tebe Posted January 4, 2017 Share Posted January 4, 2017 code: Bocianu Boczansky uses crt, fastgraph; const xsize = 80; const ysize = 48; const maxLines = 5; const xspeed = 2; const lineSpanX = xsize div (maxLines-1); const lineSpanY = ysize div 3; const lineY1 = 0; const LineY2 = lineSpanY; const LineY3 = lineSpanY shl 1; const LineY4 = ysize-1; const XOffset = xsize shr 2; var lineX1, lineX2, i, c, sc: byte; var wsync : byte absolute $D40A; procedure putLine(x:byte); begin lineX2 := (x shr 1) + XOffset; MoveTo (x, lineY1); LineTo (lineX2, lineY2); LineTo (lineX2, lineY3); LineTo (x, lineY4); end; procedure setAtX(x:byte); begin for i := 0 to maxLines-1 do begin SetColor(0); wsync:=1; putLine(x-xspeed); if (x > xsize) then break; SetColor(c); putLine(x); Inc(c); if c>3 then c:=1; Inc(x, lineSpanX); end; end; begin InitGraph(5); LineX1 := 0; sc := 1; repeat c := sc; setAtX(LineX1); Inc(LineX1,xspeed); if LineX1 >= lineSpanX then begin Dec(sc); if sc<1 then sc:=3; LineX1 := 0; end; until KeyPressed; end. clines.zip 1 Quote Link to comment Share on other sites More sharing options...
tebe Posted January 4, 2017 Share Posted January 4, 2017 sphere uses crt, fastgraph; var cx, cy, x, y, x2, y2: byte; sx, sy, size: real; sinx, cosx, siny, tmp: real; procedure Sphere(time: byte); begin if time=1 then MoveTo(cx+round(size), cy) else MoveTo(cx, cy+round(size)); sy:=-11.5*8.0; for y:=7 downto 0 do begin siny:=size*sin(sy*pi/180.0); sx:=0.0; for x:=0 to 32 do begin tmp:=sx*pi/180.0; sinx:=sin(tmp); cosx:=size*cos(tmp); if time=1 then begin x2:=cx+round(cosx); y2:=cy-round(sinx*siny); end else begin x2:=cx-round(sinx*siny); y2:=cy+round(cosx); end; LineTo(x2,y2); sx:=sx-12.0; end; sy:=sy+12.0; end; end; begin size:=90.0; cx:=160; cy:=96; InitGraph(24); SetColor(1); Sphere(1); Sphere(2); repeat until keypressed; end. sphere.zip 1 Quote Link to comment Share on other sites More sharing options...
+JAC! Posted January 6, 2017 Share Posted January 6, 2017 This is really getting better at an incredible speed. And having all the examples is really cool. Quote Link to comment Share on other sites More sharing options...
tebe Posted February 5, 2017 Share Posted February 5, 2017 starfield uses crt, fastgraph; const star_max = 64; star_speed = 2; w = 160; h = 96; var star_x, star_y, px, py: array [0..star_max-1] of byte; star_s: array [0..star_max-1] of shortint; x, y, i: byte; procedure init; begin randomize; x:=w shr 1; y:=h shr 1; for i:=0 to star_max-1 do begin star_x[i]:=random(0); star_y[i]:=random(0); star_s[i]:=random(0); end; end; procedure anim; begin for i:=0 to star_max-1 do begin SetColor(0); PutPixel(px[i], py[i]); dec(star_s[i], star_speed); if (star_s[i] < 0) then star_s[i]:=random(64); px[i] := x+(star_x[i] div star_s[i]); py[i] := y+(star_y[i] div star_s[i]); SetColor(1); PutPixel(px[i], py[i]); end; end; begin InitGraph(7+16); SetColor(1); init; repeat pause; anim; until keypressed; end. starfield.zip 2 Quote Link to comment Share on other sites More sharing options...
Gury Posted February 6, 2017 Author Share Posted February 6, 2017 (edited) Waw, nice little effect. It shows what can be done with little effort, especially with Mad Pascal and Mad Assembler, which tandem is lightning fast. It's just about imagination what limits us. Edited February 6, 2017 by Gury Quote Link to comment Share on other sites More sharing options...
