Keatah #1 Posted December 2, 2015 Is there any sort of comprehensive .ATR, .XEX, .DCM disk and file manager for the 8-bit Ataris? Something that allows adding and deleting files from an image. Something that works on the PC side of things only and does not require any 8-bit or 3rd party hardware. For the Apple II we have something called CiderPress. http://a2ciderpress.com/index.htm Quote Share this post Link to post Share on other sites
AtariGeezer #2 Posted December 2, 2015 Yep, my ATR Tools app does that... I need to finish up support for a couple more DOS Types before the release of the Win32 version. The old version written in Visual Basic can be found here: http://atariage.com/forums/topic/192052-atr-tools/page-2?do=findComment&comment=3212606 2 Quote Share this post Link to post Share on other sites
brenski #3 Posted December 2, 2015 try this: i think Kheffington sent it me some time ago DISK CREATE.zip 1 Quote Share this post Link to post Share on other sites
flashjazzcat #4 Posted December 2, 2015 Also look at Altirra's disk explorer, which is a very capable image manager which also handles the SDFS format. 1 Quote Share this post Link to post Share on other sites
+Larry #5 Posted December 2, 2015 Check out MakeATR. It is a true Win32 application with a real GUI. Web page in Polish, but it is in English and very easy to use. Ataridos/MyDos. Don't know about DCM's and XFD's -- I avoid DCM's when possible and when necessary use Imagic from Atarimax. http://serious-dial.atari.pl/makeATR/ Imagic 1.06 http://www.atarimax.com/ (scroll down...) -Larry 1 Quote Share this post Link to post Share on other sites
+Roydea6 #6 Posted December 2, 2015 ATADIM 3.05 1 Quote Share this post Link to post Share on other sites
+Larry #7 Posted December 2, 2015 Hi Roy- ATADIM is great and I use it regularly, but can it do more than just show the directory contents? Didn't think it could, but it would be great if it does more than that. -Larry Quote Share this post Link to post Share on other sites
Madi #8 Posted December 2, 2015 In my continuous search for a comprehensive Atari file management software, couldn't find a better one than this: Atari File-Management v1.7.002 Even though it has its pitfalls, still outweighs all available managers (in my opinion). It is a decent image directory that searches PC directories, and files within ATR images, add files and delete them. Supports several DOS formats. Also, it exports ascii export option. The best of all, it can be made to run executables through emulators. See photos (directories of Pooldisk_Too_CD1) madi 1 Quote Share this post Link to post Share on other sites
+Roydea6 #9 Posted December 2, 2015 Hi Roy- ATADIM is great and I use it regularly, but can it do more than just show the directory contents? Didn't think it could, but it would be great if it does more than that. -Larry Yes much more.. extract and import or drag and drop files to the ATR.. If you have the atadim.cfg file set up double cliking on COM, XEX, Files will launch the associated program [EMU] for 8bit files. DOC,TXT, ETC.. will launch an associated text editor .. MIC, PIC, ETC will launch a picture viewer Like the Recoil program for viewing 8bit graphics. RMT extenders will launch Raster Music and play the selected file.. Best would be to read the website that explains it all... Quote Share this post Link to post Share on other sites
+Larry #10 Posted December 2, 2015 Update -- I still found that not much worked, but then I clicked on the little red dot on the GUI, and that turns off the Read Only mode. It's evidently a read only toggle. Once I did that the buttons at the bottom are no longer "grayed out." Yes, looks like a lot more works. Hope that helps someone else. -Larry Quote Share this post Link to post Share on other sites
+Roydea6 #11 Posted December 3, 2015 Update -- I still found that not much worked, but then I clicked on the little red dot on the GUI, and that turns off the Read Only mode. It's evidently a read only toggle. Once I did that the buttons at the bottom are no longer "grayed out." Yes, looks like a lot more works. Hope that helps someone else. -Larry ATADIMRaster.txt Translated info.... 1 Quote Share this post Link to post Share on other sites
Madi #12 Posted September 18, 2019 On 12/2/2015 at 8:05 PM, Madi said: In my continuous search for a comprehensive Atari file management software, couldn't find a better one than this: Atari File-Management v1.7.002 Even though it has its pitfalls, still outweighs all available managers (in my opinion). It is a decent image directory that searches PC directories, and files within ATR images, add files and delete them. Supports several DOS formats. Also, it exports ascii export option. The best of all, it can be made to run executables through emulators. See photos (directories of Pooldisk_Too_CD1) madi A new release of the famous File Management software. It supports WIN7-10 and had a new features. Thank to Burkhard Rau: Atari File-Management vV 2.1 00xx mdi 3 1 Quote Share this post Link to post Share on other sites
Kyle22 #13 Posted September 20, 2019 On 9/18/2019 at 6:26 AM, Madi said: It supports WIN7-10 and had a new features. It also seems to run fine on XP32. Any chance of adding dis / assembly tools? :) 1 Quote Share this post Link to post Share on other sites
Colleton #14 Posted September 20, 2019 This is a great thread, thanks! 1 Quote Share this post Link to post Share on other sites
doctor_x #15 Posted September 20, 2019 As I started reading this thread I began thinking “there should be a file explorer that does all of this plus can associate emu’s with file types or at least allow you to select on the fly which emu to use via right-click or something...” then I found out the program above does that... Now I am thinking we need a file manager that works with ALL emulated file types and can handle multi OS brokering... could be very cool and seen positively by a large number of people due to being cross-scene.. 1 Quote Share this post Link to post Share on other sites
Mclaneinc #16 Posted September 21, 2019 (edited) Another fine bit of software for this is Atari Archiv, its an Atari based port of Purmikes excellent C64 Archiv tool for that er other machine.... http://purmike.de/documents/atariarchiv.html Its pretty much a databasing util only but does it very nicely.. Edited September 21, 2019 by Mclaneinc 3 Quote Share this post Link to post Share on other sites
