gozar Posted September 7, 2015 Share Posted September 7, 2015 With the three day weekend, I'm starting down the path to learn assembly. It's just a Pong clone, but hey, we have to start somewhere. So far, I've got it to set the background color to black and draw the field: Why can't I get rid of that cursor? Here's my source so far: ; Death By Paddle ; 2015/09/06 org $2000 ;Start of code block COLOR2 = $2c6 CRSINH = $2f0 SAVMSC = $58 SAVMSCLO = $58 SAVMSCHI = $59 XY = $c0 XYLO = $c0 XYHI = $c1 start lda #0 sta color2 ; Set background color to black lda #1 sta crsinh ; Turn off cursor ; Set up player scores lda #16 ldy #5 sta (savmsc),y ; Temporary, print a score of 0 for player one ldy #35 sta (savmsc),y ; Same for player 2 ; Draw playfield drawplayfied lda savmsclo ; Save screen locations adc #112 sta xylo lda savmschi adc #3 sta xyhi ; Calculate location of bottom line (savmsc + 920) lda #82 ; control-w ldy #40 line sta (savmsc),y sta (xy),y iny cpy #80 bcs linedone jmp line linedone vline clc ; Set up to draw the vertical line ldy #0 lda savmsclo adc #99 sta xylo ; in xy store the location of the vertical bar lda savmschi sta xyhi lda #0 ; Loop counter to do it 20 times sta $c2 lda #124 ; Vertical bar - first bar sta (xy),y vlineloop clc lda xylo adc #40 ; Calculate next position sta xylo bcc contline ; If the numbers wrapped, increment hi clc lda xyhi adc #1 sta xyhi contline lda #124 sta (xy),y ; Print the bar character inc $c2 ; Increment loop lda $c2 cmp #20 ; Are we done? bcs vlinedone jmp vlineloop vlinedone jmp * 6 Quote Link to comment Share on other sites More sharing options...
phaeron Posted September 7, 2015 Share Posted September 7, 2015 Think you're missing a CLC at the beginning of the draw playfield code. The cursor sticks around because CRSINH doesn't actually take effect until the next put operation. Quote Link to comment Share on other sites More sharing options...
Rybags Posted September 7, 2015 Share Posted September 7, 2015 I'd suggest don't assume the configuration will be Graphics 0. Many games menu loaders use a different screen mode and often the default DList and screen Ram will be overwritten. Though you can deal with that sort of thing right at the end. While in dev you can have a known configuration on entry, then fix it later. Quote Link to comment Share on other sites More sharing options...
gozar Posted September 7, 2015 Author Share Posted September 7, 2015 How do I do a GRAPHICS 0 command in assembly? Quote Link to comment Share on other sites More sharing options...
FifthPlayer Posted September 7, 2015 Share Posted September 7, 2015 (edited) Bill Wilkinson will show you how to emulate the BASIC GRAPHICS 0 command via assembly. He even gives you an assembler library to invoke all the BASIC graphics commands (which are actually part of the ROM OS). http://archive.org/stream/1982-02-compute-magazine/Compute_Issue_021_1982_Feb#page/n77/mode/2up I think what a lot of game programmers do eventually is set up their own display list in their code (oftentimes with some assembler data statements) and point ANTIC at it. (I pointed you to the start of the article, containing Bill's discussion. The actual assembler code to implement GRAPHICS q appears on page 86.) Edited September 7, 2015 by FifthPlayer Quote Link to comment Share on other sites More sharing options...
