sideburn #1 Posted January 14, 2016 Can someone please answer me all or even just one of these questions: Should the picture tube be lighting up even if logic board is disconnected? What voltages should I see on back off crt and near the high voltage transformer? If this is not the place for tech help, is there another vectrex forum where I can get some troubleshooting support? Thanks! I am desperate for some help trying to repair my vectrex. The picture tube is dead but I'm seeing voltages that look correct so I'm wondering if the crt itself is bad. I got no replies from my first post so I guess this one will be my last try Quote Share this post Link to post Share on other sites
+madman #2 Posted January 15, 2016 Have you looked at the service manual? It should cover all necessary voltages. Quote Share this post Link to post Share on other sites
chas10e #3 Posted January 15, 2016 Have you looked at the service manual? It should cover all necessary voltages. http://www.ags.tu-bs.de/lib/exe/fetch.php?media=web:e.lab:projekte:vectrex_manual.pdf there is also Vector gaming forums http://vectorgaming.proboards.com/ I'm hoping mine never breaks .... Atariage does have many good techs & I hope you find the help you need Quote Share this post Link to post Share on other sites
juice2839 #4 Posted January 15, 2016 Can someone please answer me all or even just one of these questions: Should the picture tube be lighting up even if logic board is disconnected? What voltages should I see on back off crt and near the high voltage transformer? If this is not the place for tech help, is there another vectrex forum where I can get some troubleshooting support? Thanks! I am desperate for some help trying to repair my vectrex. The picture tube is dead but I'm seeing voltages that look correct so I'm wondering if the crt itself is bad. I got no replies from my first post so I guess this one will be my last try I highly doubt your crt is bad. Your high voltage is likely the problem. Things to check - Power supply volatges, 555 timer, High voltage transistor. Quote Share this post Link to post Share on other sites
