Sign in to follow this
omf
possible build.bat update
I have been messing with this and I have added the task kill command in just before the both virtualjaguar calls so it deals with any open instances which I noticed were building up when doing a lot of compiles
so maybe a good idea to add something like the below to the batch file just before the virtualjaguar call?
rem kill the virtualjaguar process to keep things tidy, two taskkill's are needed because sometimes it leaves the process running
taskkill /IM virtualjaguar.exe >> %TEMPDIR%\build.log
don't know why but in some cases it leaves a process running so it is necessary to have 2 taskkill's to get rig of everything :(
That wouldn't work for me, I like to run multiple instances to compare changes side-by-side.
Yup it can get confusing and complex because you then need too keep track of the process' PID and kill explicitly that. Never mind what could happen if running under linux/mac ;) (yes, it's been a while since I tried it from linux but it should mostly work there).
fair comment, it is good for me however while messing about with 95% useless code that does basically SQRT(diddly) ;-)
