omf Posted May 1, 2016 Share Posted May 1, 2016 Just curious, why are you fluxing the boards. I've make a lot using just flux core solder with no problem with a fine chisel tip about 1/3 the diameter of the stock hakko fx988d tip. Not saying you should do that. Just curious why you are applying flux. this is mostly from the flux core of the 1mm solder i was using, the lowest pins on the board are very close to the cartridge connector so if / when it spits there's a good chance it goes on the cartridge connector some chips had dirty pins and needed some additional attention to solder in, on these problematic chips extra flux was used, generally though this was not necessary Quote Link to comment Share on other sites More sharing options...
omf Posted May 1, 2016 Share Posted May 1, 2016 Do we have a price that can be announced? [i presume the gaz that will handle the sale is you, here, if not please apologies] Care to share what was the issue you faced a couple of weeks ago with the EPROM speed? Just as a way to share a lesson learnt if any. not sure i took those boards out and made new, testing every chip set in a socketed board before soldering in to the final board i will work on these bad boards later to decide on the problem there is however like 12 of them which is rather annoying as that was a complete batch (waste of a saturday) 1 Quote Link to comment Share on other sites More sharing options...
omf Posted May 1, 2016 Share Posted May 1, 2016 All boards have been tested and work although some users may get some red screen issues due to flux splashes on the cart connector, not much i can do about that apart from brasso each board which im not going to do. As i say each board has been tested to get to the title screen. These boards use a legit cart header so if it boots it wont crash later on. i have decided to clarify this so there is no doubt in peoples mind. during soldering on some boards some flux splashed onto the cartridge connector, flux is not electrically conductive and the flux in the core of the solder i was using sets quite hard as a result it can insulate the cartridge connector socket and pins which results in a red screen where the connection is not good between the cartridge and socket during testing on these problematic cartridges were plugged into the jag several times to basically scrape the flux from the cartridge connector which it worked (so the game has been tested as i say) however your jaguar may not be aligned to the same as my cartridge socket pins so when you plug it in you may get a red screen. if this happens, you should be able to plug in the cartridge several times for your cartridge pins to scrape through the flux and make good contact and boot, please try this first if you have a red screen issue before reporting it to us as there may not be anything wrong. gaztee will be testing them again when the cartridge is made also so two verifications per board will be done our end hope that this clears up anyone's doubts. 8 Quote Link to comment Share on other sites More sharing options...
Zerosquare Posted May 1, 2016 Share Posted May 1, 2016 There are special sprays to remove flux (like this), but you can also use isopropyl alcohol, or even ethanol, in a pinch. It's easier and cleaner than scraping flux from pads 1 Quote Link to comment Share on other sites More sharing options...
rayik Posted May 1, 2016 Share Posted May 1, 2016 If you used no clean flux you hold be fine without cleaning it at all. If you used a different kind of flux you most likely should clean off the residue. 1 Quote Link to comment Share on other sites More sharing options...
roquer.jordi Posted May 2, 2016 Share Posted May 2, 2016 There are special sprays to remove flux (like this), but you can also use isopropyl alcohol, or even ethanol, in a pinch. It's easier and cleaner than scraping flux from pads S you suIf you used no clean flux you hold be fine without cleaning it at all. If you used a different kind of flux you most likely should clean off the residue. Enviado desde mi A0001 mediante Tapatalk Quote Link to comment Share on other sites More sharing options...
Gaztee Posted May 2, 2016 Share Posted May 2, 2016 8 Quote Link to comment Share on other sites More sharing options...
+BitJag Posted May 2, 2016 Share Posted May 2, 2016 Rebooteroids and Megablast! YES! Quote Link to comment Share on other sites More sharing options...
bmx Posted May 3, 2016 Share Posted May 3, 2016 Looks good. Quote Link to comment Share on other sites More sharing options...
Atlantis Posted May 3, 2016 Share Posted May 3, 2016 Enter 2016, the year of the shmups!! Quote Link to comment Share on other sites More sharing options...
KidGameR186496 Posted May 4, 2016 Share Posted May 4, 2016 Rebooteroids and Megablast! YES! Don't forget Xevious 4 Quote Link to comment Share on other sites More sharing options...