dmsc Posted February 26, 2017 Share Posted February 26, 2017 Hi! I ported a small text mode solitaire game that I programmed in college from TurboPascal to Mad Pascal, it was fun. Porting changes where: - The original program used colors for the cards, I removed all color references so the program is "white on blue". - As the screen is only 40 columns across, I compressed the screen somewhat. - Mad Pascal does not support "Enumerated Types", I replaced it with char constants. - Also, two dimensional arrays and non-zero based arrays where replaced by simple flat arrays (using "i * width + j" accesses). After that, I replaced all "integer" types with "byte" and "shortint", this reduced the generated code in half. Well, source is in "sol.pas" file (added a .txt extension to allow uploading), attached is a small ATR with the compiled program, simply type "SOL" to play. As the "E:" handler used to output is *slow*, I also included a simple "E:" handler replacement, load it before te game by typing "FLASH40". sol.atr sol.pas.txt 1 Quote Link to comment Share on other sites More sharing options...
dmsc Posted February 26, 2017 Share Posted February 26, 2017 Hi!, New version of my solitaire game, now the program only redraws moved cards, so it's a lot faster. As before, attached source and ATR with binary, and some images; Later in the game: And proof that you can win : sol.atr sol.pas.txt 1 Quote Link to comment Share on other sites More sharing options...
Gury Posted February 26, 2017 Author Share Posted February 26, 2017 Nice solitaire game, thank you. It is good to see the source code published, for others to analyze the inner workings. Quote Link to comment Share on other sites More sharing options...
dmsc Posted February 26, 2017 Share Posted February 26, 2017 Hi! Nice solitaire game, thank you. It is good to see the source code published, for others to analyze the inner workings. Thanks, I'm not proud of the code, was written a really long ago. Also, comments and variable names are in spanish I'm impressed with MadPascal, compatibility with TP is great (even accepts some Delphi extensions), with only a little modifications (for the control characters), the same code can be compiled with FPC to generate a Windows or Linux binary. Attached is the source modified to remove all control characters and re-adding the text color changes, i does not look as good in a Linux terminal, but it works: Included in the ZIP file are binaries for Linux, DOS and Windows sol-txtonly_v10.pas.txt solitario.zip 2 Quote Link to comment Share on other sites More sharing options...
pirx Posted February 27, 2017 Share Posted February 27, 2017 At last someone won this Solitario!!! 2 times cards were garbled, moving cursor over them fixed the view. It happened in first and last column.The variant is a bit more difficult than windows version because taking cards from the final stack is not possible. Warp speed helps a bit : ) Had fun, thanx : ))) Quote Link to comment Share on other sites More sharing options...
dmsc Posted February 27, 2017 Share Posted February 27, 2017 Hi! At last someone won this Solitario!!! 2 times cards were garbled, moving cursor over them fixed the view. It happened in first and last column. The variant is a bit more difficult than windows version because taking cards from the final stack is not possible. Warp speed helps a bit : ) Had fun, thanx : ))) I fixed a display issue, perhaps it's the same that you saw, and a bug that let you put a King over the dealing deck. Attached are the new versions, have fun! sol.atr sol_v12.pas.txt 2 Quote Link to comment Share on other sites More sharing options...
pirx Posted February 27, 2017 Share Posted February 27, 2017 magnifique! Won again with less attempts this time! The accelerator rulz, completely forgot such marvels existed. Still a glitch - looks like card to be moved shifts one char to the left. altstate attached. Quote Link to comment Share on other sites More sharing options...
dmsc Posted February 27, 2017 Share Posted February 27, 2017 Hi!, magnifique! Won again with less attempts this time! The accelerator rulz, completely forgot such marvels existed. Still a glitch - looks like card to be moved shifts one char to the left. altstate attached. Seems you forgot to attach? Thanks! Quote Link to comment Share on other sites More sharing options...
pirx Posted February 27, 2017 Share Posted February 27, 2017 Hey, yea, 2 clicks. it gets me every time. sol.err.altstate.zip Quote Link to comment Share on other sites More sharing options...
dmsc Posted February 28, 2017 Share Posted February 28, 2017 Hi!, magnifique! Won again with less attempts this time! The accelerator rulz, completely forgot such marvels existed. Still a glitch - looks like card to be moved shifts one char to the left. altstate attached. I knew that glitch, it's because all cards don't fit in the screen. I finally re-arranged the program, simplifying it a lot and fixed that last redraw problem. Also, I put the card at that position (over the last card stack) because you can't write at the last screen column using the "E:" handler without messing all the lines bellow (never understood why atari programmed it that way). New version attached, Mad Pascal sources and compiled ATR. sol_v14.pas.txt sol.atr 2 Quote Link to comment Share on other sites More sharing options...
