chinnyhill10 #426 Posted March 13, 2016 @olix: thanks for taking the trouble! Similar hints by other hardware wizards tackling the other installations would be highly welcome! I feel a lot like chinnyhill10, I am confident I can solder enough but don't always understand why I am doing what I am doing. Yes that step by step guide for the 7800 looks ideal. Can anyone do it for the other machines, e.g. the 65 XE? Quote Share this post Link to post Share on other sites
Bryan #427 Posted March 13, 2016 I'll get a better XE guide up soon! Quote Share this post Link to post Share on other sites
Prestone #428 Posted March 14, 2016 Same here, I'm pretty much waiting for the 130XE step by step instructions before I even take the board parts out of the wrappers. Quote Share this post Link to post Share on other sites
Bryan #429 Posted March 14, 2016 Here's the quick install instructions for the 65/130XE. Solder the socket on top of the 4050. Notice that pin 1 is on the left. The important pins are 1, 3, 5, 7, 8, 11, 14. Lift the front-most lead (bottom leg in the picture) of the 3 circled ferrite beads. You can do this by clipping the lead at the board, or by applying heat to the pad and gently pulling the lead out. Once the lead is out of the board, solder a wire to it. These 3 wires will go to the indicated terminals in the green block (Terminal 1 is closest to the adjustment pot). Solder a wire to pin 21 of GTIA. This will go to terminal 6. Solder a Ground wire to the top lead of R52 (left-most resistor behind the video DIN). Make sure the jumpers are configured for the 130XE (this is the default when shipped. Ignore the spare 6th jumper at the bottom) : http://atariage.com/forums/topic/246613-new-video-upgrade-coming-soon/?p=3431922 Plug in the board with the logo toward the front. Gently push the electrolytic cap (C50) to the side if need be. Connect the terminal wires for GND, Composite, Luma, Chroma, Color-In. Leave the pot in the default (middle) position. Power it up and you should have video. 2 Quote Share this post Link to post Share on other sites
olix #430 Posted March 14, 2016 Here's the quick install instructions for the 65/130XE. Solder the socket on top of the 4050. Notice that pin 1 is on the left. The important pins are 1, 3, 5, 7, 8, 11, 14. ... if i don't want to use the internal original Viedo-Part anymore, is it possible to desolder the 4050 and solder the socket directly on the board? Quote Share this post Link to post Share on other sites
Bryan #431 Posted March 14, 2016 ... if i don't want to use the internal original Viedo-Part anymore, is it possible to desolder the 4050 and solder the socket directly on the board? Yes. Quote Share this post Link to post Share on other sites
dakidski #432 Posted March 14, 2016 I'll get a better XE guide up soon! Would love a 600 XL PAL guide. I'm unsure exactly where to cut the traces, and how to go about that. Would love visuals too. So far I've been waiting with the install, until other users post their experience with 600 XL. Cheers. Quote Share this post Link to post Share on other sites
Bryan #433 Posted March 14, 2016 Would love a 600 XL PAL guide. I'm unsure exactly where to cut the traces, and how to go about that. Would love visuals too. So far I've been waiting with the install, until other users post their experience with 600 XL. Cheers. Okay, start with this post: http://atariage.com/forums/topic/246613-new-video-upgrade-coming-soon/?p=3461801 Make sure you cut the fat trace between pins 2-5 under the DIN port. Cut the top trace shown in the picture I've attached. If you have good access to the back of the DIN port, you can attach the wires there. If not, the dots show places you can drill a small hole to pass the wires through. There's also a closer place to pick off GTIA pin 21 at the top of the resistor shown. Put the board in the socket (logo facing front) and attach Composite, Luma, Chroma, and Color IN to the terminals. BTW, if you remove the 4050, you lose the modulator function. Quote Share this post Link to post Share on other sites
Bryan #434 Posted March 14, 2016 Good News: I have installed the basic kit in my 7800 PAL (Rev. C - with the little daughterboard). 7800 SVideo: Perfect image without interference (on CRC an LCD TV) 7800 Composite: Very good image without interference (on CRC an LCD TV) 2600 SVideo: Perfect image without interference (on CRC an LCD TV) 2600 Composite: Very good image without interference (on CRC an LCD TV) Of course 7800 AND 2600 Games are in color! Thanks! RevEng pointed out something I missed about the 7800 schematic so I'm going to look at it again too. I want to leave as much of the 7800 intact as possible. I'll eventually get a 7800 to test on, but for now I'm stuck simulating things. Quote Share this post Link to post Share on other sites
