going on already. You'd probably want to try a 10k resistor here, though.
Got my parts in :) now this week I'll order that iron ohm had posted :)
Woo Hoo! Mine should arrive tomorrow while I'm at work. Can't wait until January!
Thank you.
Today I got 60% of the components now waiting for the other ones and give it a try.
:) Nice project wire, it's almost impossible to make a mistake with this stuff.gallery_35324_1027_15211.jpg
Just take your time and prep your wires ahead of time with a little flux & solder. To attach them, just touch it to the correct pin on the chip, that's also treated with a "smidge of flux" and it'll take as soon as you apply the heat of the soldering iron. It only takes a second.
If for some reason you manage to make a mistake, no big deal, it's easily correctable!
I'm going to do the 32K mod this way, there will be a few extra wires to solder, but i don't need to worry about the pin-bending, snipping, etc. Also each pin is simply soldered to whatever the label says, so no head-scratching. I will add a simple paper overlay to lay on top of the 9900 so that pin-counting is not an issue as well.
(Don't use this until I have tested I have "proofread" it by building one!) If it's OK I will put it on Osh Park so that you can just order on-line. I don't think Osh (Orchard Supply Hardware?) claims ownership for public projects, nor shares any profit, so someone might feel free to also sell populated boards with Kynar wires preattached. Since the Amazon order I made for the chips were not "prime", in fact they are probably slow-boating from China, I won't be able to test this for a few days or weeks.
Ti prelim
Edited by towmater
If you like, let me know how it goes and I can send the Gerbers off to the place I use to do boards (and I can whip a board up in a flash for something as simple as this one is if you need files in unrestricted Gerber format). That may be a lot less than doing them through Osh Park (probably no more than $3-$5 per board, depending on the board footprint), although Osh is great for doing test runs to validate a design.
I can post the brd file if you want. I wish OSH didn't make you order three. The reason to do it this way will be the simplified installation, IMHO, even if it is a rather simple board. Although I'm paying for two layers here, I kept the bridge on top so that one can make a self-etched, single-sided version from the same layout.
b6231180e72b7f2d814f08a5c9a253c5