tebe Posted March 12, 2017 Share Posted March 12, 2017 (edited) uses crt, fastgraph; const maxLines =16; maxDrawLines =500; type LineDescr = array [0..3] of smallint; var Ball, Vel, max : LineDescr; Lines : array [0..maxLines, 0..3] of smallint; t : smallint; count: word; i, new, old: byte; begin InitGraph(8 + 16); randomize; max[0]:=ScreenWidth; max[1]:=ScreenHeight; max[2]:=ScreenWidth; max[3]:=ScreenHeight; for i := 0 to 3 do begin Vel[i] :=random(16) - 7; Ball[i]:=random(smallint(max[i])) - 160; end; new := 0; old := 0; count := 0; repeat for i := 0 to 3 do begin t:=Ball[i]+Vel[i]; if t >= max[i] then begin t := max[i] shl 1 - Vel[i] - Ball[i]; Vel[i] := -Vel[i]; end; if t<0 then begin t := -t; Vel[i] := -Vel[i]; end; Ball[i] := t; end; if (count >= maxLines) then begin SetColor(0); Line (lines[old, 0], lines[old, 1], lines[old, 2], lines[old, 3]); old:=(old+1) mod maxLines; end; Lines[new, 0] := Ball[0]; Lines[new, 1] := Ball[1]; Lines[new, 2] := Ball[2]; Lines[new, 3] := Ball[3]; new:=(new+1) mod maxLines; SetColor(1); Line (ball[0], ball[1], ball[2], ball[3]); inc(count); until (consol<>cn_none) or (count=MaxDrawLines); repeat until consol<>cn_none; end. in attachment, program with one and two-dimensional array two_dimensional.zip Edited March 12, 2017 by tebe 2 Quote Link to comment Share on other sites More sharing options...
funkheld Posted March 12, 2017 Share Posted March 12, 2017 lines.obx 6,7 kb is the to big. greeting Quote Link to comment Share on other sites More sharing options...
Gury Posted March 12, 2017 Author Share Posted March 12, 2017 This is logical, because it uses one-dimensional array. Look at the second example, which uses two-dimensional array for the same task, producing shorter code. This is obivously new feature implemented in Mad Pascal, one of the most important. Great. 1 Quote Link to comment Share on other sites More sharing options...
tebe Posted May 22, 2017 Share Posted May 22, 2017 (edited) new unit OBJECTS (MadPascal 1.4.7) , TMemoryStream implementation TMemoryStream.Create TMemoryStream.ReadBuffer TMemoryStream.ReadByte TMemoryStream.ReadDWord TMemoryStream.ReadWord TMemoryStream.WriteBuffer TMemoryStream.WriteByte TMemoryStream.WriteDWord TMemoryStream.WriteWord new resource type EXTMEM label EXTMEM 'filename' load FILENAME at address LABEL (32bit) uses crt, graph, objects, atari; {$r vscrol.rc} const bitmap = 0; // extended memory address 32bit var m: TMemoryStream; tb: array [0..0] of byte; i: byte; l, d: smallint; begin InitGraph(15 + 16); color0:=4; color1:=6; color2:=8; color4:=0; tb:=pointer(dpeek(88)); m.create; d:=40; l:=0; repeat m.position := l + bitmap; m.ReadBuffer(tb, 192*40); inc(l, d); if (l = 586*40) or (l = 0) then d := -d; until keypressed; end. TMemoryStream.zip Edited May 22, 2017 by tebe 1 Quote Link to comment Share on other sites More sharing options...
tebe Posted May 22, 2017 Share Posted May 22, 2017 (edited) new game, written in MadPascal by Wojciech Bociański (anticShop) at "WAP-NIAK 2017" "Vox Regis" (Mad Kingdom) http://www.pouet.net/prod.php?which=70040 https://gitlab.com/bocianu/MadKingdom/tree/master Edited May 22, 2017 by tebe 1 Quote Link to comment Share on other sites More sharing options...
Gury Posted May 22, 2017 Author Share Posted May 22, 2017 Realy amazing, new features make this compiler even stronger, especially usage of extended memory and additional optimizations. As I walk through code comparing high-level native and cross-compiler languages, I see Pascal and Action! are definitely more readable as comparable C code listings, for example CC65. Game is interesting too, thanks. Quote Link to comment Share on other sites More sharing options...