gozar Posted December 24, 2016 Author Share Posted December 24, 2016 I've made some progress, and now have a nice playfield to start with: Does it look like I'm on the right track? ; GozPong ; Ryan 'Gozar' Collins ; 12/21/16 org $3000 ;start of code jmp main ; Constants SDMCTL = $022f SDLSTL = $0230 SDLSTH = $0231 GRACTL = $d01d COLOR0 = $02C4 COLOR1 = $02C5 COLOR2 = $02C6 COLOR3 = $02C7 COLOR4 = $02C8 PCOLR0 = $02c0 PMBASE = $d407 HPOSP0 = $d000 ;Initialize variables bx .byte 0 by .byte 0 bdx .byte 4 bdy .byte 3 scoreline dta d " 0 0 " ;PMG data ball .byte $18,$3c,$3c,$18 gamescreen .byte $70,$70,$70 ;3 blank lines .byte $46 ; LMS Antic mode 6 .word scoreline .byte $42 ; LMS Antic mode 2 .word $1000 ; Store the page at $1000 .byte $02,$02,$02,$02,$02,$02,$02,$02,$02,$02 .byte $02,$02,$02,$02,$02,$02,$02,$02,$02,$02 .byte $02,$02 .byte $41 ;JVB instruction .word gamescreen ; back to the top setupgamescreen ; Show screen lda #0 sta SDMCTL lda #gamescreen&255 sta SDLSTL lda #gamescreen/256 sta SDLSTH lda #$22 sta SDMCTL ;build field lda #82 ldx #0 looptop ; top and bottom sta $1000,X sta $1370,X inx cpx #40 bne looptop ; middle line lda #87 sta $1014 lda #88 sta $1384 lda #$3c ;Store the location of the middle line sta $b0 lda #$10 sta $b1 ldy #0 sty $b2 lda #124 loopline ;Create the middle line sta ($b0),y lda $b0 clc adc #40 sta $b0 bcc drawline ldx $b1 inx stx $b1 drawline lda #124 sta ($b0),y ldx $b2 inx cpx #20 stx $b2 bne loopline ldx #0 stx COLOR2 ;Set the gamefield color ldx #255 stx COLOR0 ;set the score color stx COLOR1 ;Set the gamefield brightness rts ;Done with screen setup ;Main game main jsr setupgamescreen infinity jmp infinity run main 2 Quote Link to comment Share on other sites More sharing options...
pirx Posted December 27, 2016 Share Posted December 27, 2016 yes! Quote Link to comment Share on other sites More sharing options...
gozar Posted December 27, 2016 Author Share Posted December 27, 2016 yes! Thanks! I'm such a newbie at this, and assembly seems so... I don't know, it feels like when I get something working that there is a better way of doing it. I got a ball player/missile moving yesterday, but now my problem is that it moves way too fast! Quote Link to comment Share on other sites More sharing options...
gozar Posted December 27, 2016 Author Share Posted December 27, 2016 I'm trying to make the ball move like in Pong, but it flies across the screen. What's the best way to make the ball wait until a certain amount of time has passed before moving? Do I use the built in clock or is there a better way? Sent from my iPhone using Tapatalk Quote Link to comment Share on other sites More sharing options...
+Stephen Posted December 27, 2016 Share Posted December 27, 2016 For a case like this, I'd say it's probably best to synch your game code to the VBI. The disadvantage is that PAL and NTSC will play at different speeds. There are workarounds for this however. Let's say you have two variables, dX and dY. This will represent the horizontal and vertical ball speed. Each VBI, increment the object position, check for collisions, etc. If you need some examples of running code in VBI, I can share them. I have a simple left/right joystick routine which runs at 30Hz that's only a few lines of code. As with all things ASM, there are certain steps which need to be taken to ensure your VBI code is "hooked" properly. 1 Quote Link to comment Share on other sites More sharing options...
phaeron Posted December 27, 2016 Share Posted December 27, 2016 What you want is fixed-point math. It's in-between integer and floating-point math in that it handles fractional numbers, but the range and precision is not as adaptable as floating-point. Typically for this you would use 16-bit numbers in 8.8 form, where 8 bits hold the whole part and 8 bits hold the fractional part. Here's a simple example: ANIM_SPEED = $0038 animloop: lda pos_lo clc adc #<ANIM_SPEED ;$38 sta pos_lo lda pos_hi adc #>ANIM_SPEED ;$00 sta pos_hi ;move missile horizontally lda pos_hi sta hposm0 ;wait for next frame lda rtclok+2 wait: cmp rtclok+2 beq wait jmp animloop This code moves missile 0 right at the rate of $38/$100 = 0.22 pixels per tick. The first part is just a 16-bit add, and then the high byte is used to set the missile position. For a pong-like game, you'd put the speed into a variable of its own so you could change it as needed on playfield or paddle collisions. Fixed-point has several advantages over trying to space out +1/-1 increments with delays: backwards motion works with the same code just by using a negative speed, the speed value is linear instead of non-linear as with the delay value, and it handles in-between values smoothly. As for running your code off the vertical blank interrupt, that's a good idea but not required. You can get pretty far with the little wait loop I posted above, and then start moving code to the VBI once you're comfortable working with interrupts. 3 Quote Link to comment Share on other sites More sharing options...
gozar Posted January 10, 2017 Author Share Posted January 10, 2017 Success! gozpong.xex 5 Quote Link to comment Share on other sites More sharing options...
