TheGrandPubaa
Typing in Basic programs on modern computer
I'm extremely new to actually using the CoCo 2 and basic code in general. So I found some sample basic code in an old december issue of The Rainbow that does a little Xmas demo and i'm wondering if there is a way to type it in on my modern computer(this one is a Macbook Pro, but I can also run windows so i'm fairly platform agnostic) in a text editor and convert that file to a cassette image or a disk image I can load on the CoCo? Does this even make sense?
The "Toolshed" utilities can help you with that.
http://sourceforge.net/projects/toolshed/
You will need to edit program.bas as you see fit, then execute a sequence like this:
rm -f example.dsk
decb dskini example.dsk
decb copy -0 -b -l -t program.bas example.dsk,PROGRAM.BAS
Mounting example.dsk in your favorite emulator is left as an exercise for the reader...
Edited by linville
Yes, you can use a utility to save the program as a .wav audio file to load in a real CoCo; sounds like that is what you are trying to do.
rm -f example.dsk
This was very helpful and worked so far as to get the basic code listing on a disk image that I could then test in an emulator. However, it gives me a syntax error on the first line with actual code when I load the .bas program from the example dsk. When I type in the same line of code from scratch in the emulator, it seems to work fine. So I take this to mean there may be some kind of formatting issue with the code I entered into Notepad? For what it's worth, I pieced together the listing from a December issue of the Rainbow magazine from '82 that was scanned in on archive.org. The scanner OCR was naturally not perfect, so I went through line by line and made sure it was accurate to the actual PDF of the magazine so I think the code is fine.
Does the Mac use some unusual/different character to end a line? Something other than what the Coco is expecting?
It has been ~20 years since I last used a Mac, but I vaguely recall a similar problem moving text files from the Mac to the PC. The text mainly looked OK, but there was some odd EOL character or code that caused me problems. I know that I found software to automatically "reformat" the files, but the details are now very long forgotten.
The Mac ( and the Apple ][ ) end a Line with the Carriage Return ( ASCII Code 13 )
UN*X ( and BSD and Linux ) end a Line with the Line Feed ( ASCII Code 10 )
MS-DOS, and Windows end a Line with the Carriage Return ( ASCII Code 13 ) followed with the Line Feed ( ASCII Code 10 )
MarkO