+DrVenkman #435 Posted March 14, 2016 Hey guys - what size screwdriver do I need for the screws on the terminal block? Went to install today and the smallest flat blade I have (3/32") is too big by far. Quote Share this post Link to post Share on other sites
olix #436 Posted March 14, 2016 Thanks! RevEng pointed out something I missed about the 7800 schematic so I'm going to look at it again too.... i don't understand? I am very enthusiastic about the UAV. The SVideo Image on the 7800 is absolutly perfect and the composite signal is almost perfect. You did really a great job. There is nothing you missed about the 7800 schematic. Tomorrow i will install the uav in my 800XL an in my 130XE. Thank you for making this great hardware. Olix Quote Share this post Link to post Share on other sites
Bryan #437 Posted March 14, 2016 i don't understand? I am very enthusiastic about the UAV. The SVideo Image on the 7800 is absolutly perfect and the composite signal is almost perfect. You did really a great job. There is nothing you missed about the 7800 schematic. Tomorrow i will install the uav in my 800XL an in my 130XE. Thank you for making this great hardware. Olix Thanks! I'm glad you got it working well. I just wanted to see if the on-board (modulated) video can be left alone with UAV. Quote Share this post Link to post Share on other sites
+DrVenkman #438 Posted March 14, 2016 Hey guys - what size screwdriver do I need for the screws on the terminal block? Went to install today and the smallest flat blade I have (3/32") is too big by far. Never mind, found a set of jeweler's screwdrivers I thought I had but couldn't find earlier. That did it. But clearly, something is ... not quite right. This is composite in an 800XL so ... which connections should I check first? Remember, I assembled this board from parts, so I'm thinking I may have a bad solder joint at one or more of the jumper block pins. Quote Share this post Link to post Share on other sites
chinnyhill10 #439 Posted March 14, 2016 Here's the quick install instructions for the 65/130XE. Thanks. That makes it clearer. I was all ready to desolder the original chip, not to piggy back the new board on top! Thanks. Quote Share this post Link to post Share on other sites
Bryan #440 Posted March 15, 2016 Never mind, found a set of jeweler's screwdrivers I thought I had but couldn't find earlier. That did it. But clearly, something is ... not quite right. IMG_5763.jpg This is composite in an 800XL so ... which connections should I check first? Remember, I assembled this board from parts, so I'm thinking I may have a bad solder joint at one or more of the jumper block pins. Looks like LUM3 isn't hooked up. The standard blue screen is a lum of 0x0A against background of 0x04. If you're missing the top bit, you get a lum of 0x02 for the text. On the 800XL, LUM3 is pin 3 of the CD4050. The jumper that makes the LUM3 to Pin 3 connection is the 2nd one that goes across (looking at the jumper pictures, the 2nd jumper down). 2 Quote Share this post Link to post Share on other sites
+DrVenkman #441 Posted March 15, 2016 Looks like LUM3 isn't hooked up. The standard blue screen is a lum of 0x0A against background of 0x04. If you're missing the top bit, you get a lum of 0x02 for the text. On the 800XL, LUM3 is pin 3 of the CD4050. The jumper that makes the LUM3 to Pin 3 connection is the 2nd one that goes across (looking at the jumper pictures, the 2nd jumper down). Thank you, sir! I'll give the board a good look in the next day or two and hopefully get things up and running properly. If it's any consolation, the pixels are delightfully sharp ... Quote Share this post Link to post Share on other sites
Bryan #442 Posted March 15, 2016 Thank you, sir! I'll give the board a good look in the next day or two and hopefully get things up and running properly. If it's any consolation, the pixels are delightfully sharp ... You're welcome. This might help you with continuity testing: UAV r.C Configuration Header: P14 SY L3 P3 P5 L0 SY P7 P11 L2 L1 P7 P9 L3 P9 L2 L0 P5 InvC InvC 4050 pinout for 800XL/ALL XE L0 = P7 L1 = P11 L2 = P5 L3 = P3 SY = P14 P=pin, L=Lum, SY=sync. Make sure the P pins in the header connect to the socket pins. 2 Quote Share this post Link to post Share on other sites
