Keyboard reset with TOS 1.04?
eebuckeye
I upgraded to TOS 1.04 thanks to Exxosuk!
Have you doubled check with sysinfo it shows as TOS104 ? or checked the "Desktop info" for the animated colour FUJI ? If you brought the PCB version with the PLCC ROM, that has TOS 102 and TOS104 built in, selectable via a jumper link.
Edited by exxosuk
I was playing 'Flappy Bird' and tried to reset it so I'm wondering if that was the problem.
When some software totally takes over the system, you might have to reach
around and actually use the physical reset button on the back of the machine.
Otherwise, if the first warm boot key sequence doesn't work, try the cold boot
one... HTHs.
one... HTHs.
Indeed, lots of games (if not most) take over the system (interrupts) and key presses are not handled by the OS anymore. In that case the <alt><ctrl><delete> combination is never caught by TOS.
I generally I would only expect the key combination to work in GEM programs.
Robert