tebe Posted May 28, 2017 Share Posted May 28, 2017 (edited) Jet Graphics Planner (JGP), Graphics 4+ http://tajemnice.atari8.info/5_93/5_93_jgp.html uses crt, graph, atari; {$r engine.res} const width = 32; mode = 4; fnt1 = $a000; fnt2 = $a400; jgpfnt = fnt1-6; type TLineDisplay = record cmd: byte; adr: word; end; TJGPBlock = object x, y: byte; procedure Put(a: byte); end; var scr: array [0..11, 0..15] of word; jgp: TJGPBlock; a,b: byte; procedure TJGPBlock.Put(a: byte); var tmp, inv: byte; w: word; begin inv := a and $80; tmp := (a and $7f) * 2; w := tmp + (tmp or 1) shl 8; if inv<>0 then w:=w or $8080; scr[y,x] := w; inc(x); if x>15 then begin x:=0; inc(y); if y>11 then y:=0; end; end; procedure VBL; interrupt; assembler; asm { mva #scr32 dmactl lda >fnt1 sta chbase mva #$12 color0 mva #$c2 color1 mva #$7c color2 mva #$fe color3 mwa #MAIN.DLI.r0 vdslst jmp xitvbv }; end; procedure DLI; interrupt; assembler; asm { ?fnt = fnt1 .rept 24,#,#+1 ?fnt = ?fnt ^ [fnt1^fnt2] r%%1 .local pha fnt lda >?fnt sta wsync sta chbase ift %%1<>23 mwa #r%%2 vdslst eif pla rti .endl .endr }; end; procedure InitJGP; var a: ^TLineDisplay; i: byte; w: word; begin InitGraph(7 + 16); a:=pointer(dpeek(560)); a^.cmd:=$70; a^.adr:=$7070; w := dpeek(88); scr:=pointer(w); for i:=0 to 11 do begin inc(a); a^.cmd:=$40 or mode or $80; a^.adr:=w; inc(a); a^.cmd:=$40 or mode or $80; a^.adr:=w; inc(w, width); end; a^.cmd := $40 or mode; inc(a); a^.cmd := $41; a^.adr := dpeek(560); SetIntVec(iVBL, @vbl); SetIntVec(iDLI, @dli); nmien := $c0; end; begin InitJGP; jgp.x := 0; jgp.y := 0; for b:=0 to 3 do for a:=0 to 15 do jgp.put(a+b*16); jgp.y := 5; for b:=0 to 3 do for a:=0 to 15 do jgp.put(a+b*16 + $80); repeat until keypressed; end. jgp.zip Edited May 28, 2017 by tebe 1 Quote Link to comment Share on other sites More sharing options...
peteym5 Posted May 28, 2017 Share Posted May 28, 2017 Top Ten Game Score Sample. I am working on a template to so I can build several Atari Cartridge Games in Pascal and Assembly. I like how I can use ASM {} to make ML routines to do specific tasks. uses atari, crt, sysutils; var i : Byte; k : Byte; titlephase: Byte = 0; score: word = 2000; hiscore : array [0..10] of word = (0,9500,8500,7500,6500,5500,4500,3500,2500,1500,500); begin InitGraph(0); asm { lda #0 sta 82 sta 710 lda #12 sta 709 }; ClrScr; CursorOff; GotoXY(0, 2); writeln(' ** Top Ten High Score Demonstration **'); k := 11; i := 10; repeat if score>hiscore[i] then begin; k := i end; i := i - 1 until i = 0; if k < 10 then begin; i := 10; repeat hiscore [i] := hiscore [i-1]; i := i - 1 until i = k; hiscore [k] := score end; GotoXY(12, 6); write('Score:',score); GotoXY (8,10); write ('Todays High Scores.'); for i := 1 to 10 do begin; if k = i then begin GotoXY(12,11+i); write('*'); end; if i = 10 then begin GotoXY(13, 11+i); end else begin GotoXY(14, 11+i); end; write (i,' :'); GotoXY(18, 11+i); write(hiscore[i]); end; GotoXY(7, 23); write('Press Start to Begin.'); repeat until keypressed; end. 1 Quote Link to comment Share on other sites More sharing options...
tebe Posted May 28, 2017 Share Posted May 28, 2017 (edited) uses atari, crt; var i : Byte; k : Byte; titlephase: Byte = 0; score: word = 2000; hiscore : array [0..10] of word = (0,9500,8500,7500,6500,5500,4500,3500,2500,1500,500); begin lmargin := 0; color2 := 0; color1 := 12; ClrScr; CursorOff; GotoXY(0, 2); writeln(' ** Top Ten High Score Demonstration **'); Edited May 28, 2017 by tebe Quote Link to comment Share on other sites More sharing options...
peteym5 Posted May 29, 2017 Share Posted May 29, 2017 Why is this not setting to the address of the screen??? dl: array [0..28] of byte = ( $70,$70,$43, lo(word(@screen)), hi(word(@screen)), $03,$03,$03,$03,$03,$10,$03,$03,$03,$03,$03,$03,$03,$03,$03,$03,$03,$03,$03,$03,$03,$41, lo(word(@dl)), hi(word(@dl)) ); var screen :word absolute $B000; Quote Link to comment Share on other sites More sharing options...