Bryan #443 Posted March 15, 2016 Thanks. That makes it clearer. I was all ready to desolder the original chip, not to piggy back the new board on top! Thanks. It may fit better being in a lower socket, but it should work either way. Leaving the 4050 in preserves the modulator function, but removing the shielding makes the modulator pretty worthless. Quote Share this post Link to post Share on other sites
olix #444 Posted March 15, 2016 Hi, did i understand this right: If i use the plugin-version of the uav, but don't like to use the 5V and GND from the 4050, so i have to cut the little bridge in the middle of the pads: But where should i solder the 5V and GND wire : To the half of the pad outside or the half inside? Olix Quote Share this post Link to post Share on other sites
Bryan #445 Posted March 15, 2016 Hi, did i understand this right: If i use the plugin-version of the uav, but don't like to use the 5V and GND from the 4050, so i have to cut the little bridge in the middle of the pads: UVA-800XL.jpg But where should i solder the 5V and GND wire : To the half of the pad outside or the half inside? Olix The right -> side. Quote Share this post Link to post Share on other sites
dakidski #446 Posted March 15, 2016 Okay, start with this post: http://atariage.com/forums/topic/246613-new-video-upgrade-coming-soon/?p=3461801 Make sure you cut the fat trace between pins 2-5 under the DIN port. Cut the top trace shown in the picture I've attached. If you have good access to the back of the DIN port, you can attach the wires there. If not, the dots show places you can drill a small hole to pass the wires through. There's also a closer place to pick off GTIA pin 21 at the top of the resistor shown. Put the board in the socket (logo facing front) and attach Composite, Luma, Chroma, and Color IN to the terminals. BTW, if you remove the 4050, you lose the modulator function. So these are the two cuts (marked as red lines) that I need to make? http://imgur.com/a/Cc6HZ I've never cut lines before, but I suppose a dremel can do the job. How deep do I cut? BTW. I removed the RF-modulator. Additional detail pictures (taken today) of the Atari 600 XL PAL board: http://imgur.com/a/EavrE Regards, dakidski Quote Share this post Link to post Share on other sites
Bryan #447 Posted March 15, 2016 So these are the two cuts (marked as red lines) that I need to make? Yes. A Dremel works well, just be careful it doesn't 'walk' while you're using it. Also, a blade works but can take longer. Quote Share this post Link to post Share on other sites
dakidski #448 Posted March 15, 2016 Thank you! Lines cut. (Checked with multimeter.) UAV plugged in. - No problem with height. No need to bend resistors. I used the supplied chip socket to elevate the UAV. Jumpers set to Atari 600 XL. Now I just need the wires! Pics that may or may not help someone: http://imgur.com/a/wBfYC 1 Quote Share this post Link to post Share on other sites
cjameslv #449 Posted March 15, 2016 Just finished my install today on my ntsc 7800. What a great board! Very simple and straight forward install. I removed my rf and used double sided tape to stick the pcb in its place. Picture quality is beautiful. Running it in svideo on a crt monitor. Heres a couple pics: 1 Quote Share this post Link to post Share on other sites
+iesposta #450 Posted March 16, 2016 Just finished my install today on my ntsc 7800. What a great board! Very simple and straight forward install. I removed my rf and used double sided tape to stick the pcb in its place. Picture quality is beautiful. Running it in svideo on a crt monitor. Heres a couple pics:... That's a different way to get the audio than I did. Both TIA and POKEY sound are at the bottom of the 2 resistors (side facing the console's front), left of the tall red coil. I bridged a .1uf electrolytic cap and wired to the center of the audio, and ran ground to the large area where the RF was. Here's a halfway installed pic. All signals can be found above that small left-most IC xx74LS32x. Some at the thru holes in front of the resistors, and the rest at the resistors. I still think a resistor needs pulled because composite is fuzzier than it should be. The PAL install above had a resistor removed. like I already said, no hurry as SVideo is spectacular. Just in the future composite is convenient to have when travelling. S-Video: I Quote Share this post Link to post Share on other sites