+CyranoJ Posted May 4, 2016 Author Share Posted May 4, 2016 Don't forget Xevious Don't forget Llamatron and Revenge of the Mutant Camels! 7 Quote Link to comment Share on other sites More sharing options...
+BitJag Posted May 4, 2016 Share Posted May 4, 2016 Don't forget Xevious Don't forget Llamatron and Revenge of the Mutant Camels! This year has been, and will continue to be awesome! 2 Quote Link to comment Share on other sites More sharing options...
+CyranoJ Posted May 4, 2016 Author Share Posted May 4, 2016 This year has been, and will continue to be awesome! There's another shmup coming as well. But that isn't for me to announce 2 Quote Link to comment Share on other sites More sharing options...
+BitJag Posted May 4, 2016 Share Posted May 4, 2016 There's another shmup coming as well. But that isn't for me to announce Sweet! I am starting to think that I should wait on releasing Flappy McFur. Nobody is going to have money to spend on it It definitely takes a back seat to everything that is going to be released when it comes to depth. McFur can wait another year right? (Now going on 3 years in development, and yes, I am quite embarrassed by how long this is taking me to do a Flappy Bird inspired clone... ) 3 Quote Link to comment Share on other sites More sharing options...
phoenixdownita Posted May 4, 2016 Share Posted May 4, 2016 ..., I am quite embarrassed by how long this is taking me to do a Flappy Bird inspired clone... I give up on a poop after 20mins, you are still on your game after 3 years, nothing to be ashamed of imho, the commitment to it is outstanding or at least the hope to one day finish it is. 2 Quote Link to comment Share on other sites More sharing options...
+CyranoJ Posted May 4, 2016 Author Share Posted May 4, 2016 McFur can wait another year right? (Now going on 3 years in development) 7 years is the benchmark, remember? 5 Quote Link to comment Share on other sites More sharing options...
Sapicco Posted May 4, 2016 Share Posted May 4, 2016 Sweet! I am starting to think that I should wait on releasing Flappy McFur. Nobody is going to have money to spend on it It definitely takes a back seat to everything that is going to be released when it comes to depth. McFur can wait another year right? (Now going on 3 years in development, and yes, I am quite embarrassed by how long this is taking me to do a Flappy Bird inspired clone... ) If it's ready, put it. If you build it, we will buy. Don't worry, we have $. 1 Quote Link to comment Share on other sites More sharing options...
Rick Dangerous Posted May 4, 2016 Share Posted May 4, 2016 Sweet! I am starting to think that I should wait on releasing Flappy McFur. Nobody is going to have money to spend on it It definitely takes a back seat to everything that is going to be released when it comes to depth. McFur can wait another year right? (Now going on 3 years in development, and yes, I am quite embarrassed by how long this is taking me to do a Flappy Bird inspired clone... ) It plays fine to me, release that sucker!! It should be on a CD though, just my thought. Quote Link to comment Share on other sites More sharing options...
phoenixdownita Posted May 4, 2016 Share Posted May 4, 2016 Back on track, it's MAY the 4th, where's my Xenon II list? Add me to that list Quote Link to comment Share on other sites More sharing options...
Rick Dangerous Posted May 4, 2016 Share Posted May 4, 2016 Can we start sending PayPal's yet? My body is ready! Quote Link to comment Share on other sites More sharing options...
+CyranoJ Posted May 4, 2016 Author Share Posted May 4, 2016 Can we start sending PayPal's yet? My body is ready! Sure, send them to me. Not guaranteeing anything in return tho 7 Quote Link to comment Share on other sites More sharing options...
+orpheuswaking Posted May 5, 2016 Share Posted May 5, 2016 Is there a Paypal list? 2 Quote Link to comment Share on other sites More sharing options...
Rick Dangerous Posted May 5, 2016 Share Posted May 5, 2016 Sure, send them to me. Not guaranteeing anything in return tho What about an 8biteer cart? Quote Link to comment Share on other sites More sharing options...
guSTaw Posted May 6, 2016 Share Posted May 6, 2016 I can not wait... Quote Link to comment Share on other sites More sharing options...
